Routing - AS path prepend based on destination network
prestigio391
Level 3
Level 3
Hello team is possible some way prepend AS path to route based on destination network ? or AS ? Ilocal preference is for icncoming, prepend for outgoing subnets.But when i prepend ASpath to my LAN is goes for everyone. But i want filter it onlu for one destination ASpath or subnet. It is possible ?
Hello
If i understand you correctly you wish to advertise certain lan prefixes via as-prepending to only a specific external ASN that is not directly connected to your local ASN but is reachable via transit ASNs?  if so as far as I am aware you cannot do this, but you can perform it to directly attached external ASN peers which will then iif set to do so advertise your prefixes and attached pre-pending to their peers
Kind Regards
Paul
Hello
Kind Regards
Paul
Ok so it is not possible....i ll do it another way... thank you for answer
