TFTP error code 6
waqar zaidi
Frequent Visitor
Frequent Visitor
We are getting this bizzar error messages accross the board 30 plus routers (76XX) and message time stamp is the same for all the routers meaning we get this error message around 17:55 in the evening. Cant seems to find any answer please help.
FYI..we are not trying to connect to TFTP at all. Here is the error message from one of the router.
TFTP: error code 6 received - 18025
Leo Laohoo
Duplicate post #2.
Sorry about the duplicate post. All im trying to get is the answer since I am new to this cisco discussion plz point me into the right direction so I can get some answers or suggestions.
Hi Waqar,
I did not see the other duplicate post, so will reply to this one. The root cause is likelt DDTS CSCso27298:
     "TFTP: error code 6 received" debug get'n printed w/o enabl'n tftp debug
Symptom: Error mesaage seen: error code 6.
Conditions: When you copy a file to a tftp server which already exists, this
error message appears.
Workaround: There is no workaround.
I suggest to check you release against the integrated release list for this DDTS.
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
Thanks will check.
