07-12-2019 07:03 AM
hi i am facing below issue on my wan tinterface and due to iput queue is fully utiliezed i facing hight cpu utilization in ip iput cpu,attaching output for below commands
Show tech
Show logging
show interfaces switching
show ip interface
show int stat
show stacks
show memory
show buffers input-interface <intx/x> packet
Significant interface input overrun errors
Significant interface overrun errors
Affected Interfaces:
3399089266 input errors, 0 CRC, 0 frame, 3399089266 overrun, 0 ignored
Significant interface aggregate input errors
GigabitEthernet0/0 (67.6%)
Interface input queue is full or almost full
Input queues are full or almost full on some interfaces, which could be triggered by a high packet rate or might be wedged due to a bug
GigabitEthernet0/0
Input queue: 139/75/3091881350/115930058 (size/max/drops/flushes); Total output drops: 1959267289
07-12-2019 07:25 AM
Hello Ahmad,
the following SW bug can apply to your router
CSCsi02145
Cisco IOS Software Virtual Routing and Forwarding ICMP Queue Wedge
A vulnerability within the virtual routing and forwarding (VRF) subsystem of Cisco IOS software could allow an unauthenticated, remote attacker to cause a denial of service (DoS)
condition.
The vulnerability is due to a failure to properly process malicious ICMP version 4 (ICMPv4) messages received on a VRF-enabled interface. An attacker could exploit this
vulnerability by submitting ICMPv4 messages designed to trigger the vulnerability on an affected device. When the ICMPv4 messages are processed, the packet queue of the
affected interface may not be cleared, leading to a queue wedge. When a wedge occurs, the affected device will stop processing any additional packets received on the wedged
interface.
see the following security advice
https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20150325-wedge
You may need to update the IOS to fix it.
Hope to help
Giuseppe
