Trunk Port Switch to Switch
IrfanKhan4904
On a switch-to-switch interface, can we configure both of these commands at the same time, or can we only configure one of them?
switchport mode trunk
switchport trunk allowed vlan all
interface GigabitEthernet1/1/3
description ****Uplink-Block-Switch
Here is an example using only the selected vlans
switchport trunk allowed vlan 1,11,12
Giuseppe Larosa
Hello @IrfanKhan4904 ,
in cisco switches the command
is the default when you configure a port as a trunk
so it is enogh to use
int gi1/1/3
on both sides of the link
using a port-channel if possible is recommended. in case LACP is far better then uncondtional ( mode on)
Hope to help
Giuseppe
You can use commands but I prefer allow some of vlan not all
MHM
