Unable to tunnel to Cloud Node IP using ASDM
Travis Rose
Hello everyone,
I'm coming to you with a bit of a head scratcher. I have 4 ASAs that all route to our Zscaler portal for traffic. However, for some reason my tunnel to Zscaler has stopped working and I cannot for the life of me figure it out. I built it just like the other ASAs but it won't actually show up as a valid tunnel when I run a sh crypto command:
Result of the command: "sh crypto ipsec sa"
interface: outside
Crypto map tag: outside_map0, seq num: 1, local addr: 50.194.32.121
access-list outside_cryptomap permit ip A-192.168.102.0 255.255.255.0 A-192.168.100.0 255.255.255.0
local ident (addr/mask/prot/port): (A-192.168.102.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (A-192.168.100.0/255.255.255.0/0/0)
current_peer: 66.64.33.202
#pkts encaps: 87268, #pkts encrypt: 87268, #pkts digest: 87268
#pkts decaps: 72713, #pkts decrypt: 72713, #pkts verify: 72713
#pkts compressed: 0, #pkts decompressed: 0
#pkts not compressed: 87268, #pkts comp failed: 0, #pkts decomp failed: 0
#pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
#PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
#send errors: 0, #recv errors: 0
local crypto endpt.: 50.194.32.121, remote crypto endpt.: 66.64.33.202
path mtu 1500, ipsec overhead 58, media mtu 1500
current outbound spi: 80C6E5AA
inbound esp sas:
spi: 0x908EC937 (2425276727)
transform: esp-3des esp-sha-hmac no compression
in use settings ={L2L, Tunnel, }
slot: 0, conn_id: 53248, crypto-map: outside_map0
sa timing: remaining key lifetime (kB/sec): (3911193/7969)
IV size: 8 bytes
replay detection support: Y
Anti replay bitmap:
0xFFFFFFFF 0xFFFFFFFF
outbound esp sas:
spi: 0x80C6E5AA (2160518570)
sa timing: remaining key lifetime (kB/sec): (3872710/7969)
IV size: 8 bytes
Anti replay bitmap:
0x00000000 0x00000001
access-list outside_cryptomap permit ip A-192.168.102.0 255.255.255.0 A-192.168.50.0 255.255.255.0
remote ident (addr/mask/prot/port): (A-192.168.50.0/255.255.255.0/0/0)
#pkts encaps: 162588, #pkts encrypt: 162588, #pkts digest: 162588
#pkts decaps: 103960, #pkts decrypt: 103960, #pkts verify: 103960
#pkts not compressed: 162588, #pkts comp failed: 0, #pkts decomp failed: 0
current outbound spi: E0F0D134
inbound esp sas:
spi: 0x5B13BEC4 (1528020676)
sa timing: remaining key lifetime (kB/sec): (3910215/7143)
IV size: 8 bytes
Anti replay bitmap:
outbound esp sas:
spi: 0xE0F0D134 (3773878580)
sa timing: remaining key lifetime (kB/sec): (3875172/7143)
IV size: 8 bytes
Anti replay bitmap:
I have attached 2 pictures of my ASDM config to show that the tunnel is definitely there. I had ZScaler on the phone with me at the time and we couldn't figure it out. I even made a new PSK on the Zscaler portal so I could guarantee connectivity. No dice. Hopefully someone can throw some insight towards me. The whole office is without internet and I have management breathing down my neck to solve it. The previous guy had a CCIE and I'm just a lowly CCNA prospect who inheritied the network:
7 Replies 7
the ASDM screenshots don't show how you have actually set up the VPN to ZScaler. The fastest way to help you is to post the output of:
sh run
sh ver
Hi Georg,
last night I cleared out the dynamic crypto any/any because it wasn't needed. What's supposed to happen is the 192.168.102.1-254 can route using a tunnel through ZScaler, which is currently 165.225.34.37. I have a VLAN, 10, which is tagged on all the physical ports of my Catalyst, is supposed to route out through the Tunnel. Here's the SH Run and Sh Ver Readouts from the non-working firewall:
Result of the command: "sh run"
: Saved
ASA Version 8.2(1)
hostname Laurel-ASA
domain-name harvester.local
enable password JFuZROOZbygC42CI encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 192.168.100.0 A-192.168.100.0 description Plano Network Data
name 192.168.101.0 A-192.168.101.0 description Denver Office
name 192.168.0.0 A-192.168.0.0 description PetroHarvester VPN
name 192.168.102.0 A-192.168.102.0 description Laurel Data Network
name 192.168.30.0 A-192.168.30.0 description Laurel Voice Network
name 192.168.20.0 A-192.168.20.0 description Plano Voice Network
name 192.168.50.0 A-192.168.50.0 description Plano Wireless Network
name 192.168.105.0 Houston-LAN description Houston LAN Address
name 192.168.198.0 HOU-VPN description Houston VPN Network
name 192.168.40.0 Houston-Voice description Houston Voice Network
name 10.249.2.0 Dummy-Network description Dummy-Network
name 192.168.199.0 A-192.168.199.0 description Plano-VPN
name 184.106.31.0 Connect-Email-SRVR
name 173.203.187.0 Email-SRVR
name 206.82.157.84 Evin-FTP-IP
name 98.129.229.244 FTP-PetroHarvester
name 64.62.142.12 Meraki-IP1
name 64.156.192.245 Meraki-IP2
name 108.161.147.0 Meraki-IP3
name 199.231.78.0 Meraki-IP4
name 54.193.207.248 Meraki-IP5
name 64.62.142.2 Meraki-IP6
name 64.156.192.246 Meraki-IP7
name 17.0.0.0 Meraki-IP8
name 209.206.48.0 Meraki-IP9
name 143.127.136.0 SEP-Cloud-IP
name 184.106.54.0 Secure-Email-SRVR
name 166.78.79.0 Secure2-Email-SRVR
name 192.168.102.20 Laurel-Canon-IP description Laurel Canon Printer IP
name 66.76.188.44 BoreSight-IP description BoreSight Software IP Address
name 146.20.74.210 Ourscada
name 165.225.10.0 NEW-ZSCALER-SUB
name 165.225.10.48 zcloud
dns-guard
interface Vlan1
nameif inside
security-level 100
ip address 192.168.102.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 50.194.32.121 255.255.255.248
interface Ethernet0/0
switchport access vlan 2
speed 100
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns domain-lookup inside
dns server-group DefaultDNS
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object-group network All-Inside
network-object A-192.168.102.0 255.255.255.0
network-object A-192.168.30.0 255.255.255.0
object-group service DM_INLINE_SERVICE_1
service-object icmp
service-object icmp echo
service-object icmp echo-reply
service-object icmp time-exceeded
service-object icmp unreachable
object-group service UDP-10115 udp
description UDP-10115 for VOIP
port-object eq 10115
object-group network DM_INLINE_NETWORK_2
network-object A-192.168.100.0 255.255.255.0
network-object A-192.168.20.0 255.255.255.0
network-object A-192.168.50.0 255.255.255.0
object-group network DM_INLINE_NETWORK_3
object-group network Houston-LAN-Group
description Houston LAN Addresses
network-object Houston-LAN 255.255.255.0
network-object HOU-VPN 255.255.255.0
network-object Houston-Voice 255.255.255.0
object-group network BlackListed_IPs
description List of BlackListed IPs
network-object host 195.22.28.192
network-object host 195.22.28.193
network-object host 195.22.28.194
network-object host 195.22.28.195
network-object host 195.22.28.196
network-object host 195.22.28.197
network-object host 195.22.28.198
network-object host 195.22.28.199
object-group network DM_INLINE_NETWORK_1
network-object A-192.168.199.0 255.255.255.0
object-group network Non-Exempt-IP-List
description List of Non Exempt IPs for Zscaler Traffic
network-object Meraki-IP3 255.255.255.0
network-object SEP-Cloud-IP 255.255.255.0
network-object Secure2-Email-SRVR 255.255.255.0
network-object Meraki-IP8 255.0.0.0
network-object Email-SRVR 255.255.255.0
network-object Connect-Email-SRVR 255.255.255.0
network-object Secure-Email-SRVR 255.255.255.0
network-object Meraki-IP4 255.255.255.0
network-object host Evin-FTP-IP
network-object Meraki-IP9 255.255.255.240
network-object host Meraki-IP5
network-object host Meraki-IP2
network-object host Meraki-IP7
network-object host Meraki-IP1
network-object host Meraki-IP6
network-object host FTP-PetroHarvester
network-object host BoreSight-IP
object-group service DM_INLINE_TCP_2 tcp
port-object eq www
port-object eq https
port-object eq 8083
port-object eq 8088
object-group service DM_INLINE_TCP_3 tcp
port-object eq 8083
port-object eq 8088
port-object eq www
object-group service DM_INLINE_TCP_1 tcp
port-object eq www
access-list outside_cryptomap extended permit ip object-group All-Inside object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip object-group All-Inside A-192.168.100.0 255.255.255.0
access-list inside_nat0_outbound extended permit ip object-group All-Inside object-group DM_INLINE_NETWORK_3
access-list PetroHarvester_splitTunnelAcl standard permit 192.168.10.0 255.255.255.0
access-list PetroHarvester_splitTunnelAcl standard permit A-192.168.20.0 255.255.255.0
access-list PetroHarvester_splitTunnelAcl standard permit A-192.168.50.0 255.255.255.128
access-list PetroHarvester_splitTunnelAcl remark Frisco Access
access-list PetroHarvester_splitTunnelAcl standard permit A-192.168.100.0 255.255.255.0
access-list PetroHarvester_splitTunnelAcl remark Denver Access
access-list PetroHarvester_splitTunnelAcl standard permit A-192.168.101.0 255.255.255.0
access-list outside_access_in extended deny ip object-group BlackListed_IPs any
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_1 any any
access-list outside_access_in extended permit tcp host Ourscada any object-group DM_INLINE_TCP_2
access-list outside_cryptomap_1 extended permit ip object-group All-Inside object-group Houston-LAN-Group
access-list PetroHarvester_splitTunnelAcl_1 standard permit A-192.168.0.0 255.255.0.0
access-list inside_nat0_outbound_1 extended permit ip object-group All-Inside object-group DM_INLINE_NETWORK_2
access-list inside_nat0_outbound_1 extended permit ip object-group All-Inside object-group Houston-LAN-Group
access-list inside_nat0_outbound_1 extended deny ip host Laurel-Canon-IP any
access-list inside_nat0_outbound_1 extended deny ip object-group All-Inside object-group Non-Exempt-IP-List
access-list inside_nat0_outbound_1 extended permit ip object-group All-Inside any
access-list inside_nat0_outbound_1 extended permit ip object-group All-Inside NEW-ZSCALER-SUB 255.255.254.0
access-list Zscaler_MAP extended permit tcp host 165.22.34.37 any
access-list Zscaler_MAP extended permit icmp host 165.22.34.37 any
access-list Zscaler_MAP extended permit ip host 165.22.34.37 any
access-list inside_access_in extended permit tcp host Ourscada any object-group DM_INLINE_TCP_3
access-list outside_cryptomap_2 extended permit tcp object-group All-Inside any object-group DM_INLINE_TCP_1
pager lines 24
logging enable
logging asdm-buffer-size 300
logging asdm informational
mtu inside 1500
mtu outside 1500
ip local pool VPNPool 192.168.50.50-192.168.50.100 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list inside_nat0_outbound_1
nat (inside) 1 0.0.0.0 0.0.0.0 dns
access-group inside_access_in in interface inside
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 50.194.32.126 1
route inside A-192.168.30.0 255.255.255.0 192.168.102.254 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server ActiveDirectory protocol radius
interim-accounting-update
aaa-server ActiveDirectory (inside) host 192.168.10.231
key y4OjVwNxuCPWjmk4OVEJ
radius-common-pw y4OjVwNxuCPWjmk4OVEJ
aaa-server ActiveDirectory (inside) host 192.168.10.232
aaa authentication ssh console LOCAL
aaa authentication enable console LOCAL
http server enable
http server idle-timeout 30
http A-192.168.0.0 255.255.0.0 inside
http 4.16.103.210 255.255.255.255 outside
http 45.17.125.110 255.255.255.255 outside
http 66.196.253.42 255.255.255.255 outside
http 66.64.33.202 255.255.255.255 outside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec transform-set ESP-NULL-MD5 esp-null esp-md5-hmac
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set pfs group1
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map0 1 match address outside_cryptomap
crypto map outside_map0 1 set peer 66.64.33.202
crypto map outside_map0 1 set transform-set ESP-3DES-SHA
crypto map outside_map0 2 match address outside_cryptomap_1
crypto map outside_map0 2 set peer 38.88.155.2
crypto map outside_map0 2 set transform-set ESP-3DES-SHA
crypto map outside_map0 3 match address outside_cryptomap_2
crypto map outside_map0 3 set peer 165.225.34.37
crypto map outside_map0 3 set transform-set ESP-3DES-SHA ESP-3DES-MD5 ESP-AES-128-SHA
crypto map outside_map0 interface outside
crypto isakmp identity address
crypto isakmp enable outside
crypto isakmp policy 5
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
crypto isakmp policy 10
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 30
encryption 3des
hash md5
group 2
lifetime 86400
vpn-addr-assign local reuse-delay 5
telnet timeout 5
ssh A-192.168.0.0 255.255.0.0 inside
ssh 192.168.102.1 255.255.255.255 inside
ssh 4.16.103.210 255.255.255.255 outside
ssh 45.17.125.110 255.255.255.255 outside
ssh 66.196.253.42 255.255.255.255 outside
ssh 50.194.32.121 255.255.255.255 outside
ssh 66.64.33.202 255.255.255.255 outside
ssh timeout 30
console timeout 0
management-access inside
dhcp-client update dns server both
dhcpd auto_config outside
dhcpd dns 4.2.2.2 interface inside
vpnclient server RemoteVPN
vpnclient mode client-mode
vpnclient vpngroup RemoteVPN password ********
vpnclient username datavox password ********
priority-queue inside
priority-queue outside
threat-detection basic-threat
threat-detection scanning-threat shun
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
group-policy PetroHarvester internal
group-policy PetroHarvester attributes
dns-server value 192.168.10.231 192.168.10.232
vpn-tunnel-protocol l2tp-ipsec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value PetroHarvester_splitTunnelAcl
default-domain value harvester.local
username petroharvester password 3.lFatHVsbglPt69 encrypted privilege 15
username VPNPhone password VeBa3E2aus5Zo1QC encrypted privilege 15
tunnel-group PetroHarvester type remote-access
tunnel-group PetroHarvester general-attributes
address-pool VPNPool
authentication-server-group ActiveDirectory LOCAL
default-group-policy PetroHarvester
tunnel-group PetroHarvester ipsec-attributes
pre-shared-key *
tunnel-group 66.64.33.202 type ipsec-l2l
tunnel-group 66.64.33.202 ipsec-attributes
pre-shared-key *
tunnel-group 38.88.155.2 type ipsec-l2l
tunnel-group 38.88.155.2 ipsec-attributes
pre-shared-key *
tunnel-group 165.225.34.37 type ipsec-l2l
tunnel-group 165.225.34.37 ipsec-attributes
pre-shared-key *
tunnel-group 50.194.32.121 type ipsec-l2l
tunnel-group 50.194.32.121 ipsec-attributes
pre-shared-key *
class-map VOIP-QOS
description QOS for VOIP
match port udp range 10112 10115
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
inspect ftp
inspect netbios
inspect rsh
inspect sqlnet
inspect sunrpc
inspect tftp
inspect xdmcp
inspect pptp
inspect icmp
class VOIP-QOS
priority
service-policy global_policy global
prompt hostname context
Cryptochecksum:198163434d1f7a6354bb1444fb4116a9
: end
Sh Ver:
Result of the command: "Sh Ver"
Cisco Adaptive Security Appliance Software Version 8.2(1)
Device Manager Version 6.2(1)
Compiled on Tue 05-May-09 22:45 by builders
System image file is "disk0:/asa821-k8.bin"
Config file at boot was "startup-config"
Laurel-ASA up 12 hours 1 min
Hardware: ASA5505, 512 MB RAM, CPU Geode 500 MHz
Internal ATA Compact Flash, 128MB
BIOS Flash Firmware Hub @ 0xffe00000, 1024KB
Encryption hardware device : Cisco ASA-5505 on-board accelerator (revision 0x0)
Boot microcode : CN1000-MC-BOOT-2.00
SSL/IKE microcode: CNLite-MC-SSLm-PLUS-2.03
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.04
0: Int: Internal-Data0/0 : address is f866.f2d6.73de, irq 11
1: Ext: Ethernet0/0 : address is f866.f2d6.73d6, irq 255
2: Ext: Ethernet0/1 : address is f866.f2d6.73d7, irq 255
3: Ext: Ethernet0/2 : address is f866.f2d6.73d8, irq 255
4: Ext: Ethernet0/3 : address is f866.f2d6.73d9, irq 255
5: Ext: Ethernet0/4 : address is f866.f2d6.73da, irq 255
6: Ext: Ethernet0/5 : address is f866.f2d6.73db, irq 255
7: Ext: Ethernet0/6 : address is f866.f2d6.73dc, irq 255
8: Ext: Ethernet0/7 : address is f866.f2d6.73dd, irq 255
9: Int: Internal-Data0/1 : address is 0000.0003.0002, irq 255
10: Int: Not used : irq 255
11: Int: Not used : irq 255
Licensed features for this platform:
Maximum Physical Interfaces : 8
VLANs : 3, DMZ Restricted
Inside Hosts : 50
Failover : Disabled
VPN-DES : Enabled
VPN-3DES-AES : Enabled
SSL VPN Peers : 2
Total VPN Peers : 10
Dual ISPs : Disabled
VLAN Trunk Ports : 0
Shared License : Disabled
AnyConnect for Mobile : Disabled
AnyConnect for Linksys phone : Disabled
AnyConnect Essentials : Disabled
Advanced Endpoint Assessment : Disabled
UC Phone Proxy Sessions : 2
Total UC Proxy Sessions : 2
Botnet Traffic Filter : Disabled
This platform has a Base license.
Serial Number: JMX1439Z1Z2
Configuration register is 0x1
Configuration last modified by petroharvester at 02:29:36.519 CDT Tue Sep 2 2008
Here's a Show Version and Show Run from a working Router, 192.168.104.1:
Result of the command: "sh ver"
Cisco Adaptive Security Appliance Software Version 8.2(5)
Device Manager Version 6.4(5)
Compiled on Fri 20-May-11 16:00 by builders
System image file is "disk0:/asa825-k8.bin"
Reddell-ASA up 30 days 21 hours
IPSec microcode : CNlite-MC-IPSECm-MAIN-2.05
0: Int: Internal-Data0/0 : address is e02f.6d2f.4269, irq 11
1: Ext: Ethernet0/0 : address is e02f.6d2f.4261, irq 255
2: Ext: Ethernet0/1 : address is e02f.6d2f.4262, irq 255
3: Ext: Ethernet0/2 : address is e02f.6d2f.4263, irq 255
4: Ext: Ethernet0/3 : address is e02f.6d2f.4264, irq 255
5: Ext: Ethernet0/4 : address is e02f.6d2f.4265, irq 255
6: Ext: Ethernet0/5 : address is e02f.6d2f.4266, irq 255
7: Ext: Ethernet0/6 : address is e02f.6d2f.4267, irq 255
8: Ext: Ethernet0/7 : address is e02f.6d2f.4268, irq 255
Inside Hosts : 10
Failover : Disabled
VPN-DES : Enabled
SSL VPN Peers : 2
AnyConnect for Cisco VPN Phone : Disabled
Serial Number: JMX17054004
Configuration last modified by petroharvester at 06:33:44.881 UTC Sat Sep 27 2008
And the show version:
: Saved
ASA Version 8.2(5)
hostname Reddell-ASA
enable password A17OWcz5qpXtW0ON encrypted
names
name 192.168.100.0 A-192.168.100.0 description Plano LAN
name 192.168.199.0 A-192.168.199.0 description Plano VPN
name 192.168.20.0 A-192.168.20.0 description Plano Phone
name 192.168.0.0 A-192.168.0.0 description Petro's Networks
name 192.168.104.1 Reddell_ASA description Reddell's Firewall IP Address
name 192.168.104.254 Reddell_Router description Reddell's Router IP Address
name 206.82.157.84 Evin-FTP-IP description Evin-FTP-IP
name 98.129.229.244 FTP-PetroHarvester description FTP IP Address for ftp.petroharvester.com
name 173.203.187.0 Email-SRVR description PetroHarvester Email SRVR
name 184.106.54.0 Secure-Email-SRVR description Secure PetroHarvester Email SRVR
name 143.127.136.0 SEP-Cloud-IP description SEP Cloud IP Range
name 184.106.31.0 Connect-Email-SRVR description Connect EmailSrvr IP
name 146.20.74.210 OURSCADA.com description ourscada domain
name 165.225.10.0 ZScaler-New-Subnet
name 172.253.127.121 Mobile
name 165.225.10.48 ZScaler-VPN-NEW
interface Vlan1
nameif inside
security-level 100
ip address Reddell_ASA 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 65.116.10.210 255.255.255.248
boot system disk0:/asa825-k8.bin
ftp mode passive
object-group network A-192.168.0.0
description Network Access All Sites
object-group network A-192.168.100.0
object-group network A-192.168.101.200
object-group network A-192.168.102.0
description Data Network Laurel
object-group network A-192.168.30.0
description Voice Network Laurel
object-group network A-192.168.50.0
object-group network Dallas-LAN-Voice
object-group network Dallas_RA_VPN
description Dallas VPN Network
object-group network Inside-Network
description Reddell LAN
object-group network Plano_Network
description Plano Network Addresses
service-object icmp
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
port-object eq www
object-group service Zscaler-Proxy-Services tcp
description Zscaler-Proxy-Services for Internet Use
port-object eq www
port-object eq www
port-object eq ftp
port-object eq ftp-data
object-group network FTP-No-Exempt-List
description FTP No Exempt List of IPs to bypass Zscaler Tunnel
network-object Meraki-IP9 255.255.240.0
object-group service DM_INLINE_TCP_4 tcp
port-object eq www
object-group service OurSCADAport tcp-udp
port-object eq 8088
object-group service OurSCADAport2 tcp
port-object eq 8043
object-group service http-ssl tcp
port-object eq 8088
object-group service DM_INLINE_SERVICE_2
service-object tcp-udp eq 8088
service-object tcp eq 8043
object-group service DM_INLINE_TCP_5 tcp
port-object eq 8088
port-object eq www
port-object eq 8043
object-group service DM_INLINE_TCP_7 tcp
port-object eq 8083
port-object eq 8088
port-object eq www
network-object host OURSCADA.com
network-object host Mobile
object-group service DM_INLINE_SERVICE_3
service-object icmp
service-object tcp eq 8088
service-object tcp eq www
service-object tcp eq https
object-group service DM_INLINE_SERVICE_4
service-object icmp
object-group service DM_INLINE_SERVICE_5
service-object icmp
access-list inside_nat0_outbound extended permit ip 192.168.104.0 255.255.255.0 object-group DM_INLINE_NETWORK_1
access-list inside_nat0_outbound extended permit ip A-192.168.0.0 255.255.0.0 A-192.168.0.0 255.255.0.0
access-list inside_nat0_outbound extended deny ip 192.168.104.0 255.255.255.0 object-group FTP-No-Exempt-List
access-list inside_nat0_outbound extended permit ip 192.168.104.0 255.255.255.0 Houston-LAN 255.255.255.0
access-list inside_nat0_outbound extended permit ip 192.168.104.0 255.255.255.0 any
access-list inside_nat0_outbound extended permit ip ZScaler-New-Subnet 255.255.254.0 any
access-list outside_access_in extended permit object-group DM_INLINE_SERVICE_3 host OURSCADA.com any
access-list outside_access_in extended permit tcp host Mobile any object-group DM_INLINE_TCP_5
access-list inside_access_in remark Implicit rule: Permit all traffic to less secure networks
access-list inside_access_in extended permit ip any any
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_4 host OURSCADA.com any
access-list inside_access_in extended permit tcp host Mobile any object-group DM_INLINE_TCP_7
access-list inside_access_in extended permit object-group DM_INLINE_SERVICE_5 any object-group DM_INLINE_NETWORK_3
access-list outside_cryptomap_1 extended permit ip 192.168.104.0 255.255.255.0 Houston-LAN 255.255.255.0
access-list outside_cryptomap_2 extended permit ip 192.168.104.0 255.255.255.0 object-group DM_INLINE_NETWORK_2
access-list Zscaler-VPN-Traffic extended permit tcp 192.168.104.0 255.255.255.0 any object-group DM_INLINE_TCP_4
access-list Evin-FTP extended permit tcp any host Evin-FTP-IP object-group DM_INLINE_TCP_3
access-list outside_cryptomap extended permit ip 192.168.104.0 255.255.255.0 host ZScaler-VPN-NEW
pager lines 24
logging enable
mtu inside 1500
mtu outside 1500
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 65.116.10.209 1
timeout floating-conn 0:00:00
http server enable
http 168.215.169.82 255.255.255.255 outside
http 0.0.0.0 0.0.0.0 inside
http 4.16.103.212 255.255.255.255 outside
crypto map outside_map1 1 match address outside_cryptomap
crypto map outside_map1 1 set peer 65.116.10.210
crypto map outside_map1 1 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map1 2 match address outside_cryptomap_1
crypto map outside_map1 2 set peer 38.88.155.2
crypto map outside_map1 2 set transform-set ESP-3DES-SHA
crypto map outside_map1 3 match address outside_cryptomap_2
crypto map outside_map1 3 set peer 66.64.33.202
crypto map outside_map1 3 set transform-set ESP-3DES-SHA
crypto map outside_map1 10 match address Zscaler-VPN-Traffic
crypto map outside_map1 10 set peer 165.225.34.37 165.225.0.42
crypto map outside_map1 10 set transform-set ESP-NULL-MD5
crypto map outside_map1 interface outside
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpoint ASDM_TrustPoint0
enrollment self
subject-name CN=Reddell-ASA
crl configure
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
6c2527b9 deb78458 c61f381e a4c4cb66
quit
crypto ca certificate chain ASDM_TrustPoint0
certificate ee86ac51
308201db 30820144 a0030201 020204ee 86ac5130 0d06092a 864886f7 0d010105
05003032 31143012 06035504 03130b52 65646465 6c6c2d41 5341311a 30180609
2a864886 f70d0109 02160b52 65646465 6c6c2d41 5341301e 170d3133 30363033
31333035 32345a17 0d323330 36303131 33303532 345a3032 31143012 06035504
03130b52 65646465 6c6c2d41 5341311a 30180609 2a864886 f70d0109 02160b52
65646465 6c6c2d41 53413081 9f300d06 092a8648 86f70d01 01010500 03818d00
30818902 818100b0 43b0d228 4d5e683e 870333fb f23b2990 bc9f6e3d 0adb89b0
652bbec3 6c5c876b 16a36404 835a8adb 50fbe2e5 dfa4e04f 37a6c1e6 dc54ea20
aadacd99 d5db850e 9e36403b c4693a82 58b976d3 9f540d08 73bb839e 8761e4e3
983ea5d5 40372a17 379faac5 820503b5 8173c212 a5e252bd 43f5be34 ac732f8e
2fded1d9 3b73b902 03010001 300d0609 2a864886 f70d0101 05050003 8181009f
a49ce851 a85f7457 3a4db7bf a5d2f435 2ec0fc8d 3181e6a8 9c5bc30b 47fb61d8
60bf3c74 ffc9d090 0d25de94 2398cd9d cf85ecbe f7d95e46 a0b531bd 9ed54f94
f22d84bb aa961329 5c0b7173 b065936d 84f6ca9d 216d1981 810ce292 fbb6064b
4addf406 aead7a77 ce4fb099 dce1297a a66782dc 72559004 da054531 7a79d3
quit
encryption aes
hash sha
group 2
lifetime 86400
crypto isakmp policy 120
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 5
ssh 65.116.10.210 255.255.255.255 outside
ssh timeout 30
console timeout 2
dhcpd address 192.168.104.89-192.168.104.120 inside
dhcpd dns 192.168.100.40 192.168.100.60 interface inside
dhcpd enable inside
webvpn
group-policy DfltGrpPolicy attributes
vpn-tunnel-protocol IPSec l2tp-ipsec
group-policy GroupPolicy2 internal
group-policy GroupPolicy2 attributes
group-policy GroupPolicy1 internal
group-policy GroupPolicy1 attributes
pre-shared-key *****
tunnel-group 66.64.33.204 type ipsec-l2l
tunnel-group 66.64.33.204 ipsec-attributes
tunnel-group 165.225.0.42 type ipsec-l2l
tunnel-group 165.225.0.42 ipsec-attributes
tunnel-group 65.116.10.210 type ipsec-l2l
tunnel-group 65.116.10.210 ipsec-attributes
policy-map inside-policy
description inspection_default
inspect ftp
inspect icmp
inspect netbios
inspect pptp
inspect rsh
inspect sqlnet
inspect sunrpc
inspect tftp
inspect xdmcp
service-policy inside-policy interface inside
call-home reporting anonymous
Cryptochecksum:b9413784968cc51b2ab29901404109e8
: end
Thanks, I'll have a look...
I have extracted just the parts that belong to the ZScaler VPN. You need to go to the command line (cli) and add the lines marked in bold:
port-object eq www
encryption aes
hash sha
group 2
lifetime 86400
--> crypto isakmp nat-traversal 3600
--> peer-id-validate nocheck
--> isakmp keepalive threshold 10 retry 5
--> crypto map outside_map1 10 set connection-type originate-only
--> crypto map outside_map1 10 set phase1-mode aggressive
--> crypto map outside_map1 10 set security-association lifetime seconds 28800
I have made additional clarifications on my post
Try and implement the changes suggested, the most important one probably being the NAT traversal, which I did not see in your configuration.
Hi Georg,
I tried implementing the changes you recommended in the 192.168.102.1 firewall. It appears the tunnel still isn't up on my end for some reason. I also lost access to my TUNNEL between my office here and the remote office. For now I have reversed the changes until I can dig deeper into what settings I've messed up. I have identified there does appear to be a NATTING issues somewhere with that 165.225.37.34 tunnel. It's not sending TCP 80 or 443 through it.
