Static Routing Help
cdc9850
Community Member
Hello everyone,
I am having difficulty with coming up with the correct ip route command to implement on each of the routers in order for the network on router 2 to be able to communicate with the vlans on switches 0 and 1.
Router 0:
f0/0 - 200.200.201.254 255.255.255.0
f0/1 - 200.200.202.254 255.255.255.0
Router 1:
f0/0 - 200.200.202.253 255.255.255.0
f0/1 - 200.200.203.254 255.255.255.0
Switch 0 & 1:
3 VLANs
f0/24 - trunk
Router 2:
f0/0 - 200.200.204.254 255.255.255.0
f0/1 - 200.200.205.254 255.255.255.0
Hello
Please review working PT file, Look at the static routes and the routed interfaces on the rtrs.
Kind Regards
Paul
Hello
You show 3 vlans but 4 subnets, Also rtr 0/ or rtr1 has no transit path to rtr 2
If this is a PT lab can you post the PT file please.
Kind Regards
Paul
 I cannot upload .ptk files for some reason so I made it a google link:
https://drive.google.com/file/d/1tudmQKWypDYiRvizUnyI89BqkC9_eMc1/view?usp=sharing
PCs 0-5 are split on the 3 vlans and I'm trying to get PCs 6-8 to be able to ping the rest, that's why I have 4 subnets
Hello
Kind Regards
Paul
Wow thank you so much!
