Touble pinging a TFTP Server
jesserc68
Having touble pinging a TFTP Server
Connect a PC using the console port to a router for the perpose of UPLOADING IOS to a  TFTP Server on my PC. I connect the PC Host to a router E0/0, I config the PC with a (static IP 192.168.1.2 subnet mask 255.255.255.0  ), and Config the router with a (static IP Address 192.168.1.1 subnet mask 255.255.255.0) Configurations below However, once i try to Ping the PC Host IP Address 192.168.1.2 ,it fails, here are the config,  can anyone distinquish what is wrong!!  I used a cross-over cable to connect the router to the PC.
The Router is a Cisco 2600 platform
Thanks!!!!!!
Computer IP Config Microsoft Windows XP
[Version 5.1.2600] (C) Copyright 1985-2001 Microsoft Corp.
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix  . :
Description . . . . . . . . . . . :
Intel(R) PRO/1000 MT Network Connect ion
Physical Address. . . . . . . . . : 00-0B-DB-69-1C-0C
Dhcp Enabled. . . . . . . . . . . : No
IP Address. . . . . . . . . . . . : 192.168.1.2
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Default Gateway . . . . . . . . . :
C:
============================================================================================================= Router#sh config
Using 547 out of 29688 bytes
version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption
hostname Router
boot-start-marker boot-end-marker
memory-size iomem 10 no aaa new-model ip subnet-zero ip cef
interface Ethernet0/0
description Router connected to Host For TFTP Server, to upload IOS
half-duplex
interface Serial0/0 no ip address shutdown no fair-queue
ip http server ip classless
line con 0 line aux 0 line vty 0 4 login
end Router# ============================================================================================================ Router#ping
Protocol [ip]:
Target IP address: 192.168.1.2
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
============================================================================================================ Router#sh protocol
Global values:
Internet Protocol routing is enabled Ethernet0/0 is up, line protocol is up   I
nternet address is 192.168.1.1/24
Serial0/0 is administratively down, line protocol is down
Router#
Router#sh ip interface
Internet address is 192.168.1.1/24
Broadcast address is 255.255.255.255
Address determined by setup command
MTU is 1500 bytes
Helper address is not set
Directed broadcast forwarding is disabled
Outgoing access list is not set
Inbound  access list is not set
Proxy ARP is enabled
Local Proxy ARP is disabled
Security level is default
Split horizon is enabled
ICMP redirects are always sent
ICMP unreachables are always sent
ICMP mask replies are never sent
IP fast switching is enabled
IP fast switching on the same interface is disabled
IP Flow switching is disabled
IP CEF switching is enabled
IP CEF Fast switching turbo vector
IP multicast fast switching is enabled
IP multicast distributed fast switching is disabled
IP route-cache flags are Fast, CEF
Router Discovery is disabled
IP output packet accounting is disabled
IP access violation accounting is disabled
TCP/IP header compression is disabled
RTP/IP header compression is disabled
Policy routing is disabled
Network address translation is disabled
WCCP Redirect outbound is disabled
WCCP Redirect inbound is disabled
WCCP Redirect exclude is disabled
BGP Policy Mapping is disabled Serial0/0 is administratively down, line protocol is down
Internet protocol processing disabled
Router#
2 Accepted Solutions
johnlloyd_13
Level 9
Level 9
hi jesse,
add the default gateway 192.168.1.1 on your PC and try again.
jesse rodriguez wrote:
Thank you all, for your reply however i attempt both methods and i still can't ping the PC IP Address 192.168.1.2 here are the configs
Default Gateway . . . . . . . . . : 192.168.1.1
C:\Program Files\Microsoft Visual Studio 8\VC>
Router#ping 192.168.1.2
Router#
I'm assuming, from the post, that it's a WindoZe machine.
Do you have the Windows firewall turned off? Or at least modified to allow PING? It blocks PING by default, especially on Windows 7 (and 2008, and XP) - which means no matter how hard you try, you're not going to be able to PING your PC interface from anywhere.
Cheers
11 Replies 11
johnlloyd_13
Level 9
Level 9
hi jesse,
I would like to thank everyone for their advise an d input, it help me solve my problem. Thank you all!!! Tremendously, the solution was firewall and the full duplex, defualt gateway 192.168.1.1
Thank's
Jesse
milan.kulik
Level 10
Level 10
try to Ping the router (192.168.1.1) from the PC.
There might be a personal FW running on the PC denying the ping reply.
If not successful, check the ARP tabloe on the router by show arp command. Does it show and ARP entry fo rthe PC (
192.168.1.2)?
I'd also try to leave the duplex auto in the router port, but don't think it's the root problem.
HTH,
Milan
jesserc68
Router#
Router#ping 192.168.1.1
Type escape sequence to abort. Sending 5, 100-byte ICMP Echos to 192.168.1.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/4 ms
Router#sh arp
Protocol  Address      Age (min)  Hardware Addr  Type  Interface
Internet  192.168.1.1            -  0004.c051.2780  ARPA Ethernet0/0
Internet  192.168.1.2            2  000b.db69.1c0c  ARPA  Ethernet0/0
Router#
Router#
Router#sh config
Using 480 out of 29688 bytes ! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption .
hostname Router
interface Ethernet0/0 description connection ip address 192.168.1.1 255.255.255.0 half-duplex
line con 0 line
aux 0
line vty 0 4
end Router#
Router#
Cheers
Hi Jesse,
On the router side, do a "show interface" to check that the interface is up and the in/out packet rate. You can also use "debug ip packet" or debug icmp to see what is being received/sent. On the Windows ME side you can use Wireshark to see what was on the wire. Then, you will definetely have a clear reason of the problem.
PS: Maybe for some reason it's not responding with it's own IP address.
Hope that helps!
Vasilis
One piece of good news in a previous post is that the show arp from the router does include the MAC address of the PC. So we know that the connection is good and that the devices are talking at layer 2. Milan suggested that Jesse try to ping the router from the PC and I agree that this is a good suggestion. I do not see any evidence that Jesse has done that yet.
I agree that the most likely issue is a firewall running on the PC which frequently is configured by default to deny ping to the PC. And in my experience the firewall will also frequently deny incoming requests for TFTP. So after Jesse solves the problem with ping he may have a similar problem with TFTP.
Rick
Rick
Hi Jesse,
Checked all the FW setting as suggested by mate.
Straight cable also works. Try this may help.
BR// SS
HI,
router to pc should be crossover cable.
i seen eth0/0 in half duplex, change it to full duplex and stop window FW in computer.
and then try....
jesserc68
Thank you all !!
elepon06
You got it...
Sent from Cisco Technical Support App
