Two ISP One Inside Server With NAT public
RonnieBillate
Hi Everyone,
I would like seek an assistance with regards designing a redundant ISP in a data center. I already simulate this in a simulation gns3 and it didn't work. I hope can someone suggest or recommend a design.
1. I have a two ISP
2. The design has a 2 VRRP Firewall
3. The firewall has a NAT configuration.
4. The server was static NAT also in a ISP1 and the other one ISP2.
5. The default route was in ISP 1.
Now the issue comes in, when the outsider contact the server using the NAT in ISP2 the packet will be accepted and it will traversing to the private IP of the server. And then the private IP server will reply back by using the default route which is ISP1,
Question
is there a way in firewall that the firewall will able to know the packet was came in ISP2 and will reply using the ISP2 (which where it came) ?
Hello
You could try Policy based routing to achieve this:
Possible example:
interface x/x
nameif Isp2
ip address x.x.x.x y.y.y.y <Isp2 wan facing interface)
nat (inside,Isp2) source dynamic any interface
object-group services Srv_ports
port-object eq 80
port-object eq 443
access-list Srv-acl extended permit tcp host 172.16.1.1 host <isp host) object-group Srv_ports
route-map Pbr_rm
match ip address Srv-acl
set ip next-hop y.y.y.y <– ISP2next hop)
interface x/x
nameif inside
policy-route route-map Pbr_rm
Kind Regards
Paul
