Traceroute Question
What this command output means?
er-plcgua1#traceroute 167.175.231.235
Tracing the route to stosis50.pdvsa.com (167.175.231.235)
1 200.1.147.154 12 msec
200.1.147.162 4 msec
200.1.147.154 4 msec
2 167.175.48.178 12 msec 12 msec 28 msec
3 stosis50.pdvsa.com (167.175.231.235) 20 msec 12 msec 28 msec
er-plcgua1#
I have 3 routes on number 1 does it mean that my packet goes to both routes before next hop number 2?
This is a ATM PVC 200.1.147.154
this is a Atm pvc 200.1.147.162 to the same destination but less bandwith
Thanks a lot
Richard Burts
Leonardo
This output shows that the router considers both paths as equally valid and equally attractive ways to reach destination 167.175.231.235. So the router is load sharing the traffic in which the first probe packet is sent out the interface connected to 200.1.147.154 and the second packet is sent out the interface connected to 200.1.147.162 and the third packet is sent out the interface connected to 200.1.147.154. You should be able to verify this by doing show ip route 167.175.231.235. I would expect the output to show that the routing table has 2 entries of how to reach that destination.
Rick
Rick
