Source & Dest NAT
mkannan_29
Dear Experts,
Need your assistance to achieve the below requirement.
We are having the MPLS link and BGP has been configured as IGP to connect the remote host.
I am connecting a remote host from my PC and doing the NAT in the router at my end. As there is no NAT allowed in the remote router.
Source IP : 192.168.100.105 to be NAT as 10.116.25.105
I am doing telnet from my pc to the remote host as below
Destination IP :  10.116.28.106 :1234 to be NAT as 192.168.101.106
Actual traffic
192.168.100.105 (10.116.25.105) --> telnet 192.168.101.106:1234 (10.116.28.106:1234)
NAT traffic
(192.168.100.105) 10.116.25.105 --> telnet (192.168.101.106:1234) 10.116.28.106:1234
The required route has been configured.
I have tested the connectivity by doing the source nat as below and successfully connected the remote host
ip nat inside source static 192.168.100.105 10.116.25.105
doing telnet from my host as telnet 10.116.28.106 : 1234
I am unable to do the nat for the destination IP and request your advice on the same.
regards,
M.K
Inside Source IP : 192.168.100.105 to be NAT as 10.116.25.105
Outside Destination IP :  10.116.28.106 :1234 to be NAT as 192.168.101.106
In order to ease the explanation I will name the phisical interfaces INSIDE and OUTSIDE
int
ip nat inside
int
ip nat outside
ip nat outside source static 10.116.28.106 192.168.101.106
ip route 192.168.101.106 255.255.255.255 OUTSIDE
When a packet is received on the INSIDE interface before NATing the router will check the routing table.
Beside this,
      your internal LAN should route 192.168.101.106 toward Inside interface of this equipment
     external network should route 10.116.28.106 toward Outside interface of this equipment
Dan
7 Replies 7
Hi ,
Could you provide show ip route from your equipment ?
Dan
please find the route configured in the device
ip route 10.116.25.105 255.255.255.255 Null0
ip route 192.168.100.105 255.255.255.255 192.168.106.101
192.168.106.101 --> g/w (L3 device)
192.168.106.102 --> LAN IP of the router
Can you try :
Also I do not think that you need :
The thing is the when the packet hits the ïp nat inside interface it will do first routing and then NAT, thats why you need the static route.
What about the 10.116.28.106 prefix ? It is not present in the rt ?
Dan
Dan,
request you to provide the information in detail. I am not getting it clearly.
int
ip nat inside
int
ip nat outside
Beside this,
Dan
Hi Dan,
Thanks for the detailed information. Last week completed the configuration successfully.
Thanks for your support on the same.
Also request your help to configure different type of NATs in CISCO ASA Firewall.
M.K
My pleasure , MK.
If you have an issue with ASA's NAT, or anyother issue do not hesitate to post it.
Dan
