Routing issues
Hi Guys
Looking for some advice.
I have a network with multiple cameras, access controllers etc all IP based.
It ranges from 192.168.x.x and 10.168.x.x. and my monitoring PC`s that checks the cameras etc is on 192.168.0.x
It goes through various switches througout the building and ends up in the server room.
I just got a brand new Cisco 9300 Layer 3 switch and need help.
As i dont know which cable exactly connects to which camera or device i need to setup the switch if possible so that i can just plug in all the cables into any ports. How do i route the different IPs,Subnets so that my PC connected to the switch can be able to access these devices. basically routing it all to the default vlan that is 192.168.0.1
I realize its not ideal setup but currently my old Core switch packed up
21 Replies 21
Hello
@johannesmoolman7574 wrote:
Hi Guys
As you saying your OLD core switch is not working, And this switch is to repalce that old core of do you just want to introduce this new switch to extend your patching capabilities in the server room?
Kind Regards
Paul
Yes but later on i would like to actually use the new 9300 with all its security etc capabilities but for now i just need to replace plug all the lan cables back and be able to monitor my CCTV etc.
ive tried using vlans and inter vlan routing but as i said it wont work as i dont know which cable is on which ip as there is quite a few cables
Hello
First thing first, do you have any core routing at present, how are your users currenty working?
Kind Regards
Paul
Currently my system is down as the core was the main switch in the control room. So it is basically a setup from scratch
Hello
So do you have any backup of your old core switch configuration and/or any details on what routing/ services it was providing?
Kind Regards
Paul
Nope, none all i have is the IP and to be honest i dont think the configuration on that switch was proper as i still needed to add all the Subnets,and IPs on my workstations to access the multiple ranges. and with my limited knowledge i really actually hope my 2 x new 9300 can as it costs a pretty penny
Hello
Well you need the detail on your previous routing that old core was doing otherwise you have to start from scratch.
You should be able to obtain the vlans at least from the other switches vtp database
Show vlan brief
As for the routing, I assume you have/had a dhcp server, if it wasn’t running on your core switch then you could look at that and it should provide you with the dhcp scopes/ip ranges for each routing subnet.
Once you have these details then you should be able to bring up a simple working core very quickly
Kind Regards
Paul
I am running all static Ips and i have all the IPS and ranges it is documented for example i know i have 10.168.1.x -- 10.168.2.x and so on and 192.168.0.x and 192.168.1.x.
i have no issue in starting from scratch as it will be a nice learning curve aswell. just my initial attempts using vlans dont serve my purpose as i need to know then where each and every cable comes from and know each and every range running.
Well, this will spent many time if you dont know about your network.
To get camera connectivy again.
1. Take a look in your server or a camera, check it ip address.
2. Create a vlan with the same network + mask.
3. ping on broadcast of this address, exemple: ip server/camera 192.168.1.10/24, you will ping on 192.168.1.255 to get all address avaiable on this network
4. Make a arp map to get all which mac is learned for each interface.
do it for each service that you want to know what network were used until you shift the devices.
Jaderson Pessoa
*** Rate All Helpful Responses ***
Thanks for your reply
I have around 32 cisco L2 switches around the building with about 24 fibers connecting between them running back to the server room. so on one Cisco L2 switch there are cameras on different ranges 10.x.x.x. and 192.x.x.x and that gets fed back to the server room into a Fiber to copper converters and from there onto the switch so am i wrong then to think that one interface IE.. port 1 will show multiple arp entries.
i am just looking to route/channel any traffic coming in to the switch to the default vlan that then connects to my Monitors
Hope it helps
are you looking for a method to establish connection on this network 10.x.x.x and 192.x.x.x from your pc?
Jaderson Pessoa
Yes , currently i have set up a little lab excersice before going live.
i have my pc 192.168.0.3 the switch default vlan 1 on 192.168.0.1 two cameras 10.168.10.5 and 192.168.5.5 to test a couple of things.
so i have suceeded in setting it up so i can ping from my pc both cameras but that was by using vlan routing.
AS per that method i needed to assign the port the camera is on to the specific vlan. so looking for a way i dont have to assign a specific port to a vlan basically just plug in all patch leads and send it onto vlan 1
Well, let me check if i understood your doubot;
You have a your pc connected under a port in your switch configured in default vlan 1. Which mask address and gateway are you using?
You have two cameras that had the same characteristics in default vlan 1, right? Which mask address and gateway are you using?
you told me that you need setting a correct vlan under port that is connected to the cameras, what vlan you want configure?
Jaderson Pessoa
PC connected on port 1 vlan 1 - 192.168.0.3 / 255.255.255.0 default gateway is 192.168.0.1 /255.255.255.0 the gateway is the switch
camera 1 connected to port 10 Ip address 10.168.10.5 /255.255.255.0
Camera 2 connected to port 11 Ip address 192.168.5.5 / 255.255.255.0
camera one is on vlan 3 currently 10.168.10.1 /255.255.255.0
camera two is on vlan 4 currently 192.168.5.1 / 255.255.255.0
with this setup i can ping both from my pc and direct from the switch
so the endgame if possible
take the switch to server room. plug in my 4 pc`s that monitor the cameras into port 1 -4 plug all other cables from CCTV into the rest any random order.
and lastly do a proper redesign of this mess i call a network 😞
