Hi All, I don’t post very often but I take a keen interest in you posts, discussions and the occasional rant and I come to you in need of help.
This is the setup I’m trying to achieve.
I would like to be able to access the Broadband routers GUI interface located at 192.168.103.254 via a remote workstation somewhere on the internet. I have setup the Static NAT to present traffic to the Broadband Routers as if it is coming from the .123 address otherwise traffic wouldn’t make it back, then a Static NAT entry to push it back out the WAN port. All of this is hypothetical at this stage as it doesn’t actually work.
I’ve set up my configuration as follows, it doesn’t work.
interface FastEthernet0/0
description Internal Port 0/0
no ip address
ip nat inside
interface FastEthernet0/0.3
encapsulation dot1Q 3
ip address 192.168.103.123 255.255.255.0
ip nat inside
interface ATM0/0/0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
interface Dialer0
description DSL Link to WAN
ip address negotiated
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat outside
ip virtual-reassembly
encapsulation ppp
ip tcp adjust-mss 1452
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
ppp authentication chap callin
ppp chap hostname bob@boboff.com
ppp chap password 0 Uggleboogly
no cdp enable
ip nat service enable-sym-port
ip nat inside source list BOB interface Dialer0 overload
ip nat inside source static tcp 82.69.245.230 8083 192.168.103.254 80 extendable
ip nat outside source static tcp 192.168.103.123 80 82.69.245.230 8083 extendable
ip route 0.0.0.0 0.0.0.0 Dialer0
ip access-list extended BOB
permit ip any any
I’ve removed all security measures to get it working, then ill add ACL’s etc. back in, hence the permit all etc.
Anyone got any ideas?
