Routers Temperature
Mansour
Community Member
Please advise, i am observing alarms for high temperature in routers for example below logs for C2900 series.
how it can be fixed & thank you in advance
Intake Left(Bezel) temperature: 46 Celsius, Abnormal
Intake Left temperature: 47 Celsius, Abnormal
Exhaust Right(Bezel) temperature: 50 Celsius, Normal
Exhaust Right temperature: 51 Celsius, Normal
CPU temperature: 77 Celsius, Normal
Power Supply Unit temperature: 51 Celsius, Normal
5 Replies 5
Mansour
Community Member
can we change SYSTEM ALARMS SETTINGS in router ??
Fan tray removal or multi fan failure results in warning
CPU Warning Over Temperature Alarm = 100C
CPU Critical Over Temperature Alarm = 120C
Intake Left(Bezel) Abnormal Temperature Alarm = 45C
Intake Left(Bezel) Over Temperature Alarm = 57C
Intake Left Abnormal Temperature Alarm = 45C
Intake Left Over Temperature Alarm = 57C
Exhaust Right(Bezel) Over Temperature Alarm = 75C
Exhaust Right Over Temperature Alarm = 75C
Power Supply Unit Over Temperature Alarm = 70C
Power Supply Unit Over Critical Temperature Alarm = 85C
Leo Laohoo
Has anyone conducted a visual inspection of the router and the installed environment?
And is this the only alarm?  Are there any related alarms regarding the fan speed?
Visual inspection not yet conducted, what's ur suggestion ?
mostly routers having same alarm some of router having fan issue they are limited in number.
R1#sh environment last
SYSTEM POWER SUPPLY STATUS
Power Supply Type: AC
External Power Supply POE -48V Voltage Status: Not Present
SYSTEM FAN STATUS
Fan 1 OK, Maximum speed setting
SYSTEM TEMPERATURE STATUS
Intake Right temperature: 46 Celsius, Over-Temperature
Intake User temperature: 49 Celsius, Over-Temperature
Exhaust Fan temperature: 50 Celsius, Normal
Intake Right(Bezel) temperature: 46 Celsius, Over-Temperature
REAL TIME CLOCK BATTERY STATUS
Battery OK (checked at power up)
R1#
Fan issue logs:
NAJRAN-NAJRAN_IP10014#
IN_OUTLET_OVERTEMP: Warning: Intake User Temperature
NAJRAN-NAJRAN_IP10014#sh environment table | in fan
System fan failure results in warning
R2#
Mansour
Community Member
is it related to a bug ? or in real fan and temperature issue ??
Maybe the room where the router is installed in is really hot.
Maybe the fans are clogged.
