utorrent cpu usage...general question.
j_friedrich
Level 3
Level 3
Hi guys,
     Just a general question for all of you.  I am running a 1941 isr g2 router, which, according to my specs is equivalent to a cisco 3825 - which i also own.
Why would the cpu usage hover around 45% or so with ONE machine running torrents?  There is really no packet inspection etc...or anything else that would cause the cpu to work really hard...I am on a 100/5 connection.
Any ideas or opinions on this?
Thanks for the input.
Jason
13 Replies 13
j_friedrich
Level 3
Level 3
Hi guys,
     Here is a 'show processes' dump for you.  Maybe you can shed some light on why ONE machine is kicking the daylights out of this router...
I want to get the cpu utilization down...no problem with the torrents.
Ideas, suggestions, insight is appreciated.
Thanks.
show processes
CPU utilization for five seconds: 55%/53%; one minute: 54%; five minutes: 45%
PID QTy       PC Runtime (ms)    Invoked   uSecs    Stacks TTY Process
   1 Cwe 23ACA3C0          348       4246      81 5156/6000   0 Chunk Manager
   2 Csp 21AC5B54         5516    1080681       5 2412/3000   0 Load Meter
   3 Mwe 2106584C            4          1    400023028/24000  0 LICENSE AGENT
   4 Mwe 23B38B7C            0          1       0 5760/6000   0 RO Notify Timers
   5 Lst 23AF0B44      4873268     823512    5917 5204/6000   0 Check heaps
   6 Cwe 23AE4EE4        22084      90196     244 5240/6000   0 Pool Manager
   7 Mwe 23AE4E54            0          1       0 5656/6000   0 DiscardQ Backgro
   8 Mst 225E9668            0          2       0 5276/6000   0 Timers
   9 Mwe 2264B494            8       2595       3 2720/3000   0 WATCH_AFS
  10 Mwe 21039F1C            0          1       0 5652/6000   0 License Client N
  11 Mwe 21023AB0            0          1       0 5604/6000   0 Image License br
  12 Msi 2103C5C0      3660196      89997   40670 2420/6000   0 Licensing Auto U
  13 Msi 21213574      4333460    5398976     802 5292/6000   0 Environmental mo
  14 Mwe 213287D0         3864    1079952       3 5664/6000   0 IPC Event Notifi
  15 Mwe 21339004           52      89997       0 5728/6000   0 IPC Dynamic Cach
  16 Mwe 21344EF0            0          1       0 5660/6000   0 IPC Session Serv
  17 Mwe 21339758            0          1       0 5664/6000   0 IPC Zone Manager
  18 Mwe 2133909C          812    5276596       0 5692/6000   0 IPC Periodic Tim
  19 Mwe 21338EA4          888    5276596       0 5632/6000   0 IPC Deferred Por
  20 Mwe 2133915C            0          1       0 5680/6000   0 IPC Process leve
  21 Mwe 213393E8            0          1       0 5336/6000   0 IPC Seat Manager
  22 Mwe 2131E6D0            8     308768       0 5680/6000   0 IPC Check Queue
  23 Mwe 213395B0            0          1       0 5652/6000   0 IPC Seat RX Cont
  24 Mwe 21339678            0          1       0 5652/6000   0 IPC Seat TX Cont
  25 Mwe 213399A4           24     540344       0 5700/6000   0 IPC Keep Alive M
  26 Hsi 21324470           44    1080679       0 5732/6000   0 IPC Loadometer
  27 Mwe 21412DAC            0          1       023560/24000  0 Crash writer
  28 Mwe 214135D8            0          1       0 5172/6000   0 Exception contro
  30 Mwe 21D0A178            0          1       0 5744/6000   0 IFS Agent Manage
  31 Mwe 2229CC88      5564604   84269305      66 3644/6000   0 ARP Input
  32 Mwe 22298ED8         6968    5632897       1 3376/6000   0 ARP Background
  33 Mwe 222D1D34            0          2       0 5268/6000   0 ATM Idle Timer
  34 Mwe 222C3DE0            0          1       0 5648/6000   0 ATM ASYNC PROC
  35 Lwe 224C26C4            0          1       0 5652/6000   0 CEF MIB API
  36 Lwe 225BC814            0          1       0 5772/6000   0 AAA_SERVER_DEADT
  37 Mwe 2261F78C            0          1       011616/12000  0 Policy Manager
  38 Mwe 2276C464            0          2       0 5264/6000   0 DDR Timers
  39 Lwe 228375D0            0          4       0 5088/6000   0 Entity MIB API
  40 Mst 2339F750         2144         29   73931 3964/6000   0 PrstVbl
  41 Mwe 238584F8            0          2       0 5272/6000   0 Serial Backgroun
  42 Mwe 23B3FC94            0          1       0 2648/3000   0 RMI RM Notify Wa
  43 Mwe 213510B8            0          2       0 5292/6000   0 SMART
  44 Mwe 23E383CC            4          1    4000 4008/6000   0 RF SCTPthread
  45 Mwe 23E383CC            0          1       0 4584/6000   0 CHKPT RG SCTPthr
  46 Mwe 21D0D7D4         1160      46937      24 5500/6000   0 ARP Snoop
  47 Msp 226ADB04         5092    5403399       0 5320/6000   0 GraphIt
  48 Mwe 227930F8            0          2       011284/12000  0 Dialer event
  49 Mwe 2385FC40            0          1       0 5664/6000   0 SERIAL A'detect
  50 Mwe 23DEEB24            0          2       011300/12000  0 XML Proxy Client
  51 Cwe 23B041A8            0          1       0 5676/6000   0 Critical Bkgnd
  52 Mwe 21440A98        12832     557709      23 9336/12000  0 Net Background
  53 Mwe 21440C98            0          3       011272/12000  0 IDB Work
  54 Lwe 226DD358          204     620579       010480/12000  0 Logger
  55 Mwe 2260D58C         2072    5398977       0 4744/6000   0 TTY Background
  56 Mwe 23E383CC            0          6       0 3588/6000   0 RF Slave Main Th
  57 Mwe 238B9614            4          4    1000 5072/6000   0 IF-MGR control p
  58 Mwe 238C3604            4        540       7 5656/6000   0 IF-MGR event pro
  59 Mwe 212DA180            0          1       0 2644/3000   0 Inode Table Dest
  60 Mwe 221859F0            0          2       0 5600/6000   0 cpf_msg_holdq_pr
  61 Mwe 22185644            0          1       0 5640/6000   0 cpf_msg_rcvq_pro
  62 Mwe 2218606C            0          1       0 5624/6000   0 cpf_process_tpQ
  63 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  64 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  65 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  66 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  67 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  68 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  69 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  70 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  71 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  72 Mwe 21C361E8            0          1       0 5632/6000   0 CHKPT Test clien
  73 Mwe 22218290            0          1       011652/12000  0 Crypto PKI-HA
  74 Mwe 219C04BC           12      47400       0 5268/6000   0 TDM Management
  75 Mwe 23E383CC            0          7       0 3484/6000   0 RF Master Main T
  76 Mwe 23E383CC            0          2       0 4580/6000   0 RF Master Status
  77 Hwe 21452130          812      54950      14 5552/6000   0 Net Input
  78 Msp 2144C278         1816    1080746       1 5296/6000   0 Compute load avg
  79 Msp 214525D0       414648     181885    2279 5224/6000   0 Per-minute Jobs
  80 Msp 21452570         8224    5403759       1 7984/9000   0 Per-Second Jobs
  81 Mwe 2135B710            0          3       0 4980/6000   0 AggMgr Process
  82 Mwe 222030C8            0          1       0 5652/6000   0 Token Daemon
  83 Mst 230E4570            0      22850       0 5532/6000   0 Transport Port A
  84 Mwe 238CF0EC        33852    1117363      30 5680/6000   0 HC Counter Timer
  85 Mwe 2108A14C        11368     359974      31 4736/6000   0 SM Monitor
  86 Mwe 210B2F90            0          2       011012/12000  0 SM Installer
  87 Mwe 212F0504            0          1       0 2676/3000   0 dev_device_inser
  88 Mwe 212F0548            0          1       0 2676/3000   0 dev_device_remov
  89 Hwe 215CDEB4            0          2       0 5304/6000   0 ESWPPM
  90 Mwe 215D9B1C            0          2       0 5268/6000   0 Eswilp Storm Con
  91 Hwe 21697CF4        12796        628   20375 3820/6000   0 DXMRVL
  92 Mwe 216D9DCC            0          1       0 5656/6000   0 esw_mrvl mat que
  93 Mwe 216EC9A4       311196    5449617      57 5304/6000   0 ehwic_eswge Proc
  94 Hsi 21D2CD98          124    5403240       0 5292/6000   0 Console redirect
  95 Mwe 221986AC            0          1       0 5776/6000   0 RF_INTERDEV_DELA
  96 Mwe 2219B538            0          1       023644/24000  0 RF_INTERDEV_SCTP
  97 Mwe 23E383CC            4          4    1000 7040/9000   0 EEM ED Identity
  98 Mwe 23E383CC         9296     405527      22 7044/9000   0 EEM ED ND
  99 Mwe 22727B68          644    5394243       0 4424/9000   0 Dynamic DNS Upda
100 Hwe 21A156E4            0          1       0 5628/6000   0 IGMP Snooping Pr
101 Hwe 21A15BCC           24       1096      21 5488/6000   0 IGMP Snooping Re
102 Msi 21A62FF0          112     179992       0 5260/6000   0 Call Management
103 Hwe 21B39BB4            4          2    2000 4792/6000   0 USB Startup
104 Mwe 22195360            0          1       023644/24000  0 CF_INTERDEV_SCTP
105 Hwe 21607480         7368   10806498       0 5276/6000   0 BPSM stat Proces
106 Mwe 21D2D530         1764        264    6681 5296/6000   0 i2c sm_exchange
107 Hwe 21D2C284       115716     162053     714 5264/6000   0 i2c console redi
108 Hwe 21252C90            0          2       011300/12000  0 Ethernet CFM
109 Hwe 21252D40          840   34342689       011292/12000  0 Ethernet Timer C
110 Hwe 21252DEC         8416  687449445       011292/12000  0 Ethernet Msec Ti
111 Mwe 214C6DB0            8        593      1311284/12000  0 Auth Manager
112 Mwe 214E2B20            0          1       0 5800/6000   0 AUTH POLICY Fram
113 Mwe 21504FDC            0          2       0 5300/6000   0 Dot1x Mgr Proces
114 Mwe 2154018C            0          1       0 5744/6000   0 802.1x Webauth F
115 Mwe 21557ADC            0          1       0 5760/6000   0 EAP Framework
116 Mwe 21579368            0          2       0 5268/6000   0 CMD HANDLER
117 Mwe 215B9234            0          2       0 5216/6000   0 DTP Protocol
118 Mwe 216C6A14            0          1       0 5648/6000   0 SFF8472
119 Msi 219CADC4          636    5398983       0 5316/6000   0 PI MATM Aging Pr
120 Lwe 21B77D9C            0          2       0 5256/6000   0 call_home_les_oi
121 Mwe 21BBE084            0          1       023244/24000  0 SMI Director DB
122 Mwe 21BBE5F4            0          1       0 5624/6000   0 SMI CDP Update H
123 Mwe 21BB3D20            0          1       023084/24000  0 SMI Backup Proce
124 Mwe 21C09498            0          2       011292/12000  0 RG Faults Timer
125 Mwe 21C18E44            0          2       011296/12000  0 RG Protocol Time
126 Mwe 21C1EB48            0          2       011296/12000  0 RG Transport Tim
127 Mwe 21C2CA44            0          1       0 5760/6000   0 RG VP
128 Mwe 21C2EF4C            0          2       0 5292/6000   0 RG AR
129 Mwe 21C76C28            0          3       011112/12000  0 CTS CORE
130 Mwe 21CCF3D0            8        201      3911240/12000  0 SXP CORE
131 Mwe 21CF8D34            4      45029       0 5480/6000   0 DHCP Snooping
132 Mwe 21D06BFC            0          2       0 8276/9000   0 IP Host Track Pr
133 Mwe 22007FA0            0          1       0 5744/6000   0 IPv6 ping proces
134 Mwe 22280718            0          2       0 5284/6000   0 AAA Server
135 Mwe 2227BF20            0          1       0 5756/6000   0 AAA ACCT Proc
136 Mwe 2227C13C            0          1       0 5284/6000   0 ACCT Periodic Pr
137 Mwe 2228F520            0          1       0 5592/6000   0 AAA System Acct
138 Mwe 224B9478        31916    1484545      21 3780/6000   0 CDP Protocol
139 Mwe 2258A4E4            0          2       0 5284/6000   0 AAA Dictionary R
140 Mwe 22852E24            0          2       011304/12000  0 Ethernet LMI
141 Mwe 22868234            0          2       0 8300/9000   0 Ethernet OAM Pro
142 Lwe 2291D5E4            0          2       011360/12000  0 CEF switching ba
143 Lwe 2291D5E4            0          1       0 2360/3000   0 ADJ NSF process
144 Hwe 222EC408            0          2       011068/12000  0 ATM OAM Input
145 Hwe 222EB454            0          2       011280/12000  0 ATM OAM TIMER
146 Mwe 23B1B004            0          2       0 5320/6000   0 IPAM/ODAP Events
147 Mwe 22CDE8F0        37812  168667433       011264/12000  0 IPAM Manager
148 Mwe 23B1B004            0          2       011320/12000  0 IPAM Events
149 Mwe 22D4727C           44        399     110 2368/6000   0 IP ARP Adjacency
150 Mwe 22D48290            0          1       0 5284/6000   0 IP ARP Retry Age
151 Mrd 22D1A21C       578536    2595625     222 7948/12000  0 IP Input
152 Mwe 22D521A8            0         99       0 5648/6000   0 ICMP event handl
153 Mwe 22E0685C            0          3       0 5256/6000   0 PIM register asy
154 Mwe 23171DCC           12       8966       1 5248/6000   0 MOP Protocols
155 Mwe 233208A8            0          2       0 5272/6000   0 PPP SIP
156 Mwe 23B1B004            0          2       0 5316/6000   0 PPP Bind
157 Mwe 23B1B004            0          2       011316/12000  0 PPP IP Route
158 Mwe 235EA920            0          1       0 8644/9000   0 HQF TUNNEL
159 M*         0          176        134    131320928/24000132 Virtual Exec
160 Mwe 238FAB6C            0          1       011800/12000  0 SSS Manager
161 Mwe 2390817C            0          1       011784/12000  0 SSS Policy Manag
162 Mwe 238E88B8            0          1       0 5652/6000   0 SSS Feature Mana
163 Mwe 238E89B4         5120   21107106       0 5696/6000   0 SSS Feature Time
164 Mwe 239CF0E4       261164    8268213      3110852/12000  0 Spanning Tree
165 Mwe 23C365E0            0          2       011288/12000  0 SSM connection m
166 Mwe 23D63270            0          1       011712/12000  0 WAAS Process
167 Lwe 23DAA2EC            0          1       0 5328/6000   0 X.25 Encaps Mana
168 Mwe 2298BBEC           76      89997       0 5668/6000   0 FRR Background P
169 Lwe 2291D5E4         5948     107975      5510196/12000  0 CEF background p
170 Hwe 2291D5E4            0          1       011360/12000  0 fib_fib_bfd_sb e
171 Mwe 2134DB0C            0          1       0 5760/6000   0 IPC UDP Input
172 Lwe 229B7F30        15016    7581853       110476/12000  0 CEF: IPv4 proces
173 Lwe 2291D5E4            0         28       0 5224/6000   0 ADJ background
174 Lwe 2291D5E4            0         26       011360/12000  0 Collection proce
175 Hwe 2309A4F0            0          1       0 5772/6000   0 Socket Timers
176 Mwe 214F2DDC            0          1       0 5720/6000   0 Critical Auth
177 Mwe 2154AA20            0          2       0 5276/6000   0 Dot1x Supplicant
178 Mwe 2154F2CC            0          2       0 5260/6000   0 Dot1x Supplicant
179 Mwe 21549F84            0          2       0 5264/6000   0 Dot1x Supplicant
180 Mwe 218AC640           48        306     156 4016/6000   0 L2MM
181 Mwe 218AE978            0          1       0 5636/6000   0 MRD
182 Mwe 2189F850           36       1094      32 5280/6000   0 IGMPSN
183 Mwe 23B1B004            0          2       0 2316/3000   0 L2X Switching Ev
184 Mwe 21BFBA70            0          1       0 5784/6000   0 MAB Framework
185 Cwe 21C10834            0          2       011296/12000  0 RG Media Timer
186 Mwe 21C2242C            0          1       011764/12000  0 RG If-Mgr Timer
187 Mwe 236EB2A4            0          2       011656/12000  0 Routing Topology
188 Mwe 23055150            8        334      23 8840/12000  0 IP RIB Update
189 Mwe 22FF7CA0          192      90473       2 7204/9000   0 IP Background
190 Mwe 23067580            0        859       0 6964/9000   0 IP Connected Rou
191 Mwe 22D70A6C            0          1       0 5728/6000   0 IP Traceroute
192 Mwe 23E383CC          404      90012       4 4632/6000   0 Call Home Timer
193 Mwe 22B38764            0          3       0 5280/6000   0 Flow Exporter Ti
194 Mwe 21FFAE7C            0          1       0 8612/9000   0 IPv6 RIB Event H
196 Mwe 2281D59C            0          3       0 5036/6000   0 Service Routing
197 Mwe 22834A90            8        701      11 2256/6000   0 SR CapMan Proces
198 Mwe 2389DB84            0          1       0 5740/6000   0 SNMP Timers
199 Mwe 237FDB74            0         29       0 4816/6000   0 SCTP Main Proces
200 Mrd 230CAC28          428      38691      11 9112/12000  0 TCP Timer
201 Lwe 230D0728         1212      23941      5010588/12000  0 TCP Protocols
202 Mwe 22C75C2C           80      18439       420472/24000  0 HTTP CORE
203 Hwe 23B1B004            0          2       0 5320/6000   0 PPP Compress Inp
204 Hwe 23B1B004            0          2       0 5316/6000   0 PPP Compress Res
205 Mwe 22547AF8            0          1       059260/60000  0 COPS
206 Mwe 2278D744            0          2       0 5284/6000   0 Dialer Forwarder
207 Mwe 2291D5E4          160       1694      94 9320/12000  0 ADJ resolve proc
208 Lwe 2291D5E4            0          3       011360/12000  0 MFIB Master back
209 Mwe 22F3B3A0            0          2       0 8288/9000   0 Multicast Offloa
210 Mwe 22FEC674            0          1       0 5664/6000   0 RARP Input
211 Mwe 2307AA40            0        185       0 7408/9000   0 static
212 Mwe 230F7C40            0          1       0 8760/9000   0 IP IRDP
213 Mwe 23125704            0          1       0 5800/6000   0 LAPB Process
214 Hwe 232CC5EC            0          1       0 5600/6000   0 PAD InCall
215 Mwe 23DAC1D4            0          2       011276/12000  0 X.25 Background
216 Mwe 234BB604         4696     539981       8 4296/6000   0 QoS stats proces
217 Mwe 235F1518        75280 1347660572       0 5372/6000   0 HQF Output Shape
218 Mwe 235F1614            0          2       0 5704/6000   0 HQF Input Shaper
219 Mwe 237EE090          684    5399999       0 5312/6000   0 RUDPV1 Main Proc
220 Mwe 23BA1F54            0          1       011724/12000  0 VPDN call manage
222 Mwe 22445E64            0          2       0 5304/6000   0 AAA Cached Serve
223 Mwe 227A6328            0          2       0 5304/6000   0 ENABLE AAA
224 Mwe 2286BC20            0          1       0 5648/6000   0 EM Background Pr
225 Mwe 22C9DB48            0          1       0 5796/6000   0 IDMGR CORE
226 Mwe 230FA960            0          1       0 5776/6000   0 Key chain liveke
227 Mwe 23138C0C            0          2       0 5304/6000   0 LINE AAA
228 Mwe 2314B754            0          2       0 5288/6000   0 LOCAL AAA
229 Mwe 23A77E24            0          2       0 5280/6000   0 TPLUS
230 Lsi 23FD59E4            8       4503       1 4116/6000   0 NIST rng proc
231 Mwe 24059628            0          3       0 5260/6000   0 LDAP process
232 Mwe 234257C8            0          2       0 5300/6000   0 CSDB Timer proce
233 Lwe 23FBDA2C            0          2       0 5632/6000   0 crypto engine pr
234 Mwe 23EA48E8           48       6007       7 8152/12000  0 Crypto CA
235 Mwe 23EA5E44            0          1       011652/12000  0 Crypto PKI-CRL
236 Mwe 23FDFBE4            0          1       011664/12000  0 encrypt proc
237 Lwe 23FE1D80         1144        102   11215 4152/6000   0 crypto sw pk pro
238 Lwe 2105A484            0          1       0 8668/9000   0 Licensing MIB pr
239 Mwe 214B7868            0          2       0 5316/6000   0 Control-plane ho
240 Mwe 21A4BFF8         1072    3889197       0 3636/6000   0 PM Callback
241 Mwe 21D03178           40     432275       0 5280/6000   0 dhcp snooping sw
243 Mwe 22567F38            4         83      48 5264/6000   0 AAA SEND STOP EV
244 Mwe 225729CC            0          1       011756/12000  0 Test AAA Client
245 Mwe 23E383CC            0          4       0 7044/9000   0 EEM ED Routing
246 Mwe 23E383CC        12960     346719      37 7040/9000   0 EEM ED Syslog
247 Mwe 23E383CC            0          4       0 7044/9000   0 EEM ED NHRP
248 Mwe 23E383CC            0          4       0 7036/9000   0 EEM ED Track
249 Mwe 23E383CC            0          4       0 7032/9000   0 EEM ED Resource
250 Msi 236D064C          156     539974       0 5312/6000   0 RMON Recycle Pro
251 Mwe 236DAEE4            0          2       0 5300/6000   0 RMON Deferred Se
252 Mwe 239DB614            0          1       0 5676/6000   0 Syslog Traps
253 Mwe 23D7EE0C            0          1       0 5800/6000   0 WAN Optimization
255 Mwe 21A8C164          104          2   52000 2756/6000   0 VLAN Manager
257 Mwe 21C47B40            0          4       011064/12000  0 RBM CORE
258 Hwe 21CCC0B4            4          3    1333 4876/6000   0 CTS credentials
259 Mwe 23E383CC           16        243      65 4092/6000   0 EEM Server
260 Mwe 23E383CC            4         33     121 4568/6000   0 Call Home proces
261 Mwe 23E383CC            4          3    1333 7584/9000   0 EEM Policy Direc
262 Mwe 24083C4C            0       1503       0 4872/6000   0 SSH Event handle
263 Mwe 23E383CC            0          4       0 7036/9000   0 EEM ED CLI
264 Mwe 23E383CC            0          4       0 7040/9000   0 EEM ED Counter
265 Mwe 23E383CC            0          4       0 7032/9000   0 EEM ED Interface
266 Mwe 23E383CC            0          4       0 7040/9000   0 EEM ED IOSWD
267 Mwe 23E383CC            0          4       0 7036/9000   0 EEM ED None
268 Mwe 23E383CC            0          4       0 7036/9000   0 EEM ED OIR
269 Mwe 23E383CC            0          4       0 6820/9000   0 EEM ED RF
270 Mwe 23E383CC            0          4       0 7032/9000   0 EEM ED SNMP
271 Mwe 23E383CC            4          4    1000 7040/9000   0 EEM ED SNMP Obje
272 Mwe 23E383CC            0          4       0 7044/9000   0 EEM ED SNMP Noti
273 Mwe 23E383CC           32      90154       0 7024/9000   0 EEM ED Timer
274 Mwe 23E383CC            0          4       0 7064/9000   0 EEM ED Test
275 Mwe 23E383CC            0          4       0 7060/9000   0 EEM ED Config
276 Mwe 23E383CC            0          4       0 7064/9000   0 EEM ED Env
277 Mwe 22732320          740       5451     135 8808/12000  0 DHCPD Receive
278 Mwe 23E383CC            4          4    1000 7016/9000   0 EEM ED Nf
279 Mwe 22CFA344            8        931       811284/12000  0 Syslog
280 Mwe 23E383CC            0          4       0 7040/9000   0 EEM ED RPC
281 Hwe 21B39BB4            0          1       023004/24000  0 tHUB
282 Mwe 22DCB678            0          2       011152/12000  0 MRIB Process
283 Mwe 212E11F8            4          1    4000 2292/3000   0 Async write proc
284 Mwe 212E11F8            0          1       0 2292/3000   0 Async write proc
285 Mwe 212E11F8            0          1       0 2292/3000   0 Async write proc
286 Mwe 212E11F8            0          1       0 2296/3000   0 Async write proc
287 Msi 212DA8E8          148      89997       1 2760/3000   0 DFS flush period
288 Mwe 23E383CC           12        403      29 4140/6000   0 EEM Helper Threa
289 Mwe 22F6192C         8812   10691023       0 4988/6000   0 IP NAT Ager
290 Mwe 22FCF37C            0          1       0 5708/6000   0 IP NAT WLAN
291 Mwe 23449E64         1948     102281      19 5592/6000   0 IP VFR proc
292 Mwe 23110018          624      11129      56 4848/6000   0 l4f mgt task
293 Cwe 231049DC            0          1       0 5640/6000   0 L4F OOB Process
294 Mwe 239C723C         1232    5276626       011560/12000  0 CFT Timer Proces
295 Mwe 2271D664          720    5399086       0 8288/12000  0 DHCP Client
297 Mwe 227365BC            4      45078       0 4092/6000   0 DHCPD Timer
298 Msi 22740DC8           68      89996       0 5144/6000   0 DHCPD Database
output from #show processes cpu sorted would be more useful.
Best Regards Please rate all helpful posts and close solved questions
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Since your total CPU and Interrupt CPU are so close, show process CPU might not provide any indication of unusual CPU usage.  I.e. CPU is being used for "normal" packet forwarding.
If CPU is being used for "normal" packet forwarding, the difference between a 3825 and 1941 CPU consumption might be related to volume of traffic flowing through the two different routers, type of traffic flowing through the two different routers, different architecture of the two different routers (even though they have about the same PPS ratings), or some combination of these.
Hi guys,
     Here is the revised dump - 'show processes cpu sorted'...
CPU utilization for five seconds: 56%/54%; one minute: 55%; five minutes: 54%
PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
217       76392  1357364375          0  0.31%  0.36%  0.35%   0 HQF Output Shape
110        8640   692396143          0  0.23%  0.22%  0.23%   0 Ethernet Msec Ti
159          24         132        181  0.15%  0.01%  0.00% 132 Virtual Exec
109         864    34585551          0  0.07%  0.00%  0.00%   0 Ethernet Timer C
289       24296    11014570          2  0.07%  0.12%  0.14%   0 IP NAT Ager
151      595780     2644506        225  0.07%  0.01%  0.00%   0 IP Input
105        8724    10884370          0  0.07%  0.01%  0.00%   0 BPSM stat Proces
  31     5614964    84851804         66  0.07%  0.13%  0.15%   0 ARP Input
   8           0           2          0  0.00%  0.00%  0.00%   0 Timers
   9           8        2596          3  0.00%  0.00%  0.00%   0 WATCH_AFS
  11           0           1          0  0.00%  0.00%  0.00%   0 Image License br
  10           0           1          0  0.00%  0.00%  0.00%   0 License Client N
  13     4366024     5437883        802  0.00%  0.04%  0.04%   0 Environmental mo
   7           0           1          0  0.00%  0.00%  0.00%   0 DiscardQ Backgro
  15          52       90645          0  0.00%  0.00%  0.00%   0 IPC Dynamic Cach
  16           0           1          0  0.00%  0.00%  0.00%   0 IPC Session Serv
  12     3693320       90645      40744  0.00%  0.05%  0.05%   0 Licensing Auto U
   6       22344       91054        245  0.00%  0.00%  0.00%   0 Pool Manager
  19         900     5314623          0  0.00%  0.00%  0.00%   0 IPC Deferred Por
  20           0           1          0  0.00%  0.00%  0.00%   0 IPC Process leve
  21           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat Manager
  14        3948     1087734          3  0.00%  0.00%  0.00%   0 IPC Event Notifi
   5     4918556      829652       5928  0.00%  0.08%  0.06%   0 Check heaps
  24           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat TX Cont
  25          28      544239          0  0.00%  0.00%  0.00%   0 IPC Keep Alive M
  26          44     1088468          0  0.00%  0.00%  0.00%   0 IPC Loadometer
  27           0           1          0  0.00%  0.00%  0.00%   0 Crash writer
  28           0           1          0  0.00%  0.00%  0.00%   0 Exception contro
  17           0           1          0  0.00%  0.00%  0.00%   0 IPC Zone Manager
  18         824     5314623          0  0.00%  0.00%  0.00%   0 IPC Periodic Tim
  22           8      310993          0  0.00%  0.00%  0.00%   0 IPC Check Queue
  33           0           2          0  0.00%  0.00%  0.00%   0 ATM Idle Timer
  34           0           1          0  0.00%  0.00%  0.00%   0 ATM ASYNC PROC
  35           0           1          0  0.00%  0.00%  0.00%   0 CEF MIB API
  36           0           1          0  0.00%  0.00%  0.00%   0 AAA_SERVER_DEADT
  37           0           1          0  0.00%  0.00%  0.00%   0 Policy Manager
  38           0           2          0  0.00%  0.00%  0.00%   0 DDR Timers
  39           0           4          0  0.00%  0.00%  0.00%   0 Entity MIB API
  40        2144          29      73931  0.00%  0.00%  0.00%   0 PrstVbl
  23           0           1          0  0.00%  0.00%  0.00%   0 IPC Seat RX Cont
  42           0           1          0  0.00%  0.00%  0.00%   0 RMI RM Notify Wa
  30           0           1          0  0.00%  0.00%  0.00%   0 IFS Agent Manage
  44           4           1       4000  0.00%  0.00%  0.00%   0 RF SCTPthread
  45           0           1          0  0.00%  0.00%  0.00%   0 CHKPT RG SCTPthr
  46        1164       47120         24  0.00%  0.00%  0.00%   0 ARP Snoop
  47        5096     5442342          0  0.00%  0.00%  0.00%   0 GraphIt
  48           0           2          0  0.00%  0.00%  0.00%   0 Dialer event
  49           0           1          0  0.00%  0.00%  0.00%   0 SERIAL A'detect
  50           0           2          0  0.00%  0.00%  0.00%   0 XML Proxy Client
  51           0           1          0  0.00%  0.00%  0.00%   0 Critical Bkgnd
  52       13348      562160         23  0.00%  0.00%  0.00%   0 Net Background
  53           0           3          0  0.00%  0.00%  0.00%   0 IDB Work
  54         236      652641          0  0.00%  0.00%  0.00%   0 Logger
  32        7000     5673456          1  0.00%  0.00%  0.00%   0 ARP Background
   4           0           1          0  0.00%  0.00%  0.00%   0 RO Notify Timers
  57           4           4       1000  0.00%  0.00%  0.00%   0 IF-MGR control p
  41           0           2          0  0.00%  0.00%  0.00%   0 Serial Backgroun
  59           0           1          0  0.00%  0.00%  0.00%   0 Inode Table Dest
  60           0           2          0  0.00%  0.00%  0.00%   0 cpf_msg_holdq_pr
  61           0           1          0  0.00%  0.00%  0.00%   0 cpf_msg_rcvq_pro
  62           0           1          0  0.00%  0.00%  0.00%   0 cpf_process_tpQ
  63           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  64           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  65           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  66           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  67           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  68           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  69           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  70           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
  71           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
   3           4           1       4000  0.00%  0.00%  0.00%   0 LICENSE AGENT
  73           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-HA
   2        5668     1088470          5  0.00%  0.03%  0.02%   0 Load Meter
  75           0           7          0  0.00%  0.00%  0.00%   0 RF Master Main T
  43           0           2          0  0.00%  0.00%  0.00%   0 SMART
  77         828       55415         14  0.00%  0.00%  0.00%   0 Net Input
  78        1828     1088534          1  0.00%  0.00%  0.00%   0 Compute load avg
  79      419048      183207       2287  0.00%  0.00%  0.00%   0 Per-minute Jobs
  55        2212     5437884          0  0.00%  0.00%  0.00%   0 TTY Background
  81           0           3          0  0.00%  0.00%  0.00%   0 AggMgr Process
  82           0           1          0  0.00%  0.00%  0.00%   0 Token Daemon
  83           0       23058          0  0.00%  0.00%  0.00%   0 Transport Port A
  84       34576     1125817         30  0.00%  0.00%  0.00%   0 HC Counter Timer
  85       11448      362568         31  0.00%  0.00%  0.00%   0 SM Monitor
  86           0           2          0  0.00%  0.00%  0.00%   0 SM Installer
  87           0           1          0  0.00%  0.00%  0.00%   0 dev_device_inser
  88           0           1          0  0.00%  0.00%  0.00%   0 dev_device_remov
  89           0           2          0  0.00%  0.00%  0.00%   0 ESWPPM
  90           0           2          0  0.00%  0.00%  0.00%   0 Eswilp Storm Con
  91       12796         628      20375  0.00%  0.00%  0.00%   0 DXMRVL
  92           0           1          0  0.00%  0.00%  0.00%   0 esw_mrvl mat que
  93      313824     5488955         57  0.00%  0.00%  0.00%   0 ehwic_eswge Proc
  94         132     5442176          0  0.00%  0.00%  0.00%   0 Console redirect
  95           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_DELA
  96           0           1          0  0.00%  0.00%  0.00%   0 RF_INTERDEV_SCTP
  97           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Identity
  98        9384      408738         22  0.00%  0.00%  0.00%   0 EEM ED ND
  99         668     5433146          0  0.00%  0.00%  0.00%   0 Dynamic DNS Upda
100           0           1          0  0.00%  0.00%  0.00%   0 IGMP Snooping Pr
101          28        1116         25  0.00%  0.00%  0.00%   0 IGMP Snooping Re
102         116      181289          0  0.00%  0.00%  0.00%   0 Call Management
103           4           2       2000  0.00%  0.00%  0.00%   0 USB Startup
104           0           1          0  0.00%  0.00%  0.00%   0 CF_INTERDEV_SCTP
  58           4         540          7  0.00%  0.00%  0.00%   0 IF-MGR event pro
106        1764         264       6681  0.00%  0.00%  0.00%   0 i2c sm_exchange
107      115728      162104        713  0.00%  0.00%  0.00%   0 i2c console redi
108           0           2          0  0.00%  0.00%  0.00%   0 Ethernet CFM
  56           0           6          0  0.00%  0.00%  0.00%   0 RF Slave Main Th
  72           0           1          0  0.00%  0.00%  0.00%   0 CHKPT Test clien
111           8         593         13  0.00%  0.00%  0.00%   0 Auth Manager
112           0           1          0  0.00%  0.00%  0.00%   0 AUTH POLICY Fram
113           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Mgr Proces
114           0           1          0  0.00%  0.00%  0.00%   0 802.1x Webauth F
115           0           1          0  0.00%  0.00%  0.00%   0 EAP Framework
116           0           2          0  0.00%  0.00%  0.00%   0 CMD HANDLER
117           0           2          0  0.00%  0.00%  0.00%   0 DTP Protocol
118           0           1          0  0.00%  0.00%  0.00%   0 SFF8472
119         668     5437886          0  0.00%  0.00%  0.00%   0 PI MATM Aging Pr
120           0           2          0  0.00%  0.00%  0.00%   0 call_home_les_oi
121           0           1          0  0.00%  0.00%  0.00%   0 SMI Director DB
122           0           1          0  0.00%  0.00%  0.00%   0 SMI CDP Update H
123           0           1          0  0.00%  0.00%  0.00%   0 SMI Backup Proce
124           0           2          0  0.00%  0.00%  0.00%   0 RG Faults Timer
125           0           2          0  0.00%  0.00%  0.00%   0 RG Protocol Time
126           0           2          0  0.00%  0.00%  0.00%   0 RG Transport Tim
127           0           1          0  0.00%  0.00%  0.00%   0 RG VP
128           0           2          0  0.00%  0.00%  0.00%   0 RG AR
129           0           3          0  0.00%  0.00%  0.00%   0 CTS CORE
130           8         201         39  0.00%  0.00%  0.00%   0 SXP CORE
131           4       45354          0  0.00%  0.00%  0.00%   0 DHCP Snooping
132           0           2          0  0.00%  0.00%  0.00%   0 IP Host Track Pr
133           0           1          0  0.00%  0.00%  0.00%   0 IPv6 ping proces
134           0           2          0  0.00%  0.00%  0.00%   0 AAA Server
135           0           1          0  0.00%  0.00%  0.00%   0 AAA ACCT Proc
136           0           1          0  0.00%  0.00%  0.00%   0 ACCT Periodic Pr
137           0           1          0  0.00%  0.00%  0.00%   0 AAA System Acct
138       32196     1495544         21  0.00%  0.00%  0.00%   0 CDP Protocol
139           0           2          0  0.00%  0.00%  0.00%   0 AAA Dictionary R
140           0           2          0  0.00%  0.00%  0.00%   0 Ethernet LMI
141           0           2          0  0.00%  0.00%  0.00%   0 Ethernet OAM Pro
142           0           2          0  0.00%  0.00%  0.00%   0 CEF switching ba
  74          12       47741          0  0.00%  0.00%  0.00%   0 TDM Management
144           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM Input
145           0           2          0  0.00%  0.00%  0.00%   0 ATM OAM TIMER
146           0           2          0  0.00%  0.00%  0.00%   0 IPAM/ODAP Events
  76           0           2          0  0.00%  0.00%  0.00%   0 RF Master Status
148           0           2          0  0.00%  0.00%  0.00%   0 IPAM Events
149          44         401        109  0.00%  0.00%  0.00%   0 IP ARP Adjacency
150           0           1          0  0.00%  0.00%  0.00%   0 IP ARP Retry Age
  80        8312     5442705          1  0.00%  0.01%  0.00%   0 Per-Second Jobs
152           0          99          0  0.00%  0.00%  0.00%   0 ICMP event handl
153           0           3          0  0.00%  0.00%  0.00%   0 PIM register asy
154          12        9031          1  0.00%  0.00%  0.00%   0 MOP Protocols
155           0           2          0  0.00%  0.00%  0.00%   0 PPP SIP
156           0           2          0  0.00%  0.00%  0.00%   0 PPP Bind
157           0           2          0  0.00%  0.00%  0.00%   0 PPP IP Route
158           0           1          0  0.00%  0.00%  0.00%   0 HQF TUNNEL
   1         932       10257         90  0.00%  0.00%  0.00%   0 Chunk Manager
160           0           1          0  0.00%  0.00%  0.00%   0 SSS Manager
161           0           1          0  0.00%  0.00%  0.00%   0 SSS Policy Manag
162           0           1          0  0.00%  0.00%  0.00%   0 SSS Feature Mana
163        5160    21259209          0  0.00%  0.00%  0.00%   0 SSS Feature Time
164      262724     8318203         31  0.00%  0.02%  0.00%   0 Spanning Tree
165           0           2          0  0.00%  0.00%  0.00%   0 SSM connection m
166           0           1          0  0.00%  0.00%  0.00%   0 WAAS Process
167           0           1          0  0.00%  0.00%  0.00%   0 X.25 Encaps Mana
168          76       90645          0  0.00%  0.00%  0.00%   0 FRR Background P
169        5976      108752         54  0.00%  0.00%  0.00%   0 CEF background p
170           0           1          0  0.00%  0.00%  0.00%   0 fib_fib_bfd_sb e
171           0           1          0  0.00%  0.00%  0.00%   0 IPC UDP Input
172       15304     7633442          2  0.00%  0.00%  0.00%   0 CEF: IPv4 proces
173           0          28          0  0.00%  0.00%  0.00%   0 ADJ background
174           0          26          0  0.00%  0.00%  0.00%   0 Collection proce
175           0           1          0  0.00%  0.00%  0.00%   0 Socket Timers
176           0           1          0  0.00%  0.00%  0.00%   0 Critical Auth
177           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
178           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
179           0           2          0  0.00%  0.00%  0.00%   0 Dot1x Supplicant
180          48         306        156  0.00%  0.00%  0.00%   0 L2MM
181           0           1          0  0.00%  0.00%  0.00%   0 MRD
182          36        1114         32  0.00%  0.00%  0.00%   0 IGMPSN
183           0           2          0  0.00%  0.00%  0.00%   0 L2X Switching Ev
184           0           1          0  0.00%  0.00%  0.00%   0 MAB Framework
185           0           2          0  0.00%  0.00%  0.00%   0 RG Media Timer
186           0           1          0  0.00%  0.00%  0.00%   0 RG If-Mgr Timer
187           0           2          0  0.00%  0.00%  0.00%   0 Routing Topology
188           8         334         23  0.00%  0.00%  0.00%   0 IP RIB Update
189         200       91121          2  0.00%  0.00%  0.00%   0 IP Background
190           0         859          0  0.00%  0.00%  0.00%   0 IP Connected Rou
191           0           1          0  0.00%  0.00%  0.00%   0 IP Traceroute
192         436       90660          4  0.00%  0.00%  0.00%   0 Call Home Timer
193           0           3          0  0.00%  0.00%  0.00%   0 Flow Exporter Ti
194           0           1          0  0.00%  0.00%  0.00%   0 IPv6 RIB Event H
196           0           3          0  0.00%  0.00%  0.00%   0 Service Routing
197           8         701         11  0.00%  0.00%  0.00%   0 SR CapMan Proces
198           0           1          0  0.00%  0.00%  0.00%   0 SNMP Timers
199           0          29          0  0.00%  0.00%  0.00%   0 SCTP Main Proces
200         428       39009         10  0.00%  0.00%  0.00%   0 TCP Timer
201        1216       24160         50  0.00%  0.00%  0.00%   0 TCP Protocols
202          80       18569          4  0.00%  0.00%  0.00%   0 HTTP CORE
203           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Inp
204           0           2          0  0.00%  0.00%  0.00%   0 PPP Compress Res
205           0           1          0  0.00%  0.00%  0.00%   0 COPS
206           0           2          0  0.00%  0.00%  0.00%   0 Dialer Forwarder
207         160        1698         94  0.00%  0.00%  0.00%   0 ADJ resolve proc
208           0           3          0  0.00%  0.00%  0.00%   0 MFIB Master back
209           0           2          0  0.00%  0.00%  0.00%   0 Multicast Offloa
210           0           1          0  0.00%  0.00%  0.00%   0 RARP Input
211           0         185          0  0.00%  0.00%  0.00%   0 static
212           0           1          0  0.00%  0.00%  0.00%   0 IP IRDP
213           0           1          0  0.00%  0.00%  0.00%   0 LAPB Process
214           0           1          0  0.00%  0.00%  0.00%   0 PAD InCall
215           0           2          0  0.00%  0.00%  0.00%   0 X.25 Background
216        4876      543872          8  0.00%  0.00%  0.00%   0 QoS stats proces
143           0           1          0  0.00%  0.00%  0.00%   0 ADJ NSF process
218           0           2          0  0.00%  0.00%  0.00%   0 HQF Input Shaper
219         708     5439044          0  0.00%  0.00%  0.00%   0 RUDPV1 Main Proc
220           0           1          0  0.00%  0.00%  0.00%   0 VPDN call manage
222           0           2          0  0.00%  0.00%  0.00%   0 AAA Cached Serve
223           0           2          0  0.00%  0.00%  0.00%   0 ENABLE AAA
224           0           1          0  0.00%  0.00%  0.00%   0 EM Background Pr
225           0           1          0  0.00%  0.00%  0.00%   0 IDMGR CORE
226           0           1          0  0.00%  0.00%  0.00%   0 Key chain liveke
227           0           2          0  0.00%  0.00%  0.00%   0 LINE AAA
228           0           2          0  0.00%  0.00%  0.00%   0 LOCAL AAA
229           0           2          0  0.00%  0.00%  0.00%   0 TPLUS
230           8        4536          1  0.00%  0.00%  0.00%   0 NIST rng proc
231           0           3          0  0.00%  0.00%  0.00%   0 LDAP process
232           0           2          0  0.00%  0.00%  0.00%   0 CSDB Timer proce
233           0           2          0  0.00%  0.00%  0.00%   0 crypto engine pr
234          48        6051          7  0.00%  0.00%  0.00%   0 Crypto CA
235           0           1          0  0.00%  0.00%  0.00%   0 Crypto PKI-CRL
236           0           1          0  0.00%  0.00%  0.00%   0 encrypt proc
237        1144         102      11215  0.00%  0.00%  0.00%   0 crypto sw pk pro
238           0           1          0  0.00%  0.00%  0.00%   0 Licensing MIB pr
239           0           2          0  0.00%  0.00%  0.00%   0 Control-plane ho
240        1072     3917219          0  0.00%  0.00%  0.00%   0 PM Callback
241          40      435390          0  0.00%  0.00%  0.00%   0 dhcp snooping sw
243           4          85         47  0.00%  0.00%  0.00%   0 AAA SEND STOP EV
244           0           1          0  0.00%  0.00%  0.00%   0 Test AAA Client
245           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Routing
246       13976      367847         37  0.00%  0.00%  0.00%   0 EEM ED Syslog
247           0           4          0  0.00%  0.00%  0.00%   0 EEM ED NHRP
248           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Track
249           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Resource
250         160      543865          0  0.00%  0.00%  0.00%   0 RMON Recycle Pro
251           0           2          0  0.00%  0.00%  0.00%   0 RMON Deferred Se
252           0           1          0  0.00%  0.00%  0.00%   0 Syslog Traps
253           0           1          0  0.00%  0.00%  0.00%   0 WAN Optimization
255         104           2      52000  0.00%  0.00%  0.00%   0 VLAN Manager
257           0           4          0  0.00%  0.00%  0.00%   0 RBM CORE
258           4           3       1333  0.00%  0.00%  0.00%   0 CTS credentials
259          16         243         65  0.00%  0.00%  0.00%   0 EEM Server
260           4          33        121  0.00%  0.00%  0.00%   0 Call Home proces
261           4           3       1333  0.00%  0.00%  0.00%   0 EEM Policy Direc
262           0        1514          0  0.00%  0.00%  0.00%   0 SSH Event handle
263           0           4          0  0.00%  0.00%  0.00%   0 EEM ED CLI
264           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Counter
265           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Interface
266           0           4          0  0.00%  0.00%  0.00%   0 EEM ED IOSWD
267           0           4          0  0.00%  0.00%  0.00%   0 EEM ED None
268           0           4          0  0.00%  0.00%  0.00%   0 EEM ED OIR
269           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RF
270           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP
271           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED SNMP Obje
272           0           4          0  0.00%  0.00%  0.00%   0 EEM ED SNMP Noti
273          32       90803          0  0.00%  0.00%  0.00%   0 EEM ED Timer
274           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Test
275           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Config
276           0           4          0  0.00%  0.00%  0.00%   0 EEM ED Env
277         744        5511        135  0.00%  0.00%  0.00%   0 DHCPD Receive
278           4           4       1000  0.00%  0.00%  0.00%   0 EEM ED Nf
279          32        1025         31  0.00%  0.00%  0.00%   0 Syslog
280           0           4          0  0.00%  0.00%  0.00%   0 EEM ED RPC
281           0           1          0  0.00%  0.00%  0.00%   0 tHUB
282           0           2          0  0.00%  0.00%  0.00%   0 MRIB Process
283           4           1       4000  0.00%  0.00%  0.00%   0 Async write proc
284           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
285           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
286           0           1          0  0.00%  0.00%  0.00%   0 Async write proc
287         172       90645          1  0.00%  0.00%  0.00%   0 DFS flush period
288          12         403         29  0.00%  0.00%  0.00%   0 EEM Helper Threa
147       37996   169882340          0  0.00%  0.05%  0.05%   0 IPAM Manager
290           0           1          0  0.00%  0.00%  0.00%   0 IP NAT WLAN
291        6900      320570         21  0.00%  0.01%  0.00%   0 IP VFR proc
292         628       11217         55  0.00%  0.00%  0.00%   0 l4f mgt task
293           0           1          0  0.00%  0.00%  0.00%   0 L4F OOB Process
294        1260     5314646          0  0.00%  0.00%  0.00%   0 CFT Timer Proces
295         744     5437987          0  0.00%  0.00%  0.00%   0 DHCP Client
297           4       45402          0  0.00%  0.00%  0.00%   0 DHCPD Timer
298          76       90644          0  0.00%  0.00%  0.00%   0 DHCPD Database
Thanks.
Hi guys,
     Soooo..we did the above cpu dump having ONE machine tax the isp connection.  So what you see is a machine with roughly 300 connections running a torrent download and fully using all of the 100/5 connection.  My question is if we move to a 250/15 connection and the same scenerio, will we see the 1941W at 100% because we will roughly double the isp WAN connection?  If so, I guess we might have to move to a 2900 series and above for faster PPS?  Yes / no?  OR is it memory related?  It's tough to figure out the cause because the cpu dump doesn't show anything abnormal.
Ideas?
Disclaimer
Posting
On a 1941, if you saturating your 100/5 connection, 55% appears reasonable because Cisco lists a 1941, at 75% CPU, able to forward 120 Mbps of IMIX traffic with HQoS, 91 Mbps of IMIX traffic with PAT, or 76 Mbps with IMIX with NAT + QoS + ACL.
Doubling the volume of existing traffic would likely max out the CPU.  So yes, if you want to use a larger capacity link, you might need a more powerful router.
As a rough rule of thumb, not exceeding 75% CPU is good, so you still have a little head room with your 1941.
Hi Joseph,
     Thanks for the reply.  So would it be prudent to look at a router based on your specs / PPS?  BTW, can you give me a link on the specs you provided and a comparison for higher end router?
Thanks again for the feedback.
Hi Joseph,
OR load balance it with my existing routers....I can attach a 2821.  The 3825 is doing other stuff
Thanks.
Disclaimer
Posting
Normally you size a router based on volume and kind of traffic, and what features you'll be using.
I've attached a Cisco paper on later ISR performance.
Hi Joseph,
     So, just following along the topic...Instead of upgrading, we are looking at utilizing our 2821 in conjunction with the 1941 and load balance between the 2 still using the 100/5 connection.  Possible?  The reason is that there is a possiblilty to up our wan speed to roughly double and we don't want to overwhelm the 1941.
Ideas, sugggestion?
Thanks again for your time.
Disclaimer
Posting
Two routers sharing a connection?  Yes, might be possible, although difficult to balance out CPU load.
If you directed outbound flows to each router in proportion to its CPU capacity, return flows would (hopefully) be in about the same proportion.
Hi Joseph,
    Thanks again...So, in other words, possible but the better solution is to up the edge router?
Thanks for the input...
Disclaimer
Posting
Unsure two routers on one link would be "better", although does offer router redundancy.  An "up'ed" router would be easier, although more expensive.  You might try the multiple routers on a faster shared link and if unsatisfactory, replace with an "up'ed" router.
