Switch Routing Traffic Ignoring Firewall Rule
Wildcard
I have an issue that has been narrowed down to the switch because traffic is filtered by the firewall within the LAN without the use of the switch. It's a CBS350 and it is routing traffic on it's own within the LAN without ever reaching the firewall rule that I have setup to disallow traffic from Dispatch to Accounting. Traffic comes from dispatch, reaches the switch, and then is routed to accounting. I ran the no ip routing command. But LAN traffic from dispatch to accounting is still not being filtered by the firewall, a Sophos XGS87, which is also acting as the router. Any ideas on how to resolve this issue?
have you disabled/deleted the respective IPv4 Interfaces in the 'IPv4 Configuration' tab ?
Wildcard
There are none. The only thing there is this. It's the static IP address of the switch to SSH in.
