UDP broadcast solution under NATted environment
blue4cisco
How to configure router under nat for proper UDP
broadcast solution under NATted environment"
vijayasankar
Level 4
Level 4
Hi Sunil,
Kindly give us more details details regarding your setup and requirement.
-VJ
we r lottery operator, our server sends udp (1234)broadcast on each 15 minutes to 1000 connected machines , but results reaches only a half machine , not all.. thr is no bandwidth issue, we are using Natting.
Hi Sunil,
If possible kindly provide us a schematic diagram of your setup.
Where are the client machines located ?
How is the connectivity between the server
and client?
Have you done any troubleshooting which lead to the conclusion that the UDP packets are dropped by NAT process?
If so, kindly provide the details of the same.
If you have not carried out any troubleshooting so far, once you update your setup details, we can suggest you some steps which will assist you to troubleshoot the issue.
-VJ
