Routing question ...
asmith
Level 2
Level 2
I have found out that our 3885, won't play with 3662 due to IOS version differences, but i can't upgrade 3662, until i get rid of ACC router, as it can't due rip-2... question is this, whay can't stores that are connected to 3885 (which is in corporate hq and attached to lan) ping or connect to any of the servers on the coporate lan? which is 172.16.1.0/24
here is config on 3885:
Current configuration : 5245 bytes
version 12.3
service password-encryption
hostname 3885_HQ
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable password 7
username cisco privilege 15
no network-clock-participate slot 1
network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
ip domain name yourdomain.com
no ftp-server write-enable
voice-card 0
codec complexity high
no dspfarm
controller T1 0/0/0
framing esf
linecode b8zs
ds0-group 0 timeslots 1-24 type e&m-wink-start
controller T1 0/0/1
framing esf
linecode b8zs
channel-group 0 timeslots 1-24 speed 64
interface GigabitEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-GE 0/0$
ip address 172.16.1.8 255.255.255.0
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/0/1:0
no ip address
encapsulation frame-relay
frame-relay traffic-shaping
interface Serial0/0/1:0.11 point-to-point
ip address 10.1.50.1 255.255.255.252
frame-relay interface-dlci 50
class map_vofr
vofr data 4 call-control 5
interface Serial0/0/1:0.12 point-to-point
ip address 10.1.52.1 255.255.255.252
frame-relay interface-dlci 52
class map_vofr
interface Serial0/0/1:0.13 point-to-point
ip address 10.1.55.1 255.255.255.252
frame-relay interface-dlci 55
class map_vofr
interface Serial0/0/1:0.14 point-to-point
ip address 10.1.56.1 255.255.255.252
frame-relay interface-dlci 56
class map_vofr
interface Serial0/0/1:0.15 point-to-point
ip address 10.1.58.1 255.255.255.252
frame-relay interface-dlci 58
class map_vofr
interface Serial0/0/1:0.16 point-to-point
ip address 10.1.59.1 255.255.255.252
frame-relay interface-dlci 59
class map_vofr
interface Serial0/0/1:0.17 point-to-point
ip address 10.1.60.1 255.255.255.252
frame-relay interface-dlci 60
class map_vofr
interface Serial0/0/1:0.18 point-to-point
ip address 10.0.70.1 255.255.255.252
frame-relay interface-dlci 70
class map_vofr
interface FastEthernet1/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/1
no ip address
shutdown
duplex auto
speed auto
router eigrp 101
redistribute static
redistribute rip
network 10.0.0.0
default-metric 1000 100 255 1 1500
no auto-summary
no eigrp log-neighbor-changes
router rip
version 1
redistribute eigrp 101
network 10.0.0.0
network 172.16.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.1.23
ip http server
ip http authentication local
ip http secure-server
map-class frame-relay map_vofr
frame-relay cir 64000
frame-relay bc 640
frame-relay mincir 64000
frame-relay voice bandwidth 16000
frame-relay fragment 80
frame-relay fair-queue
snmp-server community public RO
snmp-server community private RW
control-plane
line con 0
password 7
login
stopbits 1
line aux 0
stopbits 1
line vty 0 4
privilege level 15
password 7
login
transport input telnet ssh
line vty 5 15
privilege level 15
password 7
login
scheduler allocate 20000 1000
end
3885_HQ#
Richard Burts
Al
There are a few aspects of your question that I do not understand. You mention a 3662 but never give any information about it. You ask about a problem where stores can not access resources in the corporate LAN but you do not give any specifics about where the stores are connected or what is at the store end of the connection.
My first guess at the problem would be that either the stores do not have a route to get to the corporate LAN or the 3885 does not have a route to get back to the stores. (I notice that the 3885 has a default route pointing out the LAN interface, so the 3885 would have to have learned routes to the stores networks or subnets.) So can you post the output of show ip route from the 3885 and point out whether it does or does not have routes to the stores. And can you check from the stores end whether they have routes to the corporate LAN?
I do notice that under router rip you are redistributing eigrp 101 but do not have a default metric configured, so this redistribution will not work. But I am not sure that this is part of the problem that you are asking about.
Rick
Rick
