traceroute not working but ping working in cisco 891
aammar@npr.org
I am running traceroute to 8.8.8.8 but it is not working. though when I ping 8.8.8.8 but its pinging
I have done quite a research and learned that traceroute works on udp dns resolution.
Cisco 891 is configured with ZBF and udp and icmp is allowed from inside to outside but not really sure why traceroute not working. below is the configuration and please let me know whats wrong
service password-encryption
ip dhcp excluded-address 10.33.167.0 10.33.167.10
ip dhcp excluded-address 172.27.128.0 172.27.128.10
ip dhcp pool insideDHCP
import all
network 10.33.167.0 255.255.255.0
domain-name ad.npr.org
default-router 10.33.167.1
dns-server 8.8.8.8 4.2.2.2
option 43 ascii "10,62,20,10"
option 242 ascii "MCIPADD=hq-cmact,MCPORT=1719,HTTPSRVR=dc-avaya-prov01,HTTPDIR=/FW/DC/"
ip dhcp pool Guestnet
network 172.27.128.0 255.255.255.0
default-router 172.27.128.1
dns-server 209.244.0.3 8.8.8.8 4.2.2.2
no ip domain lookup
ip domain name ad.npr.org
ip cef
no ipv6 cef
vlan 10
name NAS
vlan 15
name data
vlan 20
name voice
vlan 100
name Guest_Wireless
ip ssh source-interface Vlan15
class-map type inspect match-all SNMP
match access-group 130
class-map type inspect match-any TACACS
match access-group 150
class-map type inspect match-any SELF_OUT
match protocol icmp
class-map type inspect match-all ICMP
match access-group 140
class-map type inspect match-all DHCP
match access-group 120
class-map type inspect match-any ZBF_ALLOW_ALL
match protocol ftp
match protocol ssh
match protocol udp
match protocol tcp
match protocol telnet
match protocol dns
match protocol icmp
match protocol http
match protocol https
match protocol smtp
match access-group name udp-icmp
class-map type inspect match-all SSH
match access-group name SSH
class-map type inspect match-any GUEST_ALLOW_ALL
match protocol ftp
match protocol dns
match protocol icmp
match protocol http
match protocol tcp
match protocol udp
class-map type inspect match-all NTP
match access-group name NTP
class-map type inspect match-all IPSEC
match access-group name IPSEC
class-map type inspect match-all NPR
match access-group 101
class-map type inspect match-all INSIDE_TO_GUEST
match access-group name Inside2Guest_Access
policy-map type inspect OUTSIDE_TO_INSIDE
class type inspect NPR
inspect
class class-default
drop
policy-map type inspect GUEST_TO_INSIDE
class class-default
drop log
policy-map type inspect INSIDE_TO_GUEST
class type inspect GUEST_ALLOW_ALL
inspect
class class-default
pass
policy-map type inspect Guest_TO_OUTSIDE
description Guest LAN to Internet
inspect
class class-default
pass
policy-map type inspect OUTSIDE_TO_SELF
description Permitted traffic from Internet
class type inspect DHCP
pass
class type inspect IPSEC
inspect
class type inspect SSH
inspect
class type inspect NTP
inspect
class type inspect SNMP
inspect
class type inspect ICMP
inspect
class type inspect TACACS
pass log
class class-default
drop
policy-map type inspect Guest_TO_SELF
pass
class class-default
drop
policy-map type inspect SELF_TO_OUTSIDE
description Router to Internet
class type inspect SELF_OUT
inspect
class class-default
pass
policy-map type inspect INSIDE_TO_OUTSIDE
class type inspect ZBF_ALLOW_ALL
inspect
class class-default
pass
zone security INSIDE
description Inside LAN
zone security OUTSIDE
description WAN
zone security INSIDE-Guest
zone-pair security INSIDE_TO_GUEST source INSIDE destination INSIDE-Guest
description Printer Access
service-policy type inspect INSIDE_TO_GUEST
zone-pair security INSIDE_TO_OUTSIDE source INSIDE destination OUTSIDE
description LAN to WAN
service-policy type inspect INSIDE_TO_OUTSIDE
zone-pair security OUTSIDE_TO_INSIDE source OUTSIDE destination INSIDE
description NPR to Remote Site
service-policy type inspect OUTSIDE_TO_INSIDE
zone-pair security Guest_TO_OUTSIDE source INSIDE-Guest destination OUTSIDE
description Guest to WAN
service-policy type inspect Guest_TO_OUTSIDE
zone-pair security GUEST_TO_INSIDE source INSIDE-Guest destination INSIDE
service-policy type inspect GUEST_TO_INSIDE
zone-pair security Guest_TO_SELF source INSIDE-Guest destination self
service-policy type inspect Guest_TO_SELF
zone-pair security OUTSIDE_TO_SELF source OUTSIDE destination self
description CORE to Remote Site User
service-policy type inspect OUTSIDE_TO_SELF
zone-pair security SELF_TO_OUTSIDE source self destination OUTSIDE
description Remote Site Users to CORE
service-policy type inspect SELF_TO_OUTSIDE
crypto logging session
crypto isakmp policy 1
encr 3des
authentication pre-share
group 2
crypto isakmp key aiU!yb@dzL5 address 205.153.36.207
crypto isakmp key R3m7#yUs9! address 209.144.103.186
crypto ipsec security-association lifetime seconds 120
crypto ipsec transform-set AES esp-aes esp-sha-hmac
mode tunnel
crypto map NPR_CMAP_1 1 ipsec-isakmp
description S2S Tunnel to vpn.npr.org
set peer 205.153.36.207 default
set transform-set AES
match address 100
interface FastEthernet0
description internet Access
ip address 38.32.38.34 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nbar protocol-discovery
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
zone-member security OUTSIDE
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0
switchport trunk native vlan 15
switchport trunk allowed vlan 1-1005
switchport mode trunk
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
ip address dhcp
ip flow ingress
ip flow egress
ip nat outside
shutdown
duplex auto
speed auto
interface Wlan-GigabitEthernet8
no ip address
interface wlan-ap0
description Embedded Service module interface to manage the embedded AP
no ip address
interface Vlan1
no ip address
no ip route-cache
interface Vlan15
description Inside_LAN
ip address 10.33.167.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
zone-member security INSIDE
no ip route-cache
interface Vlan20
description VoIP
ip address 10.33.168.1 255.255.255.0
ip nat inside
no ip route-cache
interface Vlan100
description Guest_Wireless
ip address 172.27.128.1 255.255.255.0
ip nat inside
zone-member security INSIDE-Guest
no ip route-cache
interface Async3
no ip address
encapsulation slip
shutdown
ip forward-protocol nd
no ip http server
no ip http secure-server
ip flow-export source Vlan15
ip flow-export version 5
ip flow-export destination 10.36.1.119 2055
ip flow-top-talkers
top 40
sort-by packets
ip nat inside source route-map NPR_RMAP_1 interface FastEthernet0 overload
ip route 0.0.0.0 0.0.0.0 38.32.38.33
ip tacacs source-interface Vlan15
ip access-list extended IPSEC
permit udp host 205.153.36.207 any eq isakmp
permit udp host 209.144.103.186 any eq isakmp
permit udp host 205.153.36.207 any eq non500-isakmp
permit udp host 209.144.103.186 any eq non500-isakmp
permit esp host 205.153.36.207 any
permit esp host 209.144.103.186 any
ip access-list extended Inside2Guest_Access
permit ip 10.33.0.0 0.0.255.255 172.27.128.0 0.0.0.255
ip access-list extended NTP
permit udp host 10.36.1.10 any eq ntp
permit udp host 10.36.1.11 any eq ntp
ip access-list extended SSH
permit tcp 10.32.0.0 0.31.255.255 any eq 22
permit tcp 172.16.0.0 0.15.255.255 any eq 22
permit tcp 10.64.0.0 0.31.255.255 any eq 22
permit tcp 10.0.0.0 0.255.255.255 any eq 22
ip sla auto discovery
ip sla 10
icmp-echo 10.36.1.119 source-interface Vlan15
verify-data
ip sla schedule 10 life forever start-time now
ip sla 20
icmp-echo 10.31.2.200 source-interface Vlan15
ip sla schedule 20 life forever start-time now
logging trap debugging
logging source-interface Vlan15
logging host 10.36.1.233
logging host 10.62.16.241
logging host 64.125.196.130
logging host 10.70.8.241
route-map NPR_RMAP_1 permit 1
match ip address 103
access-list 100 remark Encrytion Domain
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.32.0.0 0.31.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.31.0.0 0.0.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.64.0.0 0.31.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.255.4.0 0.0.0.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.253.0.0 0.0.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.44.0.0 0.0.255.255
access-list 100 permit ip 10.33.167.0 0.0.0.255 10.52.0.0 0.0.255.255
access-list 101 permit ip 10.32.0.0 0.31.255.255 10.33.167.0 0.0.0.255
access-list 101 permit ip 10.31.0.0 0.0.255.255 10.33.167.0 0.0.0.255
access-list 101 permit ip 10.64.0.0 0.31.255.255 10.33.167.0 0.0.0.255
access-list 101 permit ip 172.16.0.0 0.15.255.255 10.33.167.0 0.0.0.255
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any host-unreachable
access-list 103 deny ip 10.33.167.0 0.0.0.255 10.32.0.0 0.31.255.255
access-list 103 deny ip 10.33.167.0 0.0.0.255 10.64.0.0 0.31.255.255
access-list 103 deny ip 10.33.167.0 0.0.0.255 10.31.0.0 0.0.255.255
access-list 103 remark 5 NAT Route MAP
access-list 103 deny ip 10.33.167.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 103 deny ip 10.33.167.0 0.0.0.255 10.255.4.0 0.0.0.255
access-list 103 deny ip 10.33.167.0 0.0.0.255 10.253.0.0 0.0.255.255
access-list 103 permit ip 10.33.167.0 0.0.0.255 any
access-list 103 permit ip 172.27.128.0 0.0.0.255 any
access-list 110 permit ip 205.153.36.0 0.0.0.255 any
access-list 110 permit ip 10.0.0.0 0.255.255.255 any
access-list 120 remark DHCP
access-list 120 permit udp any any eq bootpc
access-list 120 permit udp any any eq bootps
access-list 130 remark SNMP
access-list 130 permit udp host 10.36.1.119 any eq snmp
access-list 140 permit icmp any any echo
access-list 140 permit icmp any any echo-reply
access-list 140 permit icmp any any traceroute
access-list 150 remark TACACS
access-list 150 permit ip host 10.62.24.10 any
access-list 150 permit ip host 10.62.24.11 any
access-list 150 permit ip 205.153.36.0 0.0.0.255 any
access-list 160 permit ip 10.0.0.0 0.255.255.255 any
access-list 160 permit ip 172.16.0.0 0.15.255.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
10 Replies 10
Seb Rupik
Hi there,
Try adding the following to your ICMP ACL:
access-list 140 permit icmp any any time-exceeded
access-list 140 permit icmp any any host-unreachable
cheers,
Seb.
I have tried this but it didn't work
Helo,
from where are you initiating the traceroute ? Windows or Mac, or from the router itself ?
from the router itself as I have access to only onsite router, switch and AP remotely
you need to add icmp host-unreachable and icmp time-exceeded as below. First, add this to your config:
ip access-list extended UDP_ICMP_ACL
class-map type inspect match-any UDP_ICMP_CM
match access-group name UDP_ICMP_ACL
And then add the class type to your policy map:
inspect
class type inspect UDP_ICMP_CM
pass
class class-default
I have added the mentioned access list, class map and attached it to the policy map INSIDE_TO_OUTSIDE but still it didn't work. Also as an experiment I have added the class map to policy map SELF_TO_OUTSIDE but no use.
inspect
class class-default
drop
class class-default
drop log
inspect
class class-default
pass
inspect
class class-default
pass
pass
inspect
inspect
inspect
inspect
inspect
pass log
class class-default
drop
pass
class class-default
drop
inspect
class class-default
pass
inspect
pass
class class-default
pass
Chicago-Temp-891FW#sh run | s access-list
from what I can tell from the previous config you posted, the icmp host unreachable and time exceeeded are alreay matched in access list 101:
Remove these two entries from access list 101 and make sure they are not matched anywhere else with an 'inspect'...
I tried that but no use.
even we have configured ACL, class map and policy map, could it be related to firmware?
post the current config with the changes you have implemented...
this is another router 891 config and I have added the commands here. please check
ip dhcp excluded-address 10.33.135.0 10.33.135.10
ip dhcp excluded-address 10.33.135.200 10.33.135.254
ip dhcp pool inside
import all
network 10.33.135.0 255.255.255.0
default-router 10.33.135.1
dns-server 10.36.1.10 10.36.1.11
option 242 ascii "MCIPADD=hq-cmact,MCPORT=1719,HTTPSRVR=dc-avaya-prov01,HTTPDIR=/FW/DC/,L2QVLAN=1"
ip dhcp pool GuestNet
dns-server 209.244.0.3 4.2.2.1 8.8.4.4
no ip domain lookup
ip cef
no ipv6 cef
license udi pid C891FW-A-K9 sn FTX183985F7
vtp mode transparent
username admin privilege 15 password 7 022E544F0F031928406E070917
username itnetwork privilege 15 password 7 01310F16622B0806651C5B19390B07004A4D
vlan 100
name Guest
lldp run
match protocol icmp
match protocol ftp
match protocol ssh
match protocol udp
match protocol tcp
match protocol dns
match protocol icmp
match protocol http
match protocol smtp
match protocol ftp
match protocol dns
match protocol icmp
match protocol http
match protocol tcp
match protocol udp
inspect
class class-default
drop
class class-default
drop log
inspect
class class-default
pass
inspect
class class-default
pass
pass
inspect
inspect
inspect
inspect
inspect
pass log
class class-default
drop
pass
class class-default
drop
inspect
class class-default
pass
inspect
pass
class class-default
pass
description WAN
encr 3des
group 2
mode tunnel
match address 100
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
description Facing the ISP (the WAN)
ip address dhcp
ip flow ingress
ip flow egress
ip nat outside
duplex auto
speed auto
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
switchport trunk allowed vlan 1,10,20,100,1002-1005
no ip address
interface wlan-ap0
ip unnumbered Vlan1
interface Vlan1
ip address 10.33.135.1 255.255.255.0
ip nat inside
no ip route-cache
interface Async3
no ip address
encapsulation slip
no ip http server
ip flow-top-talkers
top 40
sort-by packets
ip access-list extended trace-list
permit ip any any
ip sla 10
icmp-echo 10.36.1.10 source-interface Vlan1
ip sla 20
no cdp run
access-list 100 permit ip 10.33.135.0 0.0.0.255 10.32.0.0 0.31.255.255
access-list 100 permit ip 10.33.135.0 0.0.0.255 10.31.0.0 0.0.255.255
access-list 100 permit ip 10.33.135.0 0.0.0.255 10.64.0.0 0.31.255.255
access-list 100 permit ip 10.33.135.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 101 remark NPR Networks
access-list 101 permit ip 10.32.0.0 0.31.255.255 10.33.135.0 0.0.0.255
access-list 101 permit ip 10.31.0.0 0.0.255.255 10.33.135.0 0.0.0.255
access-list 101 permit ip 10.64.0.0 0.31.255.255 10.33.135.0 0.0.0.255
access-list 101 permit ip 172.16.0.0 0.15.255.255 10.33.135.0 0.0.0.255
access-list 103 deny ip 10.33.135.0 0.0.0.255 10.32.0.0 0.31.255.255
access-list 103 deny ip 10.33.135.0 0.0.0.255 10.64.0.0 0.31.255.255
access-list 103 deny ip 10.33.135.0 0.0.0.255 10.31.0.0 0.0.255.255
access-list 103 deny ip 10.33.135.0 0.0.0.255 172.16.0.0 0.15.255.255
access-list 103 permit ip 10.33.135.0 0.0.0.255 any
access-list 140 remark ICMP
access-list 140 permit icmp host 10.36.1.119 any echo-reply
access-list 140 permit icmp host 10.31.2.200 any echo
access-list 140 permit icmp 10.0.0.0 0.255.255.255 any echo
access-list 140 permit icmp 10.0.0.0 0.255.255.255 any echo-reply
