Simplest Frame Relay doesn't work
kondratev
Hello!
I have a simplest FR network: 2 routers are connected through FR-switch. Configs are below:
aaa
FR-switch:
frame-relay switching
interface Serial0/0
description Router 1
no ip address
encapsulation frame-relay
no keepalive
clock rate 2000000
frame-relay lmi-type cisco
frame-relay intf-type dce
frame-relay route 202 interface Serial0/1 203
interface Serial0/1
description Router 2
no ip address
no keepalive
clock rate 2000000
frame-relay route 203 interface Serial0/0 202
aaa
Router 1:
interface Serial1/0
ip address 10.10.10.1 255.255.255.252
no keepalive
frame-relay map ip 10.10.10.2 202 broadcast
no frame-relay inverse-arp
aaa
Router 2:
interface Serial0/0
ip address 10.10.10.2 255.255.255.252
no keepalive
frame-relay map ip 10.10.10.1 203 broadcast
aaa
I see following status of FR PVC on both routers:
DLCI USAGE = LOCAL, PVC STATUS = STATIC, INTERFACE = Serial...
aaa
And I can't ping one router from another.
Could you tell me what can be the reason?
Peter Paluch
You have used the no keepalive on all your interfaces and thereby, you have deactivated the LMI completely (note that on Frame Relay interfaces, the keepalive keyword actually enables or disables the LMI). Please activate it again and give it a try.
Also, it would perhaps be useful to go for the most simple configuration, i.e. let the keepalive on, do not use static IP/DLCI mappings and let the InverseARP do its work (i.e. don't deactivate it using the no frame-relay inverse-arp). Only then, when things start to work, add the new commands as required.
Best regards,
Peter
Hi Kondratev.
Just to add onto Peter's solution.
aaa
The DLCI is showing STATIC. Normally the status should be  INACTIVE, ACTIVE, and DELETED.  STATIC means that the PVC is statically created thus no LMI/keepalive being sent.
Please see more on the link below where the engineer had a similar problem and solution.
http://www.davidsudjiman.info/2011/02/07/pvc-static-and-frame-relay-not-receiving-lmi/
HTH,
Kishore
