Routers between a switch can't ping eachother
MangoChocobo
This is my network i've been playing with in PT. I've got each side (Denver and NYC) to be able to ping Router 2 at the top as well as the PC's. However, my issues is I can't get Denver or NYC Router to ping eachother. Why is that?
Show runs:
- NYC_Router https://pastebin.com/4Ya5dr8N
- DEN_Router https://pastebin.com/YG7MAyuz
Any help is appreciated!
Richard Burts
Based on the information in the drawing the issue is that the router interfaces f0/0 are not in a common subnet. The addresses given are 192.168.120.33/28 and 192.168.120.65/28. For those addresses to be in the same subnet the mask must be at least /25.
Rick
Rick
7 Replies 7
Jaderson Pessoa
Could you show switch0 and routers2 configuration?
Jaderson Pessoa
*** Rate All Helpful Responses ***
Richard Burts
Rick
Rick
I'll try changing them to /25, This is a project I have at school currently and the router up top is a proxy router to the school's network. so I don't have complete access to this. In my scenario at school, we have some servers and clients and Denver and our main Server is at NYC. In school, I can't get them to communicate with each other but wanted to keep them in separate networks but nat them, but to no avail have I been able to fix this issue
Hello
Can you post the PT file please..
Kind Regards
Paul
There you go, I've edited it more on my side and i'm trying to work through it. I can now ping the other router since i've made them part of a /25 network.
Reminder, I don't have access to Router2 or Switch0.
I had to zip it since .pkt files are not accepted extension to send files on here.
Dear  MangoChocob,
 Please, procedure with it
R1, do it
interface f0/1
ip address 192.168.120.34 255.255.255.240
no ip nat inside
R0, do it
interface f0/1
no ip nat inside.
test again connection.
Jaderson Pessoa
I am glad that my suggestion was helpful. Thank you for marking this question as solved. This will help other participants in the community to recognize discussions that have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
Rick
