RIPV2 CONNECTION PROBLEMS
Hello everyone.
Im having some tasks to do in my final exam and everything I try seems to fail, can u guys help me please?
So, as you see in the image (1), I'm trying to ping 8.8.8.8, 151.101.133.67 and 170.1.2.3 Servers  from the higher router called "ISP_A_Porto", I can do it easily to the 151.101.133.67 Server but for the others, I got no response.
I need to use RIP V2 protocol...I think I got everything right on the middle path, as u can see by the ip route of RouterCnn (2) but I didnt find a way to use a similar configuration in the first path, for example (as you see in ip route of "RouterDNS")...How can I change the ip route of "RouterDNS" and "RouterMail" to make it all work as I want?
The rest of IP routes are in the images:
2- RouterCNN
3- RouterDNS
4-GigaPix_Porto;
5-ISP_A_Porto
RouterCNN CONFIG:
ipcef
no ipv6 cef
interface Serial0/0
no ip address
encapsulation frame-relay
clock rate 125000
interface Serial0/0.400 point-to-point
ip address 10.10.8.1 255.255.255.0
frame-relay interface-dlci 400
interface Serial0/0.401 point-to-point
ip address 10.10.5.2 255.255.255.0
frame-relay interface-dlci 401
interface Serial1/0
no ip address
clock rate 2000000
shutdown
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface GigabitEthernet3/0
ip address 151.101.133.1 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet4/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet5/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet6/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet7/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet8/0
no ip address
duplex auto
speed auto
shutdown
interface GigabitEthernet9/0
no ip address
duplex auto
speed auto
shutdown
router rip
version 2
network 10.0.0.0
network 151.101.0.0
no auto-summary
ip classless
ip route 10.10.6.0 255.255.255.0 10.10.8.2
ip route 10.10.7.0 255.255.255.0 10.10.8.2
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
RouterMail Config
no ip cef
no ipv6 cef
interface Serial0/0
no ip address
clock rate 125000
interface Serial0/0.500 point-to-point
ip address 10.10.11.2 255.255.255.0
frame-relay interface-dlci 500
interface Serial0/0.501 point-to-point
ip address 10.10.12.1 255.255.255.0
frame-relay interface-dlci 501
interface Serial1/0
no ip address
clock rate 2000000
shutdown
interface Serial2/0
no ip address
clock rate 2000000
shutdown
ip address 170.1.2.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
router rip
version 2
network 10.0.0.0
network 170.1.0.0
no auto-summary
ip classless
ip route 10.10.6.0 255.255.255.0 10.10.11.1
ip route 10.10.7.0 255.255.255.0 10.10.11.1
line con 0
line aux 0
line vty 0 4
login
GigaPix_Porto CONFIG
no ip cef
no ipv6 cef
interface Serial0/0
no ip address
interface Serial0/0.300 point-to-point
ip address 10.10.5.1 255.255.255.0
frame-relay interface-dlci 300
interface Serial0/0.301 point-to-point
ip address 10.10.8.2 255.255.255.0
frame-relay interface-dlci 301
interface Serial0/0.700 point-to-point
ip address 10.10.10.5 255.255.255.0
frame-relay interface-dlci 700
interface Serial0/0.701 point-to-point
ip address 10.10.9.5 255.255.255.0
frame-relay interface-dlci 701
interface Serial0/0.800 point-to-point
ip address 10.10.11.1 255.255.255.0
frame-relay interface-dlci 800
interface Serial0/0.801 point-to-point
ip address 10.10.12.2 255.255.255.0
frame-relay interface-dlci 801
interface Serial1/0
no ip address
clock rate 2000000
shutdown
interface Serial2/0
no ip address
clock rate 2000000
shutdown
ip address 10.10.7.2 255.255.255.0
duplex auto
speed auto
ip address 10.10.6.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
shutdown
ip address 10.10.2.2 255.255.255.0
router ospf 10
router-id 2.2.2.2
log-adjacency-changes
network 10.10.2.0 0.0.0.255 area 0
router rip
version 2
network 10.0.0.0
no auto-summary
ip classless
ip route 8.0.0.0 255.0.0.0 10.10.10.4
ip route 151.101.133.0 255.255.255.0 10.10.5.2
ip route 170.1.2.0 255.255.255.0 10.10.12.1
line con 0
line aux 0
line vty 0 4
login
-------------------------------------------------------------------------------------------------------ISP_A_Porto CONFIG
no ip cef
no ipv6 cef
interface Serial0/0
no ip address
clock rate 2000000
shutdown
interface Serial1/0
no ip address
clock rate 2000000
shutdown
interface Serial2/0
no ip address
clock rate 2000000
shutdown
ip address 10.10.7.1 255.255.255.0
duplex auto
speed auto
ip address 10.0.3.1 255.255.255.0
duplex auto
speed auto
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
duplex auto
speed auto
shutdown
no ip address
shutdown
ip address 10.0.4.2 255.255.255.0
router rip
version 2
network 10.0.0.0
no auto-summary
ip classless
line con 0
line aux 0
line vty 0 4
login
Jon Marshall
Image(s) ?
Jon
Martin L
is this a PT project? can you share PT file here (must be in a zip format).
Regards, ML
**Please Rate All Helpful Responses **
