routing two LANs
AlexTottman2015
Hi everyone,
I can't seem to send packets across my network. I have WAN set up and traffic within each LAN works but can't seem to send anything across the routers. I have configured static routing and have sub interfaces set up to handle the vlans....
Can anyone advise what I might be doing wrong? I have attached the file for reference.
Thank you :-)
the multilayer switches are layer 3 switches, which effectively makes them routers. That means you need a layer 3 connection (FastEthernet0/24 to GigabitEthernet0/0), and you cannot trunk all VLANs through that single layer 3 link anymore.
I have revised your topology. I also removed all static routes and RIP, and replaced it with OSPF.
Jaderson Pessoa
Yours L3 devices, doesn`t have a route between their routers. I suggest you to include them in ospf process or use a default route for it.
Jaderson Pessoa
*** Rate All Helpful Responses ***
luis_cordova
Hi @AlexTottman2015 ,
As option B:
In router0:
-Remove all subinterfaces, except one (the g0/0.10, for example).
This subinterface will communicate with the L3 switch
-Remove the static route
-Eliminates protocol  ospf 10
-In the RIP protocol, leave only the 172.16.0.0 enabled
In router1:
-Remove all subinterfaces, except one (the g0/0.50, for example).
-In the RIP protocol:
Router(config)#router rip
Router(config-router)#version 2
Router(config-router)#no auto-summary
Router(config-router)#network 192.16.50.0
After those changes, everything works ok.
