Starting Configuration
linkdeath
I'm not asking a question here per se, but I wanted to use your brains, if I might. I'm configuring a 1721 for use as a T1 router for a single network. The T1 line doesn't get installed until Wednesday, so I don't know the IP or subnet for the Serial0 interface yet. However, using this as simply a router for the network to be able to access the internet, does this config look okay? Or am I missing something I should be looking at still? As I said, this is my first config from scratch, so I want to make sure I get it right. Thanks!
Using 856 out of 29688 bytes
version 12.4
hostname <hostname>
boot-start-marker
boot-end-marker
enable secret 5 $1$085A$cXa1VeAWdTIK3Svp8GRXl/
enable password xxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
interface FastEthernet0
ip address 192.168.111.1 255.255.255.0
speed auto
full-duplex
interface Serial0
no ip address
encapsulation ppp
shutdown
no fair-queue
router rip
redistribute connected
network 192.168.111.0
ip classless
no ip http server
dialer-list 1 protocol ip permit
snmp-server community public RO
control-plane
line con 0
line aux 0
line vty 0 4
password xxxx
login
end
Harold Ritter
You probably want to add a default route pointing at se0 as follow:
ip route 0.0.0.0 0.0.0.0 se0
If this is to access the Internet and the want to use a private network number (192.168.111.0/24) you will need to configure NAT.
Hope this helps,
