Routing problem for certain external addresses
scourtney
Hello, all
Although I read the forums frequently, this is my first time posting. Please know that I'm primarily a sysadmin and developer, not a network engineering specialist, and that I've worked much more with Cisco switches rather than routers. IOW, if I'm committing an act of stupidity in my configs, please feel free to constructively enlighten me.
The problem summary is that outbound Internet connectivity works reliably for the overwhelming majority of public IP addresses, but intermittently fails for certain domains. I am not certain, but there may be a correlation that the failing domains use content delivery networks (CDNs) such as Akamai and their competitors. The sites that are failing are major companies, such that it's unlikely their servers are simply down. The symptom is sometimes the address being unpingable from our network as a whole, but sometimes it is pingable from the router but not from our internal hosts via NAT. In the latter case, a traceroute from the internal host shows exactly the same hops as a traceroute from the router itself, except that the internal host adds the router's inside IPv4 address as a first hop. The ISP's eBGP peer address is the first hop from the router and the second hop from the internal host.
Below is a simplified and redacted network diagram. We have two routers, with each connected over an Ethernet eBGP peering to one ISP. The primary router (01) connects to the primary ISP, and the secondary router (02) connects to the secondary ISP. Both primary and secondary ISPs advertise only default routes to us via eBGP; we are a small organization with neither the resources nor the need for larger routing tables.
Although each router is provisioned for both ISPs and has Layer 2 connectivity to them, the ISPs are on separate VLANs, and each router's subinterface is administratively shutdown for the ISP to which it doesn't normally connect. This extra provisioning is intended to allow us to quickly (but manually) adapt to unusual situations in which one router fails and the opposite ISP fails during the same outage.
Each router can reach the public Internet through the other one if its own eBGP connection is down; I have verified this by admin shutdown of the eBGP subinterfaces.
For private and DMZ VLANs, the VIPA for HSRP is the first usable address in the subnet, and this is configured as the default gateway for all hosts on that subnet. The device-specific IPv4 addresses are the last two usable addresses in the subnet. HSRP is not in use on the OSPF backbone nor on the [effectively] point-to-point eBGP segments; we rely the routing protocols to fail us over, and on metrics/priority to ensure that router01 is preferred for each path. The intended behavior is:
router01router02ISP 1ISP 2Internal routingPublic routing
up(any)up(any)router01router01 + isp1
upupdownuprouter01router02 (via router01) + isp2
downup(any)uprouter02router02 + isp2
downupupdownrouter02router02 + isp1 (manual ISP failover)
For internal hosts connecting to the public Internet, I've set up two non-overlapping NAT pools (one on each router) in the U.V.W.0/24 subnet, which is our registered public IPv4 address block. We have a VoIP server that is an exception; I found that our trunk provider didn't like dynamic IP addresses at our end, so that server has a hardwired NAT outside address.
Following is my excerpted config file, again with placeholder IP addresses matching the above diagram:
hostname router01
redundancy
mode none
interface Loopback0
description Always-up pingable address
ip address 10.250.1.1 255.255.255.0
ipv6 address **************************
interface Port-channel1
description Data trunk
no ip address
interface Port-channel1.3
description OSPF Backbone
encapsulation dot1Q 3
ip address 10.0.5.1 255.255.255.0
no ip redirects
ip nat inside
ip ospf priority 100
ip virtual-reassembly
interface Port-channel1.6
description Core production servers
encapsulation dot1Q 6
ip address 10.1.3.254 255.255.252.0
ip nat inside
standby version 2
standby 6 ip 10.1.0.1
standby 6 priority 110
standby 6 preempt delay minimum 60
interface Port-channel1.665
description DMZ
encapsulation dot1Q 665
ip address 10.0.7.254 255.255.255.0
ip nat inside
ip access-group from_dmz_ipv4 in
standby version 2
standby 665 ip 10.0.7.1
standby 665 priority 110
standby 665 preempt delay minimum 60
ipv6 address ****:****:****:****:****.0.7.254/112
interface Port-channel1.667
description External IP segment
encapsulation dot1Q 667
ip address U.V.W.254 255.255.255.0
no ip redirects
ip access-group from_external_ipv4 in
standby version 2
standby 667 ip U.V.W.1
standby 667 priority 110
standby 667 preempt delay minimum 60
ipv6 address ****:****:****:0:U.V.W:254/112
interface Port-channel2
description ISP trunk
no ip address
negotiation auto
interface Port-channel2.6
shutdown
interface Port-channel2.1997
description BGP to secondary ISP
encapsulation dot1Q 1997
ip address E.F.G.106 255.255.255.252
ip nat outside
ip access-group from_isp2_ipv4 in
shutdown
interface Port-channel2.1998
description BGP to primary ISP
encapsulation dot1Q 1998
ip address A.B.C.146 255.255.255.252
ip nat outside
ip access-group from_isp1_ipv4 in
interface Port-channel2.1999
description BGP to Primary ISP IPv6
encapsulation dot1Q 1999
ipv6 address ****:****:****:****::941/127
ipv6 enable
ipv6 traffic-filter from_isp1_ipv6 in
router ospfv3 100
router-id 10.250.1.1
address-family ipv4 unicast
redistribute static
redistribute bgp OUR_ASN metric 120
passive-interface default
no passive-interface Port-channel1.3
exit-address-family
address-family ipv6 unicast
redistribute static
exit-address-family
router ospf 100
priority 100
redistribute connected metric 2
redistribute static metric 1
network 10.250.1.0 0.0.0.255 area 0
network 10.0.5.0 0.0.0.255 area 0
network 10.0.7.0 0.0.0.255 area 0
network 10.1.0.0 0.0.3.255 area 0
network U.V.W.0 0.0.0.255 area 0
default-information originate
router bgp OUR_ASN
bgp router-id 10.250.1.1
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor E.F.G.105 remote-as ISP2_ASN
neighbor E.F.G.105 description Secondary ISP
neighbor ****:****:****:****::940 remote-as ISP1_ASN
neighbor ****:****:****:****::940 description Primary ISP
neighbor ****:****:****:****::940 update-source Port-channel2.1999
neighbor A.B.C.145 remote-as ISP1_ASN
neighbor A.B.C.145 description Primary ISP
neighbor A.B.C.145 update-source Port-channel2.1998
address-family ipv4
network U.V.W.0
neighbor E.F.G.105 activate
neighbor E.F.G.105 weight 20000
neighbor E.F.G.105 soft-reconfiguration inbound
neighbor E.F.G.105 prefix-list IPV4_ANY in
neighbor E.F.G.105 prefix-list IPV4_EXT out
neighbor A.B.C.145 activate
neighbor A.B.C.145 weight 21000
neighbor A.B.C.145 soft-reconfiguration inbound
neighbor A.B.C.145 prefix-list IPV4_ANY in
neighbor A.B.C.145 prefix-list IPV4_EXT out
exit-address-family
address-family ipv6
redistribute static
network ****:****:****::/48
neighbor ****:****:****:****::940 activate
neighbor ****:****:****:****::940 weight 21000
neighbor ****:****:****:****::940 soft-reconfiguration inbound
neighbor ****:****:****:****::940 prefix-list IPV6_ANY in
neighbor ****:****:****:****::940 prefix-list IPV6_ARIN out
exit-address-family
ip forward-protocol nd
ip nat pool natpool U.V.W.240 U.V.W.249 prefix-length 24
ip nat inside source static udp OUR_VOIP_SERVER 5060 U.V.W.37 5060 extendable
ip nat inside source static OUR_VOIP_SERVER U.V.W.37
ip nat inside source list ipv4_rfc1918_nat pool natpool overload
ip route DEVLAB_TEST_SEGMENT 255.255.255.0 DEVLAB_TEST_ROUTER
ip route U.V.W.0 255.255.255.0 Null0
ip access-list extended from_external_ipv4
10 deny ip host 0.0.0.0 any
20 deny ip 127.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255
30 deny ip 10.0.0.0 0.255.255.255 255.0.0.0 0.255.255.255
40 deny ip 172.16.0.0 0.15.255.255 255.240.0.0 0.15.255.255
50 deny ip 192.168.0.0 0.0.255.255 255.255.0.0 0.0.255.255
60 deny ip 192.0.2.0 0.0.0.255 255.255.255.0 0.0.0.255
70 deny ip 169.254.0.0 0.0.255.255 255.255.0.0 0.0.255.255
80 deny ip 240.0.0.0 15.255.255.255 any
90 deny icmp any any fragments
100 permit udp any host 224.0.0.102 eq 1985
110 permit icmp any any echo-reply
120 permit icmp any any packet-too-big
130 permit icmp any any source-quench
140 permit icmp any any time-exceeded
150 permit icmp U.V.W.0 0.0.0.255 any
160 deny icmp any any
170 permit tcp any any established
180 deny ip any 10.0.0.0 0.255.255.255
190 deny ip any 172.16.0.0 0.15.255.255
200 deny ip any 192.168.0.0 0.0.255.255
210 deny ip any 169.254.0.0 0.0.255.255
220 deny ip any 240.0.0.0 15.255.255.255
230 permit ip U.V.W.0 0.0.0.255 any
240 deny ip any any
ip access-list extended from_isp1_ipv4
100 permit icmp any U.V.W.0 0.0.0.255 echo
150 permit icmp any A.B.C.144 0.0.0.3
170 permit tcp any host A.B.C.146 eq bgp
180 permit tcp any any established
190 permit tcp any U.V.W.0 0.0.0.255 eq www
200 permit tcp any U.V.W.0 0.0.0.255 eq 443
210 permit tcp any U.V.W.0 0.0.0.255 eq smtp
! --- Some permit rules here for specific protocols
! --- to app public-facing app servers (no deny
! --- rules in this section)
250 permit tcp any U.V.W.0 0.0.0.255 eq domain
260 permit udp any U.V.W.0 0.0.0.255 eq domain
300 permit udp any U.V.W.0 0.0.0.255
320 deny ip any any
ip access-list extended from_private_ipv4
10 permit tcp any any established
20 permit udp any host 224.0.0.102 eq 1985
40 permit ip any 10.0.0.0 0.255.255.255
60 remark Internal hosts not allowed outbound SMTP ports
60 deny tcp any any eq smtp
70 deny tcp any any eq 10025
80 deny tcp any any eq 465
90 deny tcp any any eq 587
100 permit ip 10.0.0.0 0.255.255.255 any
120 remark Anything not allowed is forbidden
120 deny ip any any
ip access-list extended ipv4_rfc1918_nat
10 deny ip 192.168.0.0 0.0.255.255 192.168.0.0 0.0.255.255
20 deny ip 192.168.0.0 0.0.255.255 172.16.0.0 0.15.255.255
30 deny ip 192.168.0.0 0.0.255.255 10.0.0.0 0.255.255.255
40 deny ip 172.16.0.0 0.15.255.255 192.168.0.0 0.0.255.255
50 deny ip 172.16.0.0 0.15.255.255 172.16.0.0 0.15.255.255
60 deny ip 172.16.0.0 0.15.255.255 10.0.0.0 0.255.255.255
70 deny ip 10.0.0.0 0.255.255.255 192.168.0.0 0.0.255.255
80 deny ip 10.0.0.0 0.255.255.255 172.16.0.0 0.15.255.255
90 deny ip 10.0.0.0 0.255.255.255 10.0.0.0 0.255.255.255
94 deny udp host OUR_VOIP_SERVER any
100 permit ip 192.168.0.0 0.0.255.255 any
110 permit ip 172.16.0.0 0.15.255.255 any
120 permit ip 10.0.0.0 0.255.255.255 any
130 deny ip any any
ipv6 access-list from_isp1_ipv6
sequence 10 permit tcp any any established
sequence 20 permit icmp any ****:****:****::/64
sequence 30 permit tcp ****:****:****:****::940/127 any eq bgp
sequence 40 deny ipv6 any any
ip prefix-list IPV4_ANY seq 5 permit 0.0.0.0/0
ip prefix-list IPV4_EXT seq 5 permit U.V.W.0/24
ipv6 route ****:****:****::/48 Null0
ipv6 prefix-list IPV6_ANY seq 5 permit ::/0
ipv6 prefix-list IPV6_ARIN seq 5 permit ****:****:****::/48
end
What I have tested and (I think) ruled out so far:
  • The secondary router is not taking control of the HSRP interfaces; "show standby" on both routers shows the expected status.
  • The internal hosts having problems getting outside have correct routing tables, with the HSRP VIPA as their default gateway.
  • The unreachable public IPv4 addresses do not overlap any addresses in our internal ranges (we use only the RFC 1918 private addresses internally).
  • Both ISPs are advertising their default route to us, as expected.
  • Our OSPF and BGP routing tables look sensible and don't show things going via router02 that should be via router01.
  • In cases where an external host is unreachable from either an internal host or from our router, the external host is pingable from a cloud server that is not on our network.
  • Disabling IPv6 on our internal host doesn't change the situation. I had originally considered that we might be getting AAAA records for public hosts, and our internal hosts trying to use IPv6 when we don't yet have it fully deployed at the router.
Any insight into why I might have problems connecting to certain external hosts would be appreciated. Also, if there's anything I've configured that is bad network design, please let me know that as well, so I can improve the config in general.
Many thanks for any suggestions or advice.
first of all, looking at the output you posted, what IP addresses does the NAT pool consist of ? Are these 10 public IP addresses assigned to your organization ?
Intermittent side access is often related to MTU settings. You might want to try and lower the MTU settings to e.g. 'ip mtu 1400' and 'ip tcp adjust-mss 1360' on your outgoing interfaces. Do you have an example of one of the 'problem' sites ?
ip nat outside
shutdown
ip nat outside
PlanetRocker
need to someone expert
to suggest a 5g router with phone support
for home use
