RIP Version 2 Routing Table & DHCP Question :)
Iluvnetwork
R3# show ip route
1.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
R 1.0.0.0/8 is possibly down, routing via 1.1.1.2, Serial0/0
C 1.1.1.0/24 is directly connected, Serial0/0
3.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
R 3.0.0.0/8 [120/1] via 192.168.0.253, 00:02:31,
FastEthernet0/0
R 3.3.3.0/24 [120/1] via 192.168.0.253, 00:00:21,
FastEthernet0/0
C 192.168.0.0/24 is directly connected, FastEthernet0/0
R 200.0.0.0/24 [120/1] via 1.1.1.2, 00:00:16, Serial0/0
After 1min or few sec,
1.0.0.0/24 is subnetted, 1 subnets
C 1.1.1.0 is directly connected, Serial0/0
3.0.0.0/24 is subnetted, 1 subnets
R 3.3.3.0 [120/1] via 192.168.0.253, 00:00:23, FastEthernet0/0
R 200.0.0.0/24 [120/1] via 1.1.1.2, 00:00:21, Serial0/0
After rip routing (Version 2 + no auto-summary), I was expecting to see two C and two R. However, as you can see, 6 lines routing table was made somehow. After few seconds or 1 min, 6 lines routing table became as I expected. Can anyone explain to me why the routing table was 6 lines instead of 4 lines at the beginning?
I configured DHCP setting on both active and standby. Is there anyway that the active router sends the DHCP configuration to the standby router?
Router 4's Configuration
Router(config)#do show
show
% Incomplete command.
Router(config)#do show run
Building configuration...
Current configuration : 696 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Router
ip dhcp pool test
network 200.0.0.0 255.255.255.0
default-router 200.0.0.254
no ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 200.0.0.253 255.255.255.0
duplex auto
speed auto
standby 0 ip 200.0.0.254
standby priority 255
interface Serial0/0
bandwidth 64
ip address 1.1.1.2 255.255.255.0
router rip
version 2
network 1.0.0.0
network 200.0.0.0
no auto-summary
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Hello
What you are seeing is due to the disablement of auto summerization and rip ver 2 being applied and as such the classful network 1.0.0.0/8 which was being advertised will now be re advertised with its correct subnet mask 1.1.1.0/24.
The old 1.0.0.0/8 route ( as you have posted) will eventually timeout thorough the RIP protocol invalid and holddown timers.(unless you manually clear the route table)
res
Paul
Kind Regards
Paul
5 Replies 5
Julio E. Moisa
Based on your topology and IP plan the HSRP on the left side is not configured properly they (Router 1 and 3) have different HSRP virtual IP, is that information right? otherwise please share the config into a notepad.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Opps my bad. I did configure correctly :) Both virtual IP is 192.168.0.252
Updated Configuration Info.
That is ok, I see the following message: possibly down:
It can indicate a poisoning route was received, when during the hold down timer is being processed and if an update with valid information about a recovered network it will be restablished. The poisoning route is used to avoid loops on distance vector routing protocols.
Hello
res
Paul
Kind Regards
Paul
Thank you very much! Perfect Explanation :)
