Route map continue statement
Joebananas
Frequent Visitor
Frequent Visitor
Hello everyone, currently learning about route maps and labbed some stuff.
I was wondering if there was something up with my lab (CML2) or if this is normal behavior.
I have EIGRP running between two routers.
one of the router I have a route map set to out on eigrp
I have a deny route map entry with no match statement and just a continue statement. (Should match everything right?)
the next route-map entry is a deny with no match statement. (Again should deny everything right?)
Shouldn't this block everything from going out? I am finding in my lab that it everything ends up getting advertised to the neighbor.
I found this link on my hunt
https://community.cisco.com/t5/routing/bgp-route-map-continue-command-behavior/td-p/1855058
but this is NOT what I am seeing in my lab.
Giuseppe Larosa
Hello @Joebananas ,
can you post the interesting configuration?
My guess is that you tried to use the route-map TEST into a distribute-list command
router eigrp 10
distribute-list route-map TEST out
is this correct ?
By the way, if I correctly remember the continue keyword has been introduced for route-maps applied to BGP, typically BGP neighbors.
Hope to help
Giuseppe
Hey there Giuseppe, you are correct, I did use the distribute-list route-map configuration under eigrp, the configuration is below. Is this not the correct way to apply a route map to EIGRP?
router eigrp 1
 distribute-list route-map test out
 network 2.2.1.1 0.0.0.0
 network 2.2.2.1 0.0.0.0
 network 2.2.3.1 0.0.0.0
 network 192.168.12.2 0.0.0.0
 eigrp router-id 2.2.2.2
Route map config:
route-map test permit 10
 continue
route-map test deny 20
I am going to try doing this in BGP and see if I see the same behavior.
Thanks for the response by the way!
Update: The continue statement did work in BGP
Hello @Joebananas ,
thanks for providing additional info and feedback
I think the continue command is supported in BGP as your tests have shown, but it is not supported in EIGRP and other routing protocols, as a result of this the first clause of route-map TEST being a permit with no match statement allows all routes to be sent out in EIGRP routing process.
Hope to help
Giuseppe
