Unable to run BGP
i am unable to run "#router bgp XXX" on this new cisco "WS- C4500X-32" running image "cat4500e-universalk9.SPA.03.05.02.E.152-1.E2.bin".  any quick comment is much appreciated.
seeing this message "Protocol not in this image" while i try to add router BGP...
Leo Laohoo
Post the output to the command "sh version | i License Level:".
Switch#sh version | i License Level:
    License Level: ipbase   Type: Permanent
Go HERE.   According to this your appliance need to enable Enterprise license.
Q. What are the different types of feature sets?
A. There are three types of software licenses: LAN Base, IP Base, and IP Services. LAN Base is only supported on the Cisco Catalyst 3750-X, 3650-X, and Cisco Catalyst 2K switches.
 LAN Base: Enables basic Layer 2 forwarding and IPv4/IPv6 switch management.
 IP Base: Enables Layer 2 forwarding, IPv6 management, and basic Layer 3 routing, including Enhanced Interior Gateway Routing Protocol (EIGRP) stub and Protocol Independent Multicast (PIM) stub mode.
 IP Services: Includes IP Base and enables advanced IPv4/IPv6 Layer 3 routing such as EIGRP, Open Shortest Path First (OSPF), WCCP, VRF-lite, PBR, and IPv4 multicast routing.
