01-21-2006 05:11 AM - edited 03-03-2019 11:31 AM
Hey All,
Router hung after inserting a new T3 card, we tried to remove the T3 card, but still can not get the router reboot properly, it just shows below 3 lines message.
System Bootstrap, Version 12.2(4r)B2, RELEASE SOFTWARE (fc2)
TAC Support: http://www.cisco.com/tac
Copyright 2002 by cisco Systems, Inc.
01-21-2006 07:52 AM
can you get into ROMMON (press Ctrl+Break after powering on the device) ? If so, at the ROMMON prompt, type:
rommon>config-register 0x2142
and then:
rommon>reset
This will reset the configuration of your router to the initial defaults. If you are able to boot the router afterwards, don´t forget to set the configuration-register value back to 0x2102 (otherwise the router will boot to default values every time it is started)...
Let me know if this helps, if not, we will need to try something else...
GP
01-21-2006 03:25 PM
Hi GP,
Thanks for your reply, the problem has been resolved.
Thank You,
Trina
