router
The_guroo_2
Level 2
Level 2
hi just wanted to know a v basic thing....can some one plz help me that.......when we r chosing a router...we have to see couple of things....now i m confuse abt one thing which series router is feasible for dealing with how many clients and stuff?? is there any chart or table which can tell me that thanks
pkhatri
Level 11
Level 11
The following document will show you the throughput capability of each router. You can use that to gauge what is suitable for you:
http://www.cisco.com/warp/public/765/tools/quickreference/routerperformance.pdf
Hope that helps - pls rate the post if it does.
Paresh
