Router suggestion
harikrishna1991
We are planned to upgrade our ILL bandwidth to around 600Mbps.
Whether Cisco ISR 4451 router support the above mentioned bandwidth.
Any other alternate models
Julio E. Moisa
You can try this tool to select the proper router for your requirements:
http://3c3cc.com/c/dam/assets/prod/routers/cisco-router-selector/index.html
Please rate the comment if it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Joseph W. Doherty
600 Mbps duplex?
The 4451 is capped at either 1 Gbps or 2 Gbps aggregate throughput.  Which depends on whether the performance license has been installed.
If your 600 Mbps is duplex, you may need the 2 Gbps license, but if your normal usage doesn't go beyond gig, aggregate, you wouldn't need the additional license.
