Routing Load balancing in ASA
mohamed.ali
Dears,
I have to ISP as well one ASA I wanna to create a load-balance between the two link.
I can do it in Cisco Router like this
ip route 0.0.0.0 0.0.0.0 10.0.0.1  1
ip route 0.0.0.0 0.0.0.0 20.0.0.1  1
In this situation I order the router to load balance the traffic.
how can I do it with ASA
thanks
the ASA does not do load balancing, you can only configure it for redundancy. Check the link below for a sample config:
Configure the ASA for Redundant or Backup ISP Links
https://www.cisco.com/c/en/us/support/docs/security/asa-5500-x-series-next-generation-firewalls/118962-configure-asa-00.html
