Strange Log
Tofik Mardianto
Please Kindly Help,
I'm facing the one of strange log in my l3 switch devices that impact is made which connection through to that switch is going down. Please, someone explain to me about this issue and how to fix it.
Captured log as below :
025210: Jan 8 13:24:35.148 JAVT: %SYS-2-NOBLOCK: idle with blocking disabled. -Process= "hpm main process", ipl= 0, pid= 114
-Traceback= 1F0D4D8 13604DC 18F77DC 1975EDC 19760C0 196F7A0 1987568 1988A54 1999B88 19B30C8 19B0B50 19B0A88 197CB80 1BFEAA8 1BFF354 10BDBB0
025211: Jan 8 13:24:36.155 JAVT: %SYS-2-BLOCKHUNG: Task hung with blocking disabled, value = 0x1. -Process= "hpm main process", ipl= 0, pid= 114
-Traceback= 1F0D518 13604DC 18F77DC 1975EDC 19760C0 196F7A0 1987568 1988A54 1999B88 19B30C8 19B0B50 19B0A88 197CB80 1BFEAA8 1BFF354 10BDBB0
Thank you for your kindly help
Best Regards,
Tofik Mardianto
Network Engineer
Yes, it is the recommended release for your platform. The recommended release is typically chosen based on the number of revisions it has received. Fro this you ca infer it should have the most number of resolved caveats and least number of bugs.
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
Anytime you see 'traceback' in your logs you should be considered. A process has crashed and is dumping i a stack trace to the log you could debug it... in reality you will not be able to without the help of TAC and instead these memory will reality unclaimed and lead to a memory leak.
There are several published bugs relating to 'hpm main process' . What platform and software version are you running?
cheers,
Seb.
Device model : WS-C3750X-24T-E
Software version : 12.2(55)SE8
Thank you
Could be:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvb65187
...personally I would upgrade the switch to the recommended release 15.2(4)E7:
https://software.cisco.com/download/home/284655156/type/280805680/release/15.2.4E7
cheers,
Seb.
Thank you for your explanation and your advice.
i have a question.
is it the stable one software version for WS-C3750X-24T-E?
Thank you
cheers,
Seb.
