telnet client to open multiple sessions
Arjun Dabol
I need to take similar output from more than 50 routers. ( a show run basically) . is there a telnet client where I can connect 10-15 routers in one shot and issue a show command on all of them at the same time ?
Thanks in adv
Philip D'Ath
I use the commercial SecureCRT.  It supports scripting, and a script could walk through a list of routers and do the whole lot.
You can create a "tree" of devices, like a file system.
You could also tell it to record a macro, which you can then play back.
https://www.vandyke.com/products/securecrt/
Philip D'Ath
