Router Failover for PAT and NAT Users
qasimkhans
I need to configure Router failover on WAN links, i am hosting servers (Web server, Citrix, App severs, etc). i have IPs from ISPs. I am also using IP SLA for Internet Failover on router. now i want to setup Routers failover. my both router config as below.
track 10 ip sla 1 reachability
delay down 1 up 1
track 20 ip sla 2 reachability
delay down 1 up 1
interface GigabitEthernet0/0
no ip address
ip virtual-reassembly in
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.7
description Voice-Vlan
encapsulation dot1Q 7
ip address 192.168.7.3 255.255.255.0
ip helper-address 192.168.10.15
ip helper-address 192.168.10.16
interface GigabitEthernet0/0.8
description IT-Vlan
encapsulation dot1Q 8
ip address 192.168.8.3 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.9
description Regency-Vlan
encapsulation dot1Q 9
ip address 192.168.9.3 255.255.255.0
ip nat inside
interface GigabitEthernet0/0.10
description Servers-&-Switches-Vlan
encapsulation dot1Q 10
ip address 192.168.10.7 255.255.255.0
no ip redirects
no ip proxy-arp
ip nat inside
ip policy route-map PBR
interface FastEthernet0/0/1
ip address 50.x.x.14 255.255.255.252
ip nat outside
duplex full
speed 100
crypto map vpn
interface FastEthernet0/1/0
ip address 162.x.x.34 255.255.255.224
ip nat outside
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source route-map ISP1 interface FastEthernet0/0/1 overload
ip nat inside source route-map ISP2 interface FastEthernet0/1/0 overload
ip nat inside source static tcp 192.168.10.53 80 50.x.x.52 80 route-map ISP1 extendable
ip nat inside source static tcp 192.168.10.53 80 162.x.x.35 80 route-map ISP2 extendable
ip route 0.0.0.0 0.0.0.0 50.x.x.13 track 10
ip route 0.0.0.0 0.0.0.0 162.x.x.62 200
ip access-list extended acl_internet
deny   ip 192.168.0.0 0.0.255.255 10.10.10.0 0.0.0.255
deny   ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
permit ip 192.168.0.0 0.0.255.255 any
ip access-list extended acl_natisp1
ip access-list extended acl_natisp2
ip access-list extended acl_ncsvpn
permit ip 192.168.0.0 0.0.255.255 192.168.4.0 0.0.0.255
ip access-list extended acl_vpn
permit ip 192.168.0.0 0.0.255.255 10.10.10.0 0.0.0.255
ip sla 1
icmp-echo 50.x.x.13
threshold 500
timeout 500
frequency 1
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 162.x.x.62
threshold 500
timeout 500
frequency 1
ip sla schedule 2 life forever start-time now
route-map PBR permit 10
match ip address acl_natisp1
set ip next-hop verify-availability 50.x.x.13 1 track 10
route-map PBR permit 20
match ip address acl_natisp2
set ip next-hop verify-availability 162.x.x.62 2 track 20
route-map ISP2 permit 20
match ip address acl_internet
match interface FastEthernet0/1/0
route-map ISP1 permit 10
match interface FastEthernet0/0/1
0 Replies 0
