VDSL with Vlan ID on Cisco 1117
lester.mendoza
Good Day,
I'm trying to replace the Huawei router with Cisco with no luck on the 1st attempt, the Service provider asked me to ensure the VLAN 100 is on the router.
I've been told this is not normal PPPoE, the Service provider use a Fiber to the Demarc and still using the Legacy to the customer premises.
https://www.nbnco.com.au/residential/learn/network-technology/fibre-to-the-building-explained-fttb
I don't know how to incorporate/include the vlan 100 to the existing config,  see below, would please able to help? Pleaes
controller VDSL 0/3/0
interface ATM0/3/0
description LINK_TO_TPG
no ip address
no ip redirects
no ip proxy-arp
no atm ilmi-keepalive
no atm enable-ilmi-trap
interface ATM0/3/0.1 point-to-point
pvc 8/35
pppoe-client dial-pool-number 1
interface Dialer1
description connection to TPG with PPP authentication
ip address negotiated
no ip redirects
no ip proxy-arp
encapsulation ppp
ip tcp adjust-mss 1436
dialer pool 1
ppp authentication pap callin
ppp pap sent-username 258proudN@pig.tpg.com.au password 0 258proudN
ip route 0.0.0.0 0.0.0.0 Dialer1
Below, interface status during the cutover, interface showing down/down but controller VDSL0/3/0 showing UP.
258-PROUD#show controllers vdSL 0/3/0
Controller VDSL 0/3/0 is UP
Daemon Status: UP
XTU-R (DS) XTU-C (US)
Chip Vendor ID: 'BDCM' 'BDCM'
Chip Vendor Specific: 0x0000 0xB0C7
Chip Vendor Country: 0xB500 0xB500
Modem Vendor ID: 'CSCO' ' '
Modem Vendor Specific: 0x4602 0x0000
Modem Vendor Country: 0xB500 0x0000
Serial Number Near: FGL2250139V C1117-4P 16.6.4
Serial Number Far:
Modem Version Near: 16.6.4
Modem Version Far: 0xb0c7
Modem Status: TC Sync (Showtime!)
DSL Config Mode: AUTO
Trained Mode: G.993.2 (VDSL2) Profile 17a
TC Mode: PTM
Selftest Result: 0x00
DELT configuration: disabled
DELT state: not running
Failed full inits: 0
Short inits: 0
Failed short inits: 0
Modem FW Version: 4.14L.04
Modem PHY Version: A2pv6F039t.d26d
Line 0:
Trellis: ON ON
SRA: disabled disabled
SRA count: 0 0
Bit swap: enabled enabled
Bit swap count: 10 0
Line Attenuation: 9.3 dB 0.0 dB
Signal Attenuation: 0.0 dB 0.0 dB
Noise Margin: 44.7 dB 46.4 dB
Attainable Rate: 109103 kbits/s 56616 kbits/s
Actual Power: 12.0 dBm 6.6 dBm
Per Band Status: D1 D2 D3 U0 U1 U2 U3
Line Attenuation(dB): 5.3 11.5 16.7 2.0 8.3 12.5 N/A
Signal Attenuation(dB): 6.7 11.3 16.7 2.0 8.0 13.7 N/A
Noise Margin(dB): 44.8 45.2 44.3 46.1 48.9 44.8 N/A
Total FECC: 0 0
Total ES: 0 0
Total SES: 0 0
Total LOSS: 0 0
Total UAS: 179 179
Total LPRS: 0 0
Total LOFS: 0 0
Total LOLS: 0 0
DS Channel1 DS Channel0 US Channel1 US Channel0
Speed (kbps): NA 13960 NA 2080
SRA Previous Speed: NA 0 NA 0
Reed-Solomon EC: NA 0 NA 0
CRC Errors: NA 0 NA 0
Header Errors: NA 0 NA 0
Interleave (ms): NA 0.00 NA 0.00
Actual INP: NA 39.00 NA 41.00
Training Log : Stopped
Training Log Filename : flash:vdsllog.bin
258-PROUD#
258-PROUD# show ip int brief
GigabitEthernet0/0/0 unassigned YES NVRAM down down
GigabitEthernet0/1/0 unassigned YES unset up up
GigabitEthernet0/1/1 unassigned YES unset up up
GigabitEthernet0/1/2 unassigned YES unset down down
GigabitEthernet0/1/3 unassigned YES unset down down
Wl0/1/4 unassigned YES unset up up
Cellular0/2/0 unassigned YES NVRAM down down
Cellular0/2/1 unassigned YES NVRAM administratively down down
ATM0/3/0 unassigned YES NVRAM down down
ATM0/3/0.1 unassigned YES unset down down
Ethernet0/3/0 unassigned YES NVRAM administratively down down
Dialer1 unassigned YES NVRAM up up
Vlan1 10.2.58.254 YES NVRAM up up
258-PROUD#
*Feb 7 10:20:26.061 SYD: VC micro block get: Invalid vc handle
*Feb 7 10:20:28.108 SYD: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
*Feb 7 10:20:28.109 SYD: VC micro block get: Invalid vc handle
*Feb 7 10:20:30.155 SYD: (atm_vc_is_bridged_dot1q)ATM: VC with handle 0x0 not found
*Feb 7 10:20:30.155 SYD: VC micro block get: Invalid vc handle
*Feb 7 10:20:30.156 SYD: VC micro block get: Invalid vc handle
0 Replies 0
