Site to Site Routing Issue
tung
We have two offices. Two sites connect via IPSEC Tunnel and MPLS for backup. We have an outsource apps server locate at their location. On our WAN-01 router we have a static route to 99.99.99.99 via MPLS ATM link (10.10.10.10). Trace route to 99.99.99.99 stop at 10.10.10.20 (ASA) never pass it. I looked on our WAN-02 and the route to 5.5.5.0 is via IPSEC tunnel. Would this be a problem? From my machine I can access any share or server to the remote location but why my outsource apps doesn't work? This was working fine before we switched to IPSEC Tunnel.
Hello Tung,
if you want to have also the traffic to/from the server 99.99.99.99 to over the tunnel you need to extend the ACLs that define what has to be encrypted:
for example you could add a second line on the ACL
access-list 100 permit ip siteA.source.net wildcard host 99.99.99.99
and a mirrored line on WAN2 acl
access-list 100 permit ip host 99.99.99.99 siteA.source.net wildcard
if you so this you should be able to carry also this traffic over the IPSEC vpn
Hope to help
Giuseppe
7 Replies 7
Giuseppe Larosa
Hello Tung,
not everything is clear from your description and picture:
you say that WAN02 LAN interface has ip address 172.16.100.10 then in the picture there is a switch and then we ASA interface with ip 10.10.10.20
Is the switch a L3 switch connecting on one side to WAn2 Lan and on the other side to ASA ?
Where is terminated the IPSEc tunnel on WAN2 or on the ASA ?
May you post the config of the ipsec tunnel ?
Hope to help
Giuseppe
Site A Config
crypto isakmp key cisco address 192.168.10.10
crypto ipsec transform-set trans esp-3des esp-sha-hmac
crypto map vpn local-address FastEthernet0/1
crypto map vpn 10 ipsec-isakmp
description IPSEC to Site_B
set peer 192.168.10.10
set transform-set trans
match address 100
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.0.1
ip route 172.16.100.0 255.255.0.0 192.168.10.10
access-list 100 permit ip 172.16.20.0 0.0.255.255 172.16.100.0 0.0.255.255
Site B Config
crypto isakmp key cisco address 192.168.0.10
description IPSEC to Site_A
set peer 192.168.0.10
match address 100
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.10.1
ip route 172.16.50.0 255.255.0.0 192.168.0.10
access-list 100 permit ip 172.16.100.0 0.0.255.255 172.16.50.0 0.0.255.255
Hello Tung,
more clear now
the ASA needs to know a path to come back.
if the net 5.5.5.0 is the source from which you try to connect/ping to 99.99.99.99
I don't see how the return path can be via the tunnel because it looks like you are using ipsec without a GRE tunnel
your ACL are:
and
traffic directed to 5.5.5.0 that I don't see in the picture shouldn't use the ipsec tunnel but should follow the default route via internet without any form of protection.
I would do the following:
(I suppose 5.5.5.0/24 is your return network to connect to/from server 99.99.99.99)
on WAn2 router
ip route 5.5.5.0 255.255.255.0 atm.next-hop.ip-address
so that you use on both directions the ATM backup to talk with the server 99.99.99.99
then you need to find out if ASA configuration is fine or it needs to be modified to make your setup to work correctly.
Hope to help
Giuseppe
Thanks you for you help. Will this change my traffic on site-B to route all traffic to site-A through ATM? I am assuming 5.5.5.0 is site-A internal network? The reason we use IPSEC VPN site-to-site is because it has a faster link over ATM. FYI. This was working fine on ATM before we switched to IPSEC VPN. Our IPSEC is working fine right now between two site but except this outsource apps.
Hello Tung,
Hope to help
Giuseppe
Tung
There are a couple of things in what you posted that seem strange (and perhaps problematic):
- the access list 100 specifies addresses in which it seems that 3 octets are significant (172.16.20.0, 172.16.100.0, 172.16.50.0) but the mask used of 0.0.255.255 says that only 2 octets are significant. With that mask it is only matching on 172.16.
- the access lists should be mirror images of each other, but they are not:
But if you say that the IPSec is working for most things then I must assume that these do not matter and that there is some other issue.
When I hear that some application used to work and that it stopped working when it was put through IPSec I find that frequently it is a fragmentation issue. Try putting this command on the interfaces of the routers running IPSec:
ip tcp adjust-mss 1300
give it a try and let us know if it helps.
Rick
Rick
Rick,
You are right. I modified the access to private address for security reason but forgot to flip the mask to wild mask. After I added the access-list 100 to permit 99.99.99.99 to 172.16.50.0 and same on WAN-01 then I was able to successfully trace route to 99.99.99.99 but got timeout a few hop before it arrived at 99.99.99.99. This few hops is not listed on this diagram due to complicated routing we have. Thanks
