tunneling vrf in gre tunnels
carl_townshend
Hi All
If you want to tunnel vrf's across an mpls with ipsec encryption between my ce routers
what is the best way to do this?
I have seen docs where you run mpls on the tunnel interfaces, is this required?
what would be the easiest way?
dc410
Are you saying you are the customer or the provider?
Maybe a bit more information could help.
