%SYS-3-LOGGER FLUSHING: System pausing to ensure console debugging output
marouf.walid
Visitor
Hello
We have a router with this log message: %SYS-3-LOGGER FLUSHING: System pausing to ensure console debugging output
He's not operationel, cause he block when he boot.
here is the Console and where he block when we reboot it;
System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
Cat6k-Sup720/RP platform with 524288 Kbytes of main memory
System Bootstrap, Version 8.4(2) Release
Copyright (c) 1994-2005 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot: failed, BOOT string is empty
Autoboot executing command: "boot "
Initializing ATA monitor library...
string is bootdisk:s72033-ipservicesk9_wan-mz.122-33.SRA2.bin
Loading image, please wait ...
Self extracting the image... [OK]
Self decompressing the image : ################################################################################################################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, s72033_sp Software (s72033_sp-IPSERVICESK9_WAN-M), Version 12.2(33)SRA2, RELEASE SOFTWARE (fc4)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Thu 30-Nov-06 14:31 by prod_rel_team
Image text-base: 0x401012FC, data-base: 0x41608000
Active crashed three times, disabling auto-boot and dropping to rommon
%Software-forced reload
12:24:40 UTC Sun Jan 3 2016: Breakpoint exception, CPU signal 23, PC = 0x403043C0
Possible software fault. Upon reccurence, please collect
crashinfo, "show tech" and contact Cisco Technical Support.
-Traceback= 403043C0 40301FA0 40AD777C 40ADA708 40AC9710 40AC8A54 402A5A18 402A5A04
$0 : 00000000, AT : 41A80000, v0 : 42680000, v1 : 42120000
a0 : 502B673C, a1 : 41A82740, a2 : 41640000, a3 : 41630000
t0 : 402F7C78, t1 : 3400FF01, t2 : 402F7C78, t3 : FFFF00FF
t4 : 402F7C78, t5 : 50C18978, t6 : 00000000, t7 : 50C18970
s0 : 00000000, s1 : 41640000, s2 : 00000000, s3 : 00000000
s4 : 42F50000, s5 : 00000000, s6 : 41450000, s7 : 41450000
t8 : 50C189D0, t9 : 402DF144, k0 : 8300CF60, k1 : 04749E00
gp : 41A80660, sp : 43AED2C8, s8 : 42680000, ra : 40301FA0
EPC : 403043C0, ErrorEPC : 00428897, SREG : 3400FF03
MDLO : 00007530, MDHI : 00000000, BadVaddr : 00000000
Cause 00000024 (Code 0x9): Breakpoint exception
File bootflash:crashinfo_20160103-122440 Device Error :No such device
=== Flushing messages (12:24:40 UTC Sun Jan 3 2016) ===
Buffered messages:
Queued messages:
00:00:05: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:05: %OIR-6-CONSOLE: Changing console ownership to switch processor
*** System received a Software forced crash ***
signal= 0x17, code= 0x24, context= 0x426811e4
PC = 0x402f7cbc, Cause = 0x1020, Status Reg = 0x34008002
rommon 1 > dir bootdisk:
Directory of bootdisk:
2 83135972 -rw- s72033-ipservicesk9_wan-mz.122-33.SRA2.bin
10151 263112 -rw- crashinfo_20070806-102701
10853 33554432 -rw- sea.log
10184 264467 -rw- crashinfo_20070806-103203
10217 6590 -rw- crashinfo_20140805-084550
10218 5643 -rw- crashinfo_20140805-085809
10219 5643 -rw- crashinfo_20140805-091023
10220 5643 -rw- crashinfo_20140805-092237
10221 5643 -rw- crashinfo_20140805-093443
10222 5643 -rw- crashinfo_20140805-094649
10223 5643 -rw- crashinfo_20140805-095903
rommon 2 > boot bootdisk:s72033-ipservicesk9_wan-mz.122-33.SRA2.bin
cisco Systems, Inc.
00:00:04: %SYS-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
00:00:04: %PFREDUN-6-STANDBY: Initializing as STANDBY processor
Mark Malone
do you have more than 1 image in flash
you could go to rommon then go to load_helper flash_init and then set the boot to pick a different image , if its a software issue this should bypass it but if its hardware it wont but at least you will know
This is why I would suggest even if you don't have another image on it I would use xmodem and stick another one on it through rommon and try bypass current image
Hello
We downloaded an other IOS Image, put it on the flash, with the help of a memory card reader,
The system boot, and the router run again.
Thanks for your help.
Regards.
glad you got it sorted 🙂
