Unable to establish vpn connection with 2 cisco vpn rv042 routers
I have purchased 2 cisco rv042 vpn router and wants to connect 2 sites thru vpn, I have configured my vpn router behind adsl router configured in bridge mode, also configured my cisco wan as pppoe mode, I also having static ip address, both the vpn routers are connected to internet and able to browse, but are not communicating with each other, I am trying  to connect the two routers using vpn, but it is not working, please help.
check if your RV042 routers are configured with NAT traversal (VPN > Client to Gateway > Advanced)...
You also might want to have a look at the instructions linked below, check if you have followed all steps...
https://www.cisco.com/c/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/smb304-vpn-tunnel-setup-on-the-rv016-rv042-rv042g-and-rv082-vpn-rou.html
