Track command on C857
khader1977
Dear all,
I have a Cisco C857 router and i am unable to use the track command. is there any thing need to be done I tried and upgraded the router and checked still the command is not available. I can see only advance security software in the image selection.
Thanks and Regards,
Jeelany
khader1977
Is there any other way that we can track interfaces on C857 routers.
wzhang
Unfortunately, the Enhanced Object Tracking feature is not available on the 85x series routers, you'd need to upgrade to the 87x series to get this feature support. I hope this helps.
Wen
