Subnet mask problem
xhackuss1
hi Folks,
I have this situation where a customer has this addressing.
The customer has subnetted 192.168.1.0 network as follows.
192.168.1.48/28 and 192.168.1.64/28.
the problem is,now they want to match the IP range of 192.168.1.80 to 192.168.1.254 in an access-list. So my problem is, what subnet mask will match the remaining range of 192.168.1.80 to 192.168.1.254 after the initial /28 subnetting ?
Giuseppe Larosa
Hello Yahaya,
being an ACL you can use multiple lines to be able to cover the required address range.
So the answer is multiple ACL lines:
192.168.1.128 0.0.0.127 matches 192.168.1.128-192.168.1.255
192.168.1.80 0.0.0.15 matches 192.168.1.80-192.168.1.95
192.168.1.96 0.0.0.31 matches 192.168.1.96-192.168.127
you need to see every acl line as made of three using the three blocks.
Hope to help
Giuseppe
