Static NAT resolution problem
shahid_duet
Dear boss
Please see my attachment.
I want to do static NAT  203.88.148.85 ->172.29.1.5 and 192.168.0.241->172.29.1.5
That means all outsider will get mail server by 203.88.148.85 and local user will get mail server by 192.168.0.241.
For that i did :
router :
interface GigabitEthernet0/0
ip address 203.88.148.84 255.255.255.248
ip nat outside
interface GigabitEthernet0/1
ip address 10.0.0.1 255.255.255.252
ip nat inside
ip route 0.0.0.0 0.0.0.0 203.88.148.81
ip route 172.29.1.0 255.255.255.0 10.0.0.2
ip route 192.168.0.0 255.255.255.0 10.0.0.2
ip nat pool IP_POOL 203.88.148.84 203.88.148.86 netmask 255.255.255.252
ip nat inside source list 1 pool IP_POOL overload
ip nat inside source static 172.29.1.5 203.88.148.85
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 172.29.1.0 0.0.0.255
ASA:
nameif inside
security-level 100
ip address 192.168.0.240 255.255.255.0
nameif outside
security-level 0
ip address 10.0.0.2 255.255.255.252
interface GigabitEthernet0/2
nameif DMZ
security-level 50
ip address 172.29.1.1 255.255.255.0
access-list OUTSIDE-IN extended permit ip any 172.29.1.0 255.255.255.0
static (DMZ,outside) 172.29.1.5 172.29.1.5 netmask 255.255.255.255
access-group OUTSIDE-IN in interface outside
route outside 0.0.0.0 0.0.0.0 10.0.0.1 1
But i cant get 203.88.148.85 from internet and 203.88.148.81 from 172.29.1.5. same in case of local net.
what can i do now ? where my missing ?
can u help me  plz .
thanks
shahid
2 Accepted Solutions
cadet alain
on ASA:
disable nat-control with no nat-control
remove the static nat for dmz,outside on asa and change ACL to permit ip any 172.16.29.5
do a static'(dmz,inside) for tcp port 25 and put an ACL o enable return traffic from dmz to inside
On router change nat to this:
ip nat pool IP_POOL 203.88.148.84 203.88.148.84 netmask 255.255.255.252
ip nat inside source static tcp  172.29.1.5 25 203.88.148.85 25
Regards.
Alain.
Yes I understand but it's been a while since I've configured ASA so I had to think it over.
Per default ICMP is not inspected so you need to modify your ACL to permit return echo-replies or   enable icmp inspection like this:
policy-map global_policy
  class inspection_default
    inspect icmp
NB: return traffic from dmz to inside is permitted by default for tcp and udp so I think this should work without the ACL and just inspecting icmp so your pings to the server will work and smtp also.
Regards.
Alain.
12 Replies 12
cadet alain
on ASA:
Regards.
Alain.
Hi Alain
U r correct.
clould u pls diffentiate between
ip nat inside source static tcp and ip nat inside source static.
Now tell me how i NAT my local IP 192.168.0.241 to 172.29.1.5 on ASA ?
how PC 192.168.0.10  will get 172.29.1.5 by nating 192.168.0.241 ?
Plz help me
shahid
ip nat inside source static tcp and ip nat inside source static.:
the first one is called static PAT and second is static NAT which means in second case you are doing a 1-1 nat of all your ports where in the other case is only for a certain tcp port.
to map the mail server for inside access:
static (dmz,inside) tcp 192.168.0.241 25 172.29.1.5 25 netmask 255.255.255.255
Don't forget to add an ACL permitting traffic back from dmz:
access-list MAILSERVER_DMZTOINSIDE 10 extended permit tcp 192.168.0.241 255.255.255.0 25 192.168.0.0 255.255.255.0 any
access-group MAILSERVER_DMZTOINSIDE  out interface inside
Regards.
Alain.
Mr. Alain
Thanks again
pls see my new diagram.
Now i m getting 192.168.0.241 as NAT from My local net ie 192.168.0.0/24.
but i need access from my branch ie 192.168.11.0/24, 12.0/24,13.0/24, etc. as i did
access-list MAILSERVER_DMZTOINSIDE extended permit tcp host 192.168.0.241 eq smtp  192.168.0.0 255.255.0.0
route local 192.168.0.0 255.255.0.0 192.168.0.254  on ASA.
I get form asa to 192.168.11.5 but dont get 192.168.0.241 from 192.168.11.5.
how i get 192.168.0.241 from 192.168.11.5 ? any route requited in core router ?
NB: there are a route for 192.168.0.0/24 on branch router.
shahid
So the part you asked for is working now?
but you want the branch sites to communicate with this server, is that so? your remote sites are all using VPN? in that case which type, IPsec site-to-site VPN?
Regards.
Alain.
alain
Yes its working  with Local Net but not branch.
I m using VPN and 192.168.0.0/24 is allowed through site to site IPsec crypto map VPN, as i m getting 192.168.0.243 from branch.
I want to communicate mail server from branch.
How  ?
shahid
Hi alain
do u understand my diagram ?
If not clear let meknow .
    inspect icmp
Regards.
Alain.
Thanks boss
u r great
Dear Alian
I need ur help again
now i m using asa5510.
I get local to sever but not get server to local.
waht can i do now ?
shahid
rais
Level 7
Level 7
From my part of the world I get:
>ping 203.88.148.85
Pinging 203.88.148.85 with 32 bytes of data:
Reply from 111.93.72.94: TTL expired in transit.
Ping statistics for 203.88.148.85:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Same results using: http://www.as577.net/en/page/lg.html
There seems to be a routing loop.
Thanks.
yep,
tracerouting to your next-hop router from ISP is revealing a loop between 2 SP.
Regards.
Alain.
