Static route forwarding address
ateeqs.net
Level 2
Level 2
Hi Expert,
Please help me to understand of using forwarding address of static route after determining the interface
example:
ip route xx.xx.xx.xx 255.255.255.0 GigabitEthernet0/0 x.x.x.x name DO_NOT_ADVERTISE_TO_MPLS
thanks for assistance.
John Blakley
You usually do this for multiaccess interfaces in order to explicitly tell the router what the interface is and the next hop for the route. The next hop after the interface has to be directly connected to the interface that you specify. They're called "fully specified static routes".
HTH,
John
HTH, John *** Please rate all useful posts ***
