router configuration backup
salman abid
Level 4
Level 4
Hi guys,
I'm working in a company which is having around 100 sites & its too much difficult to maintain the configuration backups.
sometimes i forgot to take backup after any change
Kindly suggest me some software through which i can centerlize the configuration backup of all routers or the moment there will be a change in configuration it will take automatic backup for that perticular router
I'm looking for a licensed software
6 Replies 6
milan.kulik
Level 11
Level 11
you can copy your config to an FTP server automatically each time you save the config.
All you need is a working FTP server with a proper directory structure.
Then you need to configure on your routers:
ip ftp username ...
ip ftp password ...
archive
  log config
  logging enable
  logging size 1000
  notify syslog contenttype plaintext
  hidekeys
  path ftp://your_server/router_directory/file_name
  write-memory
(This configuration also sends all config changes to Syslog.)
See http://www.cisco.com/en/US/docs/ios/fundamentals/command/reference/cf_a1.html#wp1018716
for details.
HTH,
Milan
can i take backup of cisco router without configuring ftp. is it possible...?
if yes how.?
kcnajaf
Level 11
Level 11
Hi Salman,
If your devices support Kron command you could use it for automatic configuration backup.
Please link gives more details on the same.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_tech_note09186a008020260d.shtml#ab
Najaf
EEM works without any software. You just need TFTP server for that
Here is config
E.g Take Router's startup-config backup on 15th of every month.
Now this is a time-based task. So lets dive into the configuration.
1) R1(config)#event manager applet My_router_backup
2) R1(config-applet)#event ?
application        Application specific event
cli                CLI event
config             Configuration policy event
counter            Counter event
env                Environmental event
gold               GOLD event
interface          Interface event
ioswdsysmon        IOS WDSysMon event
none               Manually run policy event
oir                OIR event
resource           Resource event
rpc                Remote Procedure Call event
snmp               SNMP event
snmp-notification  SNMP Notification Event
syslog             Syslog event
tag                event tag identifier
timer              Timer event
track              Tracking object event
As  you can see, you can define different types of events here. like,  Interface events help you monitor a particular interface value (eg.  broadcast received, input rate in bps/pps, output rate in bps/pps etc).  Syslog is the most common and easy, it helps you monitor a particular  syslog msg and as soon as that syslog message appears on a router you  can define an action based on that (dont worry, i will provide an  example of this). I hope by now you may have get some idea as to what an  event does.
We will select timer since our action is not based on any particular event but rather periodic.
2) R1(config-applet)#event timer ?
absolute   Absolute timer event
countdown  Countdown timer event
cron       Cron timer event
Cron entry is composed of 5 fields and written in this form "x x x x x"
1) Min 0-59
2) Hour 0-23
3) Date 1-31
4) Month 1-12
5) Day of week 0-7
Now if i want to say take backup on 15th of every month at 18:00 pm. So lets start from down to up.
1) Min is 00 -> 0
2) Hour is 18 (so enter as it is)
3) Date is 15
4) Month is * (when we cant specify any value, we can simply write * there which would mean no matter which month is it)
5) Day of week * ( we are putting * here since we have already defined the day through date 15, so whichever day it is )
A little bit about "*". It means "from first to last". I will show the example a bit later in this post. Keep reading...
Therefore the cron_entry will be "0 18 15 * *", which mean on 15th of every month at 18:30 pm this action will take place.
2) R1(config-applet)#event timer cron cron_entry "0 18 15 * *"
action 1 cli command "enable"
action 2 cli command "configure terminal"
action 3 cli command "file prompt quiet"
action 4 cli command "end"
action 5 cli command "copy running-config tftp://tftp-server/router-confg"
action 6 cli command "configure terminal"
action 7 cli command "no file prompt quiet"
action 8 cli command "end"
*** Do Rate Helpful Posts***
Jawad
Thanx for the replies
just confirm me one more thing
at most of sites we have cisco 877 router & cisco 1861 router. so this configuration will support that series or is there some ios prerequisite for this configuration????
salman abid
Level 4
Level 4
well thanks for all the replies........... actually i was looking for some server which can help me to make a centerlized data base of configuration for all the switches, routers & firewalls from multiple locations
Your replies also enhance my knowledge
but finally i got some thing that can fullfill my requirments
http://www.solarwinds.com/network-configuration-manager.aspx
its good to centerlize the configuration of all the devices of different vendors
