The unix time in statistics of netflow for nat translation on asr1001
unfraget
hi everybody,
i've issue with netflow statistics for nat translation, somehow in netflow statistics on collector appear tthe start of unix time 1970-01-01 04:00:00.000.
although the time on asr is configured correctly:
sh clock detail
10:18:02.508 MSK Fri Feb 21 2020
NAT settings
ip nat settings pap
ip nat log translations flow-export v9 udp destination 84.47.177.11 20100 source Loopback777
ip nat translation timeout 120
ip nat translation tcp-timeout 3600
ip nat translation pptp-timeout 3600
ip nat translation udp-timeout 240
ip nat translation finrst-timeout 30
ip nat translation syn-timeout 30
ip nat translation icmp-timeout 20
ip nat translation max-entries all-host 4096
no ip nat service sip tcp port 5060
no ip nat service sip udp port 5060
IOS veriosn
Cisco IOS Software, ASR1000 Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc2)
how can i fix this issue?
5 Replies 5
which Netflow collector are you using ?
we nfdump.
very interesting, i decoded tcpdump, and see that date in the netflow package  is correct
looks like the ASR is sending the correct timestamps, but somehow nfdump scambles them into something else. What does the configuration of your flow record look like ? Try and toggle the values in the two lines below:
collect timestamp absolute first
collect timestamp absolute last
tomorrow, i'll try to set sys-uptime in settings of recorder
(config-flow-record)#collect timestamp ?
absolute Timestamps based on the epoch of 00:00 UTC 1st Jan 1970
sys-uptime Timestamps based on the sys-uptime
i think that i'm should use "sys-uptime" settings
it didn't working :(
