Routing issues - EIGRP
ALIAOF_
Level 11
Level 11
I have a Cisco router connected to a core switch via pass through VLAN.
Cisco PO1(172.16.0.1/30) -------- Juniper (LAG) (172.16.0.2/30)
There are multiple SVI's on the Juniper switch.
Cisco EIGRP config is like this.  I see the EIGRP neighbor and it is up.
H   Address                 Interface              Hold Uptime   SRTT   RTO  Q  Seq
                                                   (sec)         (ms)       Cnt Num
0   10.0.56.153             Gi0/0                     6 00:08:48    1   100  0  2294151
router eigrp 100
 network 10.0.0.0
 redistribute static
 eigrp stub connected static summary redistributed
My routes are showing up like this:
S*    0.0.0.0/0 [1/0] via 10.0.56.153
      10.0.0.0/8 is variably subnetted, 12 subnets, 7 masks
C        10.0.40.88/30 is directly connected, Port-channel1.888
L        10.0.40.89/32 is directly connected, Port-channel1.888
C        10.0.56.152/29 is directly connected, GigabitEthernet0/0
L        10.0.56.155/32 is directly connected, GigabitEthernet0/0
C        10.0.67.180/30 is directly connected, Loopback1
L        10.0.67.182/32 is directly connected, Loopback1
S        10.26.192.0/19 [1/0] via 10.0.40.90
S        10.80.3.0/24 [1/0] via 10.0.40.90
S        10.82.3.0/24 [1/0] via 10.0.40.90
S        10.126.192.0/20 [1/0] via 10.0.40.90
S        10.126.208.0/23 [1/0] via 10.0.40.90
S        10.226.192.0/20 [1/0] via 10.0.40.90
From the LAN I can ping the router, I can ping the 10.0.40.90 which is the Juniper L3 interface connected to the Cisco. I can also ping the Cisco's Interface 10.0.40.89.  But I can not ping out public IPs.  If I remove the "redistribute static" command and update "eigrp stub connected summary" I am able to ping public IP's sourced from the L3 interface of the switch (10.0.40.90) that is about it.  What am I missing here?
I have also tried to update the config as follows:
router eigrp 100
 network 10.0.40.88 0.0.0.3
 network 10.0.56.152 0.0.0.7
 network 10.26.192.0 0.0.31.255
 network 10.126.208.0 0.0.1.255
 redistribute static
 eigrp stub connected static redistributed
Giuseppe Larosa
Hello @ALIAOF_ ,
You have a default static route in the IP routing table and if you redistribute you may be injecting a default route in EIGRP and this can influence the other EIGRP device .
Check what happens on the other EIGRP device you may be overriding its default route and this can break connectivity to the public IP addresses  ( for example NAT s not triggered )
Hope to help
Giuseppe
Georg Pauwen
who is the EIGRP neighbor ?
Post a diagram of your topology, as it is unclear where you are pinging from...
10.0.56.153 is the PE and EIGRP neighbor.  Sorry I did not get a chance to draw the diagram in Visio it's been a busy day.  But here is a high level.
These two are connected via a port channel and using a pass through VLAN.
    - VLAN1 - 10.26.192.0/19
    - VLAN802 - 10.126.208.0/23
    - There are more but I'm just going to use these two for simplicity and this example
I have tried to ping from a laptop that is sitting on VLAN1.
Giuseppe Larosa
Hello @ALIAOF_ ,
Hope to help
Giuseppe
I have tried to take that command out as as well and done something like this too:
router eigrp 100
Also tried this:
router eigrp 100
After doing some troubleshooting today, I feel like there are further config related issues on the PE, which I do not have access too.  Will need to understand more about the flow I think.  So far I can only ping any public IP if I source it from the p2p interfaces on the router or the switch.
