routing with QoS
mohameddjelouah
hello we have a Lan with 2 ISP and a data center with diffrent servers we have apps on the servers so i want to route the traffic throgh isp1 to some servers and the the outhers throgh isp2 what should i do ?
i have nouther question we have a proxy server to the internet  and we have a 2mb line connection we want to give the proxy server 1mb max of traffic can we implement that on the router ??
Joseph W. Doherty
"hello we have a Lan with 2 ISP and a data center with diffrent servers we have apps on the servers so i want to route the traffic throgh isp1 to some servers and the the outhers throgh isp2 what should i do ? "
The typical answer often is to use PBR.
"i have nouther question we have a proxy server to the internet and we have a 2mb line connection we want to give the proxy server 1mb max of traffic can we implement that on the router ??"
Egress, usually yes. Ingress bandwidth management s generally problematic. (Other posters might mention you can rate-limit ingress, but downstream rate-limiting doesn't always keep ingress traffic from consuming additional bandwidth before the rate-limiter.) Also, BTW, for egress, I would suggest, if equipment's QoS supports, providing your proxy traffic a guarantee of 1 Mbps, not limit it to 1 Mbps.
Joseph W. Doherty
