Route-Map in Switch Catalyst 3560
npservice
Hi, I have a Catalyst 3560 with EI software,two Vlan configured and Ospf routing
Interface Vlan 1 with Ip 10.12.0.1 and Interface Vlan 2 with Ip 10.13.0.1.
I need to give a default route with static route to hosts in network 10.12.0.0 and I need to give a default route received from Ospf External Route to hosts in network 10.13.0.0.
Network 10.12.0.0 must know all Ospf route IA.
Is it possible with Route-Map configuration?If Yes, could you please explain me sample config?
Regards and sorry for my bad english.
Marco
r-simpson
Level 3
Level 3
When NAT uses a route map to decide to create a translation entry, it will always create a "fully extended" translation entry. This translation entry will contain both the inside and outside (local and global) address entries and any TCP or UDP port information. Refer to NAT: Local and Global Definitions for more information on inside and outside (local and global) addresses.Refer URL
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml#h1toh2
