SDSL router
mohammedrafiq
I have to set up VPN from Brussles to Uk over SDSL line,Please can some one suggust a small suitable router, I am thinking to buy Cisco 878 router but like to confirm.
2 Accepted Solutions
Giuseppe Larosa
Hello Mohammed,
878 it should be fine
We use several 877 with ADSL line and we implement IPSec/point to point GRE tunnels with no problem handling several IP Phones just to make an example.
Hope to help
Giuseppe
Ganesh Hariharan
If the requirement is of small end user buisness cisco 878 can be helpful as cisco 878 series routers are fixed-configuration routers that support multiple types of DSL technologies, broadband cable, and Metro Ethernet connections in small offices,They provide the performance needed to run concurrent services, including firewall, intrusion prevention, and encryption for VPNs; optional 802.11b/g for WLAN networking; and quality of service (QoS) features for optimizing voice and video applications.
Hope to Help !!
Ganesh.H
Giuseppe Larosa
Hello Mohammed,
Hope to help
Giuseppe
Ganesh Hariharan
Hope to Help !!
Ganesh.H
Thanks all ,
I have found one 1800 series in our store and will use this.
Regards.
