Terminal server | OCTAL
Ibrahim Jamil
Level 7
Level 7
Hi Netpro
from the TS how you can send one set of commands as  depicted below to routers connected through an octal cable at once
router rip
no auto
net 10.0.0.0
thanks
John Blakley
From your server prompt:
send *
router rip
no auto
net 10.0.0.0
ctrl - z
HTH,
John
HTH, John *** Please rate all useful posts ***
Hi Jhon
can y post me a doc related to TS , how to become professional with TS
thanks
Jamil,
You could start here:
http://www.cisco.com/en/US/docs/ios/11_0/access/connection/guide/xmanag.html#wp3052
You'll see closer to the end the "send *" line references all lines that are connected. You can also specify a single line to send commands to...
HTH,
John
thanks Jhon
i need to setup a cisco rack ang engage TS to console to routers and switches ,
